05-13-2018, 11:47 AM | #81 | |
Newbie Join Date: Apr 2017 Location: El Dorado
| Re: Crazy axles idea design Quote:
Fascinated by this project. I am not an engineer nor do I know if you can scale it down but, have you seen the Cyclo transmissions. https://m.youtube.com/watch?v=dYVPU47c9WA Sent from my iPhone using Tapatalk | |
05-14-2018, 08:44 PM | #82 | |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
I might have been wrong, 280 size. found here... Losi: 1/18 Xcelorin Sensored ESC/Motor Combo: MRC: Losi (LOSB9567) and maybe with a re design to accommodate the bolt patern and flipping the shaft you could go with something like this. https://www.amazon.com/LHI-920KV-Bru...ss+motor&psc=1 might be to big though. | |
05-15-2018, 10:54 AM | #83 | |
Newbie Join Date: Oct 2016 Location: NH
At only 30:1 reduction thats pushing 700 rpm on the wheels... say a 7in diameter wheel * pi * 700rpm = 15,000 ipm or about 20fps/13mph. Thats pretty fast for a crawler, and was only at 20k rpm... it could be closer to 30k rpm on lipo voltage. | |
05-15-2018, 11:03 AM | #84 | |
05-16-2018, 05:50 AM | #85 |
Pebble Pounder Join Date: Jan 2018 Location: Spain
My first idea was to use brushless motors but as you say it is difficult to find sensored ones with the right size and speed (KV) and sometimes they are overpriced as well... That is why I decided to go brushed way. About brushed motors that I have to test: - JRS-385RA/SA: 8500rpm at 7.4V (This one was too slow and low power, so not suitable) - Mabuchi RS380PH-3270: 10000rpm at 7.4V (Speed of this one is OK but limited power, with lower friction may be a good candidate) - SRC-380SA-3065-55: 13000rpm at 7.4V (Waiting to receive it and test...) And there is easy to find higher KV ones but that will require changing the gear ratio, that will mean as well to redesign the gearbox, not a big drama, just some hours on the CAD drawing and printer. I already have found different worm gears suitable for that modification that can allow use higher revs. motors: 1:60 worm gears 1:50 worm gears |
05-16-2018, 06:00 AM | #86 | ||
Thank you for all the inputs. Quote:
05-16-2018, 06:06 AM | #87 |
One question: What is the top speed of a crawler this kind? Have anyone checked that? I was guessing around 10 to 12Km/h (6-7.5mph), am I right? Last edited by gonper; 05-16-2018 at 07:31 AM. Reason: Tipo found |
05-16-2018, 09:18 AM | #88 | ||
45t 540 Brushed Sensored Brushless | ||
05-16-2018, 04:04 PM | #89 | |
I doubt that it will be possible to fit a 540 size motor this way... | |
05-16-2018, 04:22 PM | #90 |
BTW, I managed to cut and shut the tires. This is my first time I cut and shut tires so I decided to use the cheap tires I found on Alibaba that will allow me to learn how to do so and test the rig. I am very happy with the results. Then latter will make comp ones with other kind of tires. |
05-16-2018, 06:04 PM | #91 | |
That wheel looks great, too. | |
05-17-2018, 01:50 PM | #92 |
All parts printed. Now need to make the suspension and steering links. And wait for the motors to arrive |
05-18-2018, 01:19 PM | #93 |
does that say "version" 5? in the one case? also, lets get a sneak peak at that chassis! sorry if I was no help with finding motors. I thought for sure leopard rc had a 380 sensored motor. but when I was on their site, I could not locate one. |
05-18-2018, 05:17 PM | #94 | |
Thank you for your search, I am going to keep with the brushed option for now, I have a couple of ideas in order to make it work well. | |
05-18-2018, 05:42 PM | #95 |
Et voila Steering and suspension links. |
05-18-2018, 09:06 PM | #96 |
Wow, those look really, really sweet. So close to a full assembly.
05-19-2018, 02:07 AM | #97 |
And here we go, first assembly. Please let me know your thoughts. It looks like everything goes together quite well. May need to order some more screws sizes as some are short some others are long, and add some washers/seams here and there, not a big deal And wait for the motors to arrive that I hope they come next week. |
05-19-2018, 09:19 AM | #98 |
Amazing!!! What is you plan for battery placement/size? Are they in the wheel assemblies?
05-19-2018, 01:25 PM | #99 |
wow... that's probably going to be one of the lightest supers on the planet. I bet.. as it sits in the last picture it doesn't weigh more than 1.5 lb. |
05-19-2018, 02:13 PM | #100 |
| Re: Crazy axles idea design |
Crazy axles idea design - Similar Threads | ||||
Crazy idea? | nahuebsch82 | Axial Wraith | 18 | 03-23-2015 12:15 PM |
My Crazy Idea.... | Nootch | Tires and Wheels | 9 | 11-07-2009 12:00 AM |
Another crazy idea of mine | BJoe | Paint and Body | 7 | 01-11-2008 01:50 AM |
crazy idea | clodman666 | Chit Chat | 13 | 09-27-2006 12:26 AM |
crazy idea | reedpowell33 | General Crawlers | 3 | 12-15-2004 09:59 PM |
