Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: D.U.D. Rear Dig "Write up"
Old 12-20-2006, 01:27 AM   #1
Default D.U.D. Rear Dig "Write up"
D.U.D. Dig Write Up
Well there was a few guys wanting a write up on this. So here you go.
I got this idea from Unholy and Dezfan. D.U.D. = Dezfan Unholy Dig.
What I used for this set up. There is better and more expense stuff to use. But this is what I had laying around and used.
Radio Gear: TQ3
Front Servo: Tower Pro 955mg
Rear Servo: Traxxas 2055
Motors: Axiom 65T
Switch: Refrigerator light switch
You must use a switch that sends power while in the up position. Then when it’s hit by the 2nd servo it shuts the power off.
Step One: Mount your 2nd Servo and Switch on the rear axle. Don’t worry about the horn hitting the switch yet. You can adjust that when it’s all done. Just make sure they are close enough so they will make contact. I used one 3mm 1/2in bolt and a lock nut with a nylon insert to mount the switch. The Servo is mounted with Heavy Duty Velcro. The Velcro is from Radio Shack. It has a 20lb pull on it. So it can handle any servo your choose with ease. I then used a big Zip tie just to make sure it wasn’t going anywhere.
Step Two: Wire up your front motor to the Neg and Pos from your ESC. Your motor should have 4 post on it. So you will have one Neg and one Pos left. Now solder a Pos wire to the Pos post thats left and wire that to the rear motors Pos post.
Step Three: Solder a Neg wire to the last Neg post on the front motor and run it to the switch. The switch as 2 post in it. Just choose one and solder the other end of the Neg wire to it. Now solder a short piece to the other post on the switch and then to the rear motors neg’s post.
Step Four:
Now hit your 3rd channel button on your radio to test it. Adjust your horn so that it matches up with the button on the switch. I dipped the servo horn in plastic dip to give some grip so it wouldn’t slip off.
Here is a Diagram of how it should be wired up and few close ups of the rear servo and switch mounted up on my rig.
Old 12-20-2006, 03:05 AM   #2
cool wright up and now i'm just waiting on stuff to get here.
rich
rocpede is offline   Reply With Quote
Old 12-20-2006, 07:11 AM   #3
Nice write up,and i'm going to get a refregerator switch
traylor4x4 is offline   Reply With Quote
Old 12-20-2006, 10:40 AM   #4
Very good write up. Would it work with a super, or would the tires just drag the rear around?
roddyf is offline   Reply With Quote
Old 12-20-2006, 10:41 AM   #5
Super sized tires would provide too much leverage and the rear would just roll.
Unholy is offline   Reply With Quote
Old 12-20-2006, 10:50 AM   #6
dezfan's Avatar
Good write up R2J.
I was just to lazy to do it!
Couple shots of mine.
dezfan is offline   Reply With Quote
Old 12-20-2006, 11:13 AM   #7
Originally Posted by dezfan
Good write up R2J.
never too lazy to picwhore though!
Old 12-20-2006, 11:17 AM   #8
dezfan's Avatar
I invented Pic whoring!
Old 12-20-2006, 12:05 PM   #9
Interesting idea, I've been following this since you first came up with the switch thing but how does it work on the rocks or ever carpet where the tires have more traction.
rcracer is offline   Reply With Quote
Old 12-20-2006, 12:07 PM   #10
dezfan's Avatar
Works pretty good. I used it again in our comp this weekend and ended up w/ the win!
Old 12-20-2006, 12:08 PM   #11
I tighten the gear mesh on the rear axle slightly and it works well. It really comes down to how much traction the front gets.
Old 12-20-2006, 12:10 PM   #12
how many amp switch does it have to be?
Old 12-20-2006, 12:11 PM   #13
i have found that if you use a switch made for houshold current, the amp rating is insignificant, I use a mini-toggle only rated for 1amp at 120 volts and it doesn't even get warm.
Old 12-20-2006, 12:17 PM   #14
thanks, a perfect idea for my winter 2.2 build
Old 12-20-2006, 02:10 PM   #15
Originally Posted by run2jeepn
Nice writeup
........if I could just figure out how to wire my servo's to my ESC
Johnson420 is offline   Reply With Quote
Old 12-20-2006, 02:37 PM   #16
Originally Posted by Johnson420
Nice writeup
Magic crawler dust!
Cloak is offline   Reply With Quote
Old 12-20-2006, 04:07 PM   #17
You Clod guys come up with some crazy stuff.Nice info,good pictures too.
ColquittCustom405 is offline   Reply With Quote
Old 12-20-2006, 05:05 PM   #18
Nice write up, I'm sure i can do it now
doctorducttape is offline   Reply With Quote
Old 12-20-2006, 11:15 PM   #19
not a bad idea but i rather use a 4 channel and 2 esc
andrewmp6 is offline   Reply With Quote
Old 12-20-2006, 11:18 PM   #20
Thats what I'm doing with my Super. But for a $7 switch and about 10min of work it's a perfect upgrade for any 2.2 Clod. Thats why I posted this.
