09-24-2013, 09:07 AM | #441 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
| Re: DLUX super build |
09-24-2013, 11:26 AM | #442 |
Quarry Creeper Join Date: Jul 2007 Location: Fort Mill, SC
congratulations. You put a TON into this rig. It must feel great to have something like that to show for it. You deserve it!
09-25-2013, 06:17 AM | #443 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
Very cool Erik, you definitely deserve this |
09-25-2013, 08:08 PM | #444 |
Rock Crawler Join Date: Mar 2009 Location: houston
Nice work... |
09-26-2013, 04:20 PM | #445 |
Congrats broman. But where's the Super Ultra? |
09-26-2013, 04:58 PM | #446 |
I would be hard pressed to build another chassis for this class. I couldnt be happier with this car in its current state.
09-27-2013, 01:03 PM | #447 |
Quarry Creeper Join Date: Feb 2011 Location: Germany
congrats |
09-28-2013, 09:48 AM | #448 |
Rock Stacker Join Date: Apr 2013 Location: San Diego
Gratz! it will always get podium!
01-21-2014, 08:39 AM | #449 |
An update on this build is long over due.... First up, I put my new knuckles on. I couldnt be happier. None of my cars could benefit from these knuckles as much as the super. My biggest issue with my RC4wd knuckles were the 12mm bearings. I milled out the knuckles for 14mm and that was a ton better but I still had to replace them every so often. So, lets fix the problem. 22mm bearings inside, 16mm out side. Problem solved..... forever.... Here is a cool shot of the bearings for the OFNA style shaft. 22mm, 16mm, 14mm, 12mm (stock bully) |
01-21-2014, 08:43 AM | #450 |
My hope was to build the Delrin knuckles and get a lighter setup all in one shot. Cast bully knuckle with 3 14mm bearings 14g 22mm bearing and 16mm bearing alone weigh 15g..... fail.... LOL With the knuckle the whole assembly weighed in at 31g. Not quite the weight I was looking for but well worth the cost IMO |
01-21-2014, 08:43 AM | #451 |
01-21-2014, 08:45 AM | #452 |
01-21-2014, 08:55 AM | #453 |
01-21-2014, 09:04 AM | #454 |
01-21-2014, 09:08 AM | #455 |
Finally, the thing I am most excited about! When I was doing my sway bar for my sporty, Stubs mentioned that he always thought it would be cool to put sway bars on a super. I instantly thought it was a great idea! I have always known that my super needs stiffer springs but I hate them for so many other reasons so this is perfect! Putting theory to practice, I put it on and its an instant success! My car has never, ever driven so well. Here is the sway bar that I am talking about. Its a universal setup so should work on most anything. All I did was simply drill a hole in my existing chassis and add the sway bar. It probably took me 20 min to install. |
01-23-2014, 11:04 AM | #456 |
Rock Crawler Join Date: Oct 2010 Location: Switzerland
Real Cool stuff you produce Eric But the Sway bar is exposed extrem on the super not?? is there no chance to mount it lower?? |
01-23-2014, 06:53 PM | #457 |
Yeah, I it is pretty high. It has not hurt me that I know of. Driving upside down is still ridiculous and I can drive all around with no effort. I cant mount the torsion bar any lower or it hits my upper links on compression. I could make the arms lower but I like them level with the ground at half travel. If I do see the height holding me back I will just make the end links shorter. |
01-24-2014, 05:36 AM | #458 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
I think it's awesome it worked out! I have wanted a sway bar on my super since I built it. It looks super cool too! Do you have one front and back or just on the back? |
01-24-2014, 09:50 PM | #459 |
Just on the back. As soon as I get some time I will try our idea and put one front and rear. |
02-24-2014, 08:45 AM | #460 |
