09-13-2011, 08:22 AM | #81 | |
Here's where it stands now... | |
09-13-2011, 08:55 AM | #82 |
| I drilled out the holes in the CVD to run the pins that came with my Ofna 17mm hexes and that seemed to work quite well. |
09-13-2011, 09:45 AM | #83 | |
http://www.amainhobbies.com/product_...rce=google_ext | |
09-13-2011, 11:18 AM | #84 |
If those are what fit in these hexes, then yes http://www.amainhobbies.com/product_...-Hard-Coated-2 |
09-13-2011, 12:33 PM | #85 |
The bottom of each of those two links lists the same cars for parts compatability, so I think those pins are a safe bet. |
09-13-2011, 02:46 PM | #86 |
Shelby...which hexes are on my axles?
09-13-2011, 07:34 PM | #87 |
I spent some time in the shop tonight to make one rear lower link just to see what shape it needs to be and go from there. This is my first attempt...I'm going to move the bend at the chassis end back towards the axle around 25mm which will provide more breakover...anyone else see any issues? I like the angle the shock has now a lot better than before and the link provides a better transition from chassis to axle...keeping the transmission protected. I'll get two more made up with the upper bend adjusted and hopefully some uppers to go with them while I'm at it. Getting one made up and having something to base the next ones on will make things move a lot faster. Last edited by ittybitty; 09-13-2011 at 07:36 PM. |
09-14-2011, 05:47 PM | #88 |
I got the rear lowers finished up...ended up making two new ones with the bend at the chassis end moved away which really helped out as you can see... I'm uploading some videos from this past weekend right now and I'll post them up as soon as they finish. |
09-14-2011, 06:24 PM | #89 |
I'm not sure what brand hexes they are. S links are what Krawlfreak runs, but those to look a little agressive of a bend. They clear everything ok?
09-14-2011, 07:26 PM | #90 |
Yeah they do...I either need to swap to different shocks or figure something out for limiting these...it's got too much travel as is. After I make the rear uppers with the hex bar it'll be finished for a little while...I'll spend some time driving it and then decide what needs to be tweaked from there. It just wasn't even close to being right with the arched links...
09-14-2011, 08:21 PM | #91 | |
09-14-2011, 08:47 PM | #92 |
No worries man! That wasn't a jab at you...it's probably just because I didn't have the tubes clocked yet...and the shocks I'm running just weren't right in that setup. Not to mention...I'm still figuring this super stuff out...and will be for a long time |
09-14-2011, 10:19 PM | #93 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
I would put a spring inside the shock in a droop setup to lower it down. The upper links need to be much closer to level.
09-14-2011, 11:50 PM | #94 |
In that pic above I had picked it up by the bottom of the chassis and sat it down so it wasn't sitting at normal ride height. Here's a shot of it if I "drop" it...where it settles... |
09-15-2011, 10:08 PM | #95 |
I made another set of lowers and a set of uppers. I left these lowers a little long...I'm right on 18" this time if not a little over with the idea being to see how it works like this and maybe add a little more bend to the chassis end of them for more clearance. I'll be testing this setup out this weekend and will adjust from there. I added some internal springs to the rear shocks today as well. |
09-15-2011, 10:13 PM | #96 |
One more shot from above showing the shape of the uppers... A video from last weekend before all of these changes |
09-15-2011, 11:22 PM | #97 |
That looks killer right there, nice work on the links. |
09-16-2011, 09:12 AM | #98 |
I wanna be Dave Join Date: Aug 2008 Location: Having fun again...
waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaay better!
09-16-2011, 09:19 AM | #99 |
09-16-2011, 09:23 AM | #100 |
18 |
