Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya Bruiser
Thread: JHTreyIII's Bruiser Build
Old 03-29-2014, 09:32 PM   #181
Thanks for the compliment! They replace the entire hub and fit right over the stock bearing. They have a single lock nut like the original hub and then you screw on the "hub caps" if you can call them that. No modification to stock setup required and MUCH sturdier than RC4WD's hex conversion.
JHTreyIII is offline   Reply With Quote
Old 03-29-2014, 09:35 PM   #182
Thank you for the info. I wonder if they will fit the OG bruiser axles
2500 HD Tapatalk
rocpede is offline   Reply With Quote
Old 07-26-2014, 10:19 PM   #183
Default Re: JHTreyIII's Bruiser Build
hi verry nice build ....i have a bruiser too ..i have a transmision problem ..remember the 2 plastic gear in the trany ..i strip the second gear 1 time , after i put the slipper cluch and strip it again ...im not ruff whit it just driving and climbing ...anyway , do you find somewhere those platic gear in metal !!!! i just dont understand why in a 1200$ rig they put some plastic gear in the trany
boul69 is offline   Reply With Quote
Old 07-26-2014, 10:25 PM   #184
I haven't stripped those yet but I have some brass gears to replace them. I picked them up on eBay like a year ago and just haven't gotten around to replacing them. I bet that guy is still selling them. I guess brass is supposed to "give" a little. I also use one of the spring loaded servo savers to shift so it never forces the shift too hard. One of these days I'll swap them out, I just haven't touched this rig in ages.
Old 09-20-2015, 01:09 AM   #185
Was wondering if there is an update...
Old 09-21-2015, 08:23 AM   #186
No, I'm actually considering selling this rig since it never gets used.
JHTreyIII's Bruiser Build - Similar Threads
JHTreyIII's Class 1 Build - 1981 Chevy Pickup JHTreyIII 1.9 Scale Rigs 321 11-18-2015 09:52 AM
JHTreyIII's 'Big Metal Bitch' Wraith Build JHTreyIII Axial Wraith 141 04-18-2014 06:42 PM
JHTreyIII's Jeep Brute JHTreyIII 1.9 Scale Rigs 22 12-04-2012 12:58 PM
JHTreyIII's '72 Chevy C10 Build JHTreyIII Axial SCX-10 83 10-29-2012 05:05 PM
NIRC Polar Series JHTreyIII's Class 2 run johnnyh66 Scale Videos! 4 03-26-2012 01:38 PM
