Go Back   RCCrawler Forums > Vendors > RCP Crawlers
Thread: Wreckluse Feedback, Support & FAQ
Old 02-06-2013, 06:21 AM   #241
Default Re: Wreckluse Feedback, Support & FAQ
for the motor, I have a holmes hobby 35T with a BR-XL on 3S...very good...
I actually craked the hood too, the HPI jeep is a direct fit? I know it's kinda sucky to scrap a complete body for the hood...but I think it might be cheaper to get the body from my hobbyshop than ordering a new hood from RCP ;) no offence Sozo, but with the shipping to Canada...
rebuilder is offline   Reply With Quote
Old 02-06-2013, 06:55 AM   #242
Rock Slayer
TrailDawg362's Avatar
I'm running a HH 35T/Sidewinder/3S combo, great low end control and good wheel speed when I drop the hammer
TrailDawg362 is offline   Reply With Quote
Old 02-06-2013, 08:00 AM   #243
RCP CRAWLERS
ZoSo's Avatar
I run a 35t
ZoSo is offline   Reply With Quote
Old 02-06-2013, 11:42 PM   #244
I guess a 55T will be too slow
natskiboy is offline   Reply With Quote
Old 02-07-2013, 10:28 AM   #245
RCP CRAWLERS
ZoSo's Avatar
if your running a 3 cell lipo it will work fine
Old 02-09-2013, 03:44 PM   #246
I have a 27 turn stock motor in mine , its a little bit fast but I also run 32 pitch gears 58 spur 15 pinion , I can slow it down with gearing when I need to , my second one will have a 55 t in it .
paleblue46 is offline   Reply With Quote
Old 02-24-2013, 06:43 PM   #247
Can you guys post pics of how you mount your electronics?
Old 02-25-2013, 07:20 AM   #248
RCP CRAWLERS
ZoSo's Avatar
all my electornics are mounted behind my dash....battery slides in behind the front wheels
Old 02-25-2013, 08:32 AM   #249
I also have an issue with the servo arm hitting the 4 link truss. Have you experienced this?
Old 02-25-2013, 08:46 AM   #250
i got mine put together last night now i just need to get a new hood!
JDCrawler27 is offline   Reply With Quote
Old 02-25-2013, 11:37 AM   #251
RCP CRAWLERS
ZoSo's Avatar
is it mounted to the chassis or the axle?
We'll meet up this week
Old 02-25-2013, 12:44 PM   #252
Mine is chassis mounted
Old 02-25-2013, 03:42 PM   #253
RCP CRAWLERS
ZoSo's Avatar
post a pic ....maybe we can figure something out
Old 03-02-2013, 06:11 AM   #254
Ok I really need some help
Here are my link measurement. (actual link not eye to eye)
Upper 115mm Front
Upper 109mm Rear
Lower 109mm Front
Lower 93mm Rear
Here is a pic.
Look at the servo arm right on the 4 link mount
Here is a shot of where the servo suppose to go and the 4 link mount is right at it
I have also tried a GCM mount which is not as high but its still hitting.
What are my options, it seems I cant get axle mounted as the tabs on my axles is cutoff. I am thinking getting new links but not so sure.....
Old 03-02-2013, 03:32 PM   #255
RCP CRAWLERS
ZoSo's Avatar
I see some custom fabrication.... you may want to flip the servo so the arm points forward
and cut away some more from the front
Old 03-03-2013, 07:03 PM   #256
Shes a runner!! I shaved off some of the 4 link truss and mounted the servo arm forward. It only hits on the left side. I am thinking of adding some spacers to the servo when I mount it to give me more clearance.
Old 03-03-2013, 09:29 PM   #257
Cool work around Natski...post up some pics of that if you can...
Postclanker is offline   Reply With Quote
Old 03-05-2013, 04:18 AM   #258
Yes will post pic soon. I actually worked on it again and replaced the 4 link truss with the stock Axial 4 link mount (it sits lower on the axle). I also used some servo post to mount the servo higher and cut out some of the metal so the servo arm moves freely. It works better this way as I get more clearance.
Old 03-13-2013, 12:48 PM   #259
Just wanted to let you know guys... HPI discontinued the Rubicon body #7182...dont break you hoods!
Old 06-27-2019, 10:50 AM   #260
Will this be available again?
Thorsteenster is offline   Reply With Quote
You may edit your posts
