03-07-2007, 03:53 PM | #61 |
Rock Crawler Join Date: May 2006 Location: Surrey, BC, Canada
Ok... I finally got my D.U.D. set-up done and installed... Just waitin' on the silicone to dry on the radio box so's I can mount the servo and switch... I made my version modular... I can unplug it and have it disabled as I have Deans on my motor leads so I made the D.U.D. in between some Deans... I've tested it dry with no wheels on the truck and it works perfectly... I hafta wait til Sunday to hit the rocks and see how good it really does... I'd also take pics, but, my cam don't have batteries right now.... Mebbe later on down the road I will...;) I have high hopes for this set-up as being something new on the rocks here that's never been done before... I'm the ground breaker, per se, in my group here... |
03-08-2007, 01:31 AM | #62 | |
Quarry Creeper Join Date: Mar 2006 Location: Australia
Either way, your cutting the power from the rear motor... and if you wire the front motor straight off that, then you have just cut power to both. If you look at the diagram on page one, when you press the switch, your isolating the rear motor, so even if you short it (while switch is pressed)... its not connected to the front | |
03-08-2007, 08:18 AM | #63 |
Seeing I run an EVX, I'm not concerned about the issues Tzi mentions... You could use a micro switch like I have... It has poles to be a "normally open" or "normally closed" and would fit a motor to motor parallel set-up... The switch is for forklifts that I got from a friend who used to repair them... I'm sure there's other variants of it out there... I have it in the "normally closed" configuration... When the servo horn turns and trips the switch, it has another position to be "normally open" which you could run the front motor off of, with a diode to keep the power from flowing back into the rear motor, when the dig is engaged as the middle pole would be energized from the rear motor feed... With nothing off it, it just does nothing in my rig... Mebbe I'll put a light on it or something to indicate dig in use... I really do need to take some pics of the setup... Last edited by DaViolentOne; 03-08-2007 at 09:38 AM. |
03-08-2007, 09:26 AM | #64 | |
Pebble Pounder Join Date: Feb 2007 Location: Monrovia
Actually, instead of going from switch to esc, you would go from the switch to the front motor. Make sure your esc hooks to the front motor first. | |
03-08-2007, 09:40 AM | #65 |
Here's a drawing of my set-up... And yes.. I know I suck at making drawings of things...;) And here's a variant for those with SuperChickens or MoPeds that use 1 pair of wires for the motors instead of 2... As you can see, the switch is useable in 2 configurations... It can be used to power both motors in the "normally closed" position and then just the front in the "normally open" position... When the switch is pressed, the feed will go from the top lug to the middle lug and then to the front motor on it's own... EDIT: I noticed just now that I have the diode on the wrong wire... It should be on the one that goes between the motors... Last edited by DaViolentOne; 03-10-2007 at 10:39 AM. |
03-11-2007, 07:59 PM | #66 |
Guess what guys? I did it on my super clod, and did the part where it shorts the rear motor out to turn it into a brake. It works great. If you guys need to know exactly how, i will draw up a diagram.
03-11-2007, 08:00 PM | #67 |
Yea that'd be cool... I found my rear axle free-wheels WAY too easy... If I can make it brake or even aid in slowing, that'd help a lot...
03-11-2007, 08:01 PM | #68 | |
03-11-2007, 08:16 PM | #69 | |
03-11-2007, 08:24 PM | #70 |
03-11-2007, 09:04 PM | #71 |
What? you guys were so anxious, now you cant say anything?
03-13-2007, 10:32 AM | #72 |
RCC Addict Join Date: Jun 2004 Location: SERCRC
| I finally got around to riggin' up a kill switch to the rear motor on my 2.2" Clod last weekend. I used parts I had laying around (a heavy duty toggle switch and a 645MG Hitec). Works awesome! Can't believe I waited so long to do this mod! Crappy camera phone pics.... |
03-13-2007, 10:43 AM | #73 |
It's looks like a D.U.D.! |
03-13-2007, 12:02 PM | #74 | |
The 645MG is overkill for a dig switch, but that's all I had at the house. I set the EPA's on my Agressor to keep from breaking the toggle off.:-P | |
03-15-2007, 09:22 PM | #75 |
Gotta love a DUD.... |
03-20-2007, 10:34 AM | #76 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
Thanks Chris Was sitting here getting ideas for my sons new truck(getting re-worked) and was looking at ideas on how to do it, instead of the brush crap and seeing how others did it without that type of switch.. Nice idea. Didn't think of just a basic toggle. already have plenty of those sitting around. |
03-20-2007, 11:41 AM | #77 | |
03-20-2007, 12:13 PM | #78 | |
03-20-2007, 12:34 PM | #79 | |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
03-20-2007, 01:54 PM | #80 |
RCC Addict Join Date: Aug 2005 Location: Akron
I'm glad to see this work! About a year ago when I had my clod crawler I was toying with this same concept. I sold the crawler before trying anything out. I still used the same concept on my tank! I used auto relays though to get the tracks to coordinate. Same basic principle though! Full skid steering from two servos |
