01-31-2013, 12:09 PM | #121 | |
RCC Addict Join Date: Apr 2008 Location: Singapore
| Re: AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho Quote:
01-31-2013, 03:07 PM | #122 |
Newbie Join Date: Jan 2012 Location: Sydney, Australia
Ahh I see, Im only use to a savage nitro with a 3 speed. Which you dont notice it so much Im guessing it would be a little more exaggerated with a 55T motor on low gear. We will wack in the stock 27T and see if it pleases him more. And I will tell him it makes it a little more realistic as you need to control direction throttle to stay on a peak ;) Ok, Thanks as he was worried he got a faulty one. Here they charged us 80% tax so it was a worry if we had to send it back and then have to pay the tax again etc... Hehe the most expensive ax2 here almost 260 dollars for him just to have it. Will add the thread lock on the shifter shaft. Me personally had a diablo when you guys were new. And it didnt last to well, diffncasings got very brittel fast and snapped and had problems with linkages on the tranny. Anyway quality seems nicer now! Build many tf2's for teenages here ;) |
02-02-2013, 11:04 PM | #123 |
Pebble Pounder Join Date: Jan 2013 Location: Gilbert
Wanting to get this tranny for my Boyer truggy. Does anyone currently run the ax2 in theirs? If so, what all do I need for mod to correctly install in order not to have binding issues or drive-line issues?? Any info would be appreciated!!! thx |
02-03-2013, 07:16 AM | #124 |
Rock Crawler Join Date: Jan 2006 Location: Bellaire, MI
| Re: AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho That's because the nitro models with multiple speeds use a centrifugal 2/3 speed transmission that automatically shift as the rpm's come up using centrifugal force to fling a lever out to catch on the next higher gear. Completely different system.
02-03-2013, 10:25 AM | #125 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
| Re: AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho I have the 2 speed in my Boyer truggy build. Depending on your final ride height, driveshaft angle shouldn't be a problem. Since the new trans is longer than the stock gearbox one shaft (or both) needs to be shorter. The stock skidplate is pre-drilled for the R2 trans I believe, so drilling the new hole pattern is needed. I mounted the shift servo along side the trans to make room for the battery tray cross-wise on the chassis between the trans and front shock mounts.
02-03-2013, 11:31 AM | #126 | |
Do you like the setup?? I just felt with the truggy the wheel speed was too slow and it is a HEAVY rig, I'm sure this will make a huge difference. Plus might be able to bring the COG down to keep it from rolling as much. Last edited by jjwiggs; 02-03-2013 at 11:34 AM. | |
02-03-2013, 12:31 PM | #127 |
Glad to be of some help! My rig is still in the finishing stage, so I have no idea how it will handle. It IS a beast of a chassis, so low gear should be a plus . I also have the 2 speed in an SCX-10 Comanche and I love it! Steep downhill descents w/o using the brakes are a breeze, and carefully clawing your way up stuff in low gear is as good as it gets. Good speed in 2nd for general trail running too.
02-04-2013, 09:09 AM | #128 | |
Thanks again TraiDawg, you've certainly made my decision to get the ax2 very easy! Keep me posted how your truggy mod goes as well. | |
02-09-2013, 06:48 AM | #129 |
Quarry Creeper Join Date: Jun 2011 Location: butler pa
Great transmission!
02-09-2013, 06:50 PM | #130 |
Rock Crawler Join Date: Apr 2012 Location: Sparks
ok i busted mine! the output shaft on the front side snaped today crawlin in low gear not even on it!.i emailed rc4wd but thought i would post up here also.pro4 on 3s but like i said was just crawlin!pics to come soon!!
02-09-2013, 06:55 PM | #131 |
[IMG][/IMG]
02-09-2013, 06:58 PM | #132 |
not even 1 month old bought 1/15/13
02-09-2013, 09:16 PM | #133 |
| Re: AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho |
02-09-2013, 09:22 PM | #134 |
RCC Addict Join Date: May 2010 Location: Midwest
crawling in low gear and not even in the throttle? maybe it just feel apart at that point but, it actually broke when you were hammering it seconds earlier? have you checked for binding in the drivetrain yet? was a wheel stuck in a hole? what was happening exactly? |
02-10-2013, 01:02 AM | #135 | |
nope not stuck in a hole just normal crawling im really not sure when or why it snaped.it appears to be at a spot were the shaft decreases in size. | |
02-10-2013, 07:22 PM | #136 |
That sucks but don't sweat it, I'm sure RC4WD will take care of you.
02-13-2013, 07:38 AM | #137 |
02-20-2013, 10:55 PM | #138 |
Rock Crawler Join Date: Nov 2008 Location: missoula
Where are guys setting the shift rod for Tranny to start and how do u keep servo from over heating
02-21-2013, 10:38 AM | #139 |
Quarry Creeper Join Date: Apr 2009 Location: Ottawa, ON, Canada
02-22-2013, 01:54 PM | #140 |
Rock Crawler Join Date: Jan 2008 Location: Lehigh Valley, Pa
My EPA's are set near 0 for 1st gear and something like 40 for second gear. It works perfectly and shifts smooth every time.
AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho - Similar Threads | ||||
Axial Wraith & Honcho | Trailing in the Forest | burtonkidd | Videos! | 1 | 01-15-2012 03:47 PM |
2 speed transmission for honcho | Dfrog | Newbie General | 18 | 03-28-2011 07:52 AM |
