01-06-2009, 02:22 PM | #101 |
Rock Crawler Join Date: Jul 2008 Location: Williamston
All this does for me is to free wheel the rear and not lock it. It must be wireing it wrong. I n the mode you want I have burnt 3 switches! Confused!!!!!!! Tod |
01-06-2009, 03:19 PM | #102 |
I wanna be Dave Join Date: Dec 2005 Location: Tax Nation
Simple wiring... Wire motors like normal, now disconnect the negative (I wont get into it but, basically neg side usually carries less amps) connect switch between neg wire and motor so that when switch is not press everything works. You should now have dig when switch is pressed. The gearing/motor should be enough to lock most setups (unless you have an open diff) |
09-29-2009, 04:26 PM | #103 |
Quarry Creeper Join Date: Jan 2009 Location: North Wales, UK.
Subscribed! Great write up |
