#1 |
Think outside the Box
![]() Join Date: Feb 2006
June 2009 Update Crawler practically finished, Pics on PAGE 8 , Video of Engine sound and more on Page 9
Scale Super at Fordyce Trail CA. VIDEO In dash MP3 PLayer PROJECT FULL THROTTLE SCALE SUPER Comp Buggy Custom Super Rock Buggy 1 seater with MP3 player and 6 Watt Stereo, rock lights, DIG ! :-P This build uses drivetrain from Axial tranny ,Revo drive shafts to Losi 8 Aftershock diff to Losi Hyper 8 shafts to XTM Mad force steering knuckles, , The build Begins ! 6ch Mini scale Super Rock buggy Crawler: Something for the trails when I'm not Crawling in my Scale Toyota :-P ( in other words when others are broke Big thanks RCcrawler You guys ! for tech mods and feedback Yotachump- Chromoly Axial tranny outputs Robinson racing ax10 internal gears RCP -Beadlocks RPP - ESC MambaMax Holmes Hobbies, CC BEC FinishLine RC _Delrin Links TCS Crawler store , Motor BM16 Brushless BowTie-- for scale stickers Tower Hobbies, Wild Willy Driver, stickers, RC /Unlimited (LHS) for helping me find axle shafts that fit together Ebay for DX6 & non crawler hard to find parts Like the V8 Corvette Die cast motor I will try to Stuff under the Hood Think I bought something from Unimoger..? Hardware Suplliers: Olander- for Metric Hex head screws 3mm MMS - Standard Small Hex head bolts, 8-32 MSC for the Rod ends--NOT using. CHANGE to Losi 1/8 buggy rod ends with HPI 6.8 steel Balls Slinky Sam-- 1/4 D.O.M Tubing for Chassis McCaster- for 3/16 steel tube, Chassis- 1/4 DOM Tube rock buggy frame.- similar to SNIPER Picture below Suspension- 4 Link Shocks Max Big bores or other Droop front Team Losi Aftershock Diffs. scratch built steel locker, Axles - scratch built 5/8 Stainless Angled Solid Axles & knuckles . 12" wide wheel width 14.2" axle build in progress April 1st :-P Axle shafts- 14.5" wide OFNA Universals Hyper 8. 5" shafts 1/8 Knuckles - OFNA Jammin 1/8 Drive shafts- modified Revo . Tranny- Axial ax10 with 32pitch Kimbrough-66/14= 55.2:1 Motor- 55 Turn->overheats, Now Using BM16 Brushless ESC - MAMBA MAX. Battery- Dec 2008-Upgrading to 3S lipo 2250 30c. The Old batt. in pics is Cheap battery packs.com , custom split 4 pack 8 cell 4500. Lasts 1.1 hours With 5 servos & lights, Radio - 6 Channel Spectrum DX6, ebay Servos: Ch#1 ESC Speed control - Ch#2 Front Steering - 5955 . Ch#3 Rear steer - 7995 or Mini Actuator Ch#4 Rear DIG HS 225 servo Ch#5 Lights [/COLOR] 4 link 7/16 Delrin lower 3/8 Delrin upper links ROD ENDS Losi buggy with HPi 6.8 heat treated steel balls 18" wheel base 14" wide. Weight- loaded 11 lbs Tires- Proline Moab XL's . Rims- Narrowed to 2 1/8 Beadlocks - Custom machined Rock Rings with scale Hex bolts Foam, custom cut with rolling ground weight Scale Features - ROCk Lights: Super 100,000 mcd 10mm LED's X7, two headlights, one rear, 4 under chassis Rock lights 1/10 scale Recaro seats IPOD Stereo IPOD shuffle with mini Speakers PICTURES BELOW: 1- NEw Axle assembly, Team losi aftershock Diff 2- Steel Locker 3- 8 cell split battery, Elite 4500 from Cheap batterypacks $56. Drive time 1.5 hour ! 4 Narrowed Axial with beadlocks & Moab XL Last pic top view of frame Crawler Buggy STATS Ratio 6.79:1 Total 58.35:1 motor speed 10955 RPM max speed 4 MPH KV 987 motor Torque .48 Axle Torque 27.9 ft-lbs motor Power 743.7 watts 1 Horse Power Thunder Power 3s Lipo 2250 Aprox Weight 10 lbs
__________________
Spektrum DX6i Pistol 1/8 Scale Rock Buggy, MP3 6Watt Stereo Revo-Losi to 1/5 4wd 6s Last edited by toy4crawlin; 11-09-2009 at 09:33 AM. |
| Sponsored Links | |
#2 |
![]() Join Date: Feb 2007
lookin good so far, those axles are going to be hot.. cant wait to see the final build.
#3 |
Very unique idea on using the Losi Aftershock diffs!! It looks great so far!! Keep up the great work!!
__________________
Twin Force super Losi Mini Last edited by Toph; 06-19-2007 at 01:04 PM. |
#4 |
looks like its gonna be sick, got a ? tho, wats the hydro. suspension? and adjustable height servo?? just some fancy words to say that you'll be able to lift and lowerl the truck at a touch of a button??
#5 | |
Quote:
Can't wait to have a tube buggy Yep ! you got it. it will help with steep hill climbs and the COG Finished mocking up and Spot welding the rear axle yesterday :-P Interesting part of attaching the axles to the Diff in a Clean scale manner, hmmm rear axle 0* caster |
#6 |
thats gonna be sweet, them axles are beeef! and they look killer too. what kind of design you gunna go with on the tube frame.?
#7 | |
Quote:
I like Detail & unique so I'll find something then tweak it a bit here's a few I like, Sniper & well I'm really just liking Sniper, but if I were to build a 2.2 then it would be like the new single seat competition crawlers http://www.avalancheengineering.com/design.html http://www.avalancheengineering.com/sniperchassis2.htm Last edited by toy4crawlin; 04-04-2007 at 09:36 PM. |
#8 |
www.JPCUSTOMRCS.com
![]() Join Date: Sep 2005
Interesting idea on the Wheel weight. I'd like to hear an update after you get to run this thing. It's looken really good so far.
__________________
#9 |
Dirt Addict
![]() Join Date: Jan 2004
Location: Stumblin' thru the parking lot of an invisible 7-Eleven
Like the axle build....those will look great.
Keep the pics coming. Jay
__________________
"We have so many people who can't see a fat man standing beside a thin one without coming to the conclusion that the fat man got that way by taking advantage of the thin one!" - Ronald Reagan |
#10 |
the R2 s speed is shifted by a servo? i thought it was automatic......
__________________
no longer checks this forum, please e-mail if you have any questions. |
#11 |
Wow this is a pretty killer build. I love those axles.
__________________
[COLOR=seagreen]Spiraling. [/COLOR][COLOR=#00ff00][/COLOR] |
#12 |
Killer axel set up. I thought of going with SS but was worried of the weight. Looks good !
#13 | |
Quote:
I think aluminum is to soft. Keeping the weight at axle height and lower will give you great COG results Thanks for the axle props, I may have rushed the build on these though I was building them thinking I would just attached them with plates like all the other emaxx tube axles guys do. But I want something "Cleaner" than that. So back to design board, Question? : What do you guys think about attaching the Large 1" short tube to the Diff with Brazing or JB weld and then Insert the 2nd tube ring inside and fastening toghether with 3 small short button head screws ? so that the axle are removable. I cannot remove axle shafts from the outside ends because the dogbone end pin is slightly to large. I doubt the OFNA Jammin universals will break so I could Braze or JB weld the whole axle together ? Idea Drawing is with screws Left First Tube is 1" with smaller middle tube snug fit inside 1st tube Diff housing is ALUMINUM Tubes are steel Now that I think about it, I cannot Braze Aluminum with Steel. I would need to use a Metal bonder like JB weld for this joint Last edited by toy4crawlin; 08-19-2008 at 10:07 AM. |
#14 |
I was looking at the second picture say to myself that looks familiar then it click it was my axle picture. I still have a lot to do to mine. I sracpped the tubber chassis in favor of a stick like chassis.
__________________
[thread=59214][B]"Nameless" BMVii[/B][/thread] [thread=59567][B]"The Gaff" Maxx Build[/B][/thread] |
#15 | |
Quote:
I have yet to see a real stick chassis on a max driveline Very cool though Last edited by toy4crawlin; 04-06-2007 at 03:44 PM. |
#16 |
Build update: Wheel Locks
RC4Wd has a disconnect tranny to disconnect rear driveline so you can steer tighter. but right now it's only single speed, if they come out with a 2 speed version then I'll use it and add a Line lock for the rear brakes. If Not, then PLan B: Adding a driveshaft Brake for the Rear Driveshaft. and use the mechanics like the gas powered rc's use for brakes, like an old RC10Gt Thanks to the Maxx sticky thread http://www.rccrawler.com/forum/showthread.php?t=5371 I'll be using 5457 yoke for the rotor brake and the 5453 for the 5mm tranny shaft and the 5458 for the 8mm Losi Pinion shaft Humm... I ran out of radio channels LOL Servos: Ch#1 Throttle Ch#2 Front Steering - 5955 servo . Ch#3 Rear steer - either a 5955 or a 5995 Ch#4 Suspension- adjustable height servo 5955 Ch#5 Front Dig/ rear shaft lock, servo #? Ch#6 Tranny shift servo. stock servo Last edited by toy4crawlin; 05-15-2007 at 01:12 PM. |
#17 |
UPDATE:
Well this build will be much slower than I had hoped. My spending is out of hand, The last 4 months I have SPENT $3400.oo in RC Hobbies, My Toyota crawler, 2nd 4runner , and Tooling. But the plans on the axles are almost finalized. Build progress change: Change in Design on front axles Braze Aluminum sleeve on Diff cover and use bolts to connect stainless axle housing also this wheel width is looking like 16" + so I'm most likely going to use OFNA Hyper 8 Axle shafts that are only 5" long each wheel width should be around 14" Wheel base around 16.5 or 17" Another Mod: 6 LED Rock Lights , 2 flood offroad front lights & 1 interior light, New Parts: RC4WD 2 Speed tranny & Revo shafts for drive shafts 1/10 scale recaro seats
__________________
Spektrum DX6i Pistol 1/8 Scale Rock Buggy, MP3 6Watt Stereo Revo-Losi to 1/5 4wd 6s Last edited by toy4crawlin; 05-15-2007 at 12:49 PM. |
#18 |
damn, those axles look killer.
__________________
Brushless Hyper 7 TB EVO 4 AX10 Scaler BL Rusty |
#19 |
Lookig into Rod ends
Thanks to : Originally Posted by peej410 http://www1.mscdirect.com/CGI/NNSRIT...49458&PMT4NO=0 These are looking pretty cool 10/32 thread @ $2.86
__________________
Spektrum DX6i Pistol 1/8 Scale Rock Buggy, MP3 6Watt Stereo Revo-Losi to 1/5 4wd 6s |
#20 |
them rod ends are ridiculous!!
| Thread Tools | |
| Display Modes | |
