Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial AX-10 Scorpion
Loading
Thread: New Comp Build.......SWX......New Production Pics!!
Old 03-13-2008, 12:47 AM   #1
2006 2.2 National Champ
BENDER's Avatar
Exclamation New Comp Build.......SWX......New Production Pics!!
Well, it's time I made the jump to AX10 gear for my newest comp build, with all the goodies needed to be as durable as possible. My TLT axled comp rig has been good to me, but I have been very impressed by the few SW3 AX10 crawlers I've seen in action. I've done a few of these builds in the past, but this one is actually for me.
First up............assembling the axles. Going with the durability theme. I'm starting out with Axial's aftermarket heavy duty ring and pinion, as well as their heavy duty lockers.
BENDER is offline   Reply With Quote
Old 03-13-2008, 12:53 AM   #2
BENDER's Avatar
Starting with the rear, I'm going with the straight axle conversion and aluminum lockouts from RCP Crawlers. Since 4ws isn't allowed in the 2.2 class this is the strongest most efficient way to go on the rear axle for a comp rig, as well as a scaler.
Old 03-13-2008, 01:05 AM   #3
BENDER's Avatar
Start by dropping the locker into the diff case provided with the AX10 kit. Install the gasket on top. Then, screw the ring gear onto the diff assembly, and slide the bearings into place. Slide one bearing on each axle shaft, then lube the ends that fit into the locker with a little grease before installing them.
Old 03-13-2008, 01:11 AM   #4
BENDER's Avatar
Next step, install a bearing onto the axle's pinion shaft and install it into the axle case. Make sure bearing is seated all the way down in the housing, or your gear mesh will be too tight. Now drop the diff/axle shaft assembly in place, add grease, and install 2nd half of the axle's housing with the 4 screws supplied.
Old 03-13-2008, 01:16 AM   #5
BENDER's Avatar
Last step is installing the rear aluminum lockouts. Slide a bearing onto the outer ends of the straight axle, and slip the aluminum lockouts onto the ends of the axle housing. Install M3 screws and the rear axle is ready.
Old 03-13-2008, 01:25 AM   #6
BENDER's Avatar
Time for the front axle. Build will be the same as the rear up to installing the diff assembly into the housing. Install the supplied bearings into the knuckles and add the outer axles. Make sure you don't forget to add the little black bushings to the knuckles before you install them onto the axle C's. I also used stainless button head screws for the kingpins because of their low profile. Aluminum knuckles and axle C's are in the plans for this build too, but the stockers will work for now.
Old 03-13-2008, 01:31 AM   #7
BENDER's Avatar
Here's a little peek at the wheels and tires I'll be running.....................nothing but the best, MSD Top Gun Beadlock Wheels and Losi Rock Claws
Old 03-13-2008, 01:54 AM   #8
Natedog's Avatar
Looks good so far, would really like to get ahold of some of those steel lockers cause my stockers are gettin pretty loose. Flat head allen screws (instead of button-heads) would be better in those countersunk holes for the RCP rear straight axle pieces. ;)
Natedog is offline   Reply With Quote
Old 03-13-2008, 06:13 AM   #9
Brad, welcome to the dark side brother. Cool build thread.
JUSTGOINGSLOW is offline   Reply With Quote
Old 03-13-2008, 06:18 AM   #10
very cool. my build is identical as far as axles go. I picked up the rcp aluminum c's and knuckles but thats it. The ring and pinion look great sitting next to the stock ones. How easy is the bead to clamp onto with those mose wheels? i bought the rc4wd beadlocks and they are next to impossible.
kurt is offline   Reply With Quote
Old 03-13-2008, 09:19 AM   #11
BENDER's Avatar
Quote:
I need to pick-up some more M3 flatheads. But, the button heads may be staying. More details on that later.
Quote:
Thanks.
Quote:
The MSD wheels work great with the Losi tires. The bead seats perfectly.
Old 03-13-2008, 09:23 AM   #12
[HOONIGAN]
Wrecker's Avatar
It's about time!
Wrecker is offline   Reply With Quote
Old 03-13-2008, 09:26 AM   #13
looks good so far
Trimmy is offline   Reply With Quote
Old 03-13-2008, 09:49 AM   #14
Oh shit...
Rubbaneck is offline   Reply With Quote
Old 03-13-2008, 11:42 AM   #15
rbl
rbl's Avatar
looks good brad.
im digging the msd's
rbl is offline   Reply With Quote
Old 03-13-2008, 11:51 AM   #16
Pixel Pusher
Talking
Quote:
Originally Posted by BENDER View Post
.... Aluminum knuckles and axle C's are in the plans for this build too, but the stockers will work for now.
Quote:
Originally Posted by Harley0706 View Post
... Why the plastic knuckles though? I have seen quite a few of the steering arms let go, even when the drag link is switched to the bottom side.
Newb.....
Looks great Brad, looks like maybe you got the "full-monty" Axial treatment... wrenches and all.
Great tech here for everyone.
FreqEsKinz is offline   Reply With Quote
Old 03-13-2008, 11:58 AM   #17
Team drivers get all the goodies :-P It'll be interesting to hear your feedback on the heavy duty lockers. As long as they hold up better than the stock ones, I want a pair!
ecoli is offline   Reply With Quote
Old 03-13-2008, 11:59 AM   #18
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Quote:
Originally Posted by Freq E Tag View Post
Newb.....
Damn it anyway! I stopped reading at the "will be the same as the rear".
Harley is offline   Reply With Quote
Old 03-13-2008, 12:03 PM   #19
damn damn it now i have to build one
Thaks fro giving me a new excuse to empty my wallet
Great build ! ! ! !
I was wating for this just like when i built my SW2
chivas72 is offline   Reply With Quote
Old 03-13-2008, 12:17 PM   #20
I see the MSD's growing greatly in popularity. Is this because of the seat ability of the tires - explicitly Rock Claws? I know how fun bead locks can be to assemble, lol. Are these just easier and more efficient at beading the ring?
I have to ask as I am really wanting these wheels. I like them mainly for the looks but I have never bought an aftermarket pair. Sorry to hijack, but you would know!
O.C.D. is offline   Reply With Quote
You may not edit your posts
