01-18-2007, 08:57 PM | #41 |
Man thats alot of crap to put on a 2.2....But would be cool.
01-18-2007, 09:12 PM | #42 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
it would just be another switch... have your servo horn stright up... then throw your TQ3 switch one way to shut off the front and the other way for the rear |
01-18-2007, 10:02 PM | #43 |
Newbie Join Date: Jan 2007 Location: new jersey
Ordered up the parts I need so I can try this on my STICK. when it gets here..Cant wait |
01-30-2007, 09:29 PM | #44 |
As anyone tried it with front and rear yet?
02-14-2007, 07:04 AM | #45 |
Rock Stacker Join Date: Nov 2005 Location: Germany
| Thanks for the write up
That's a nice how-to. I did it to my Bronclod as well, just used a micro servo to save some space. Works good: It's a real cool and cheap mod. |
02-14-2007, 12:21 PM | #46 | |
RCC Addict Join Date: May 2006 Location: Roseville
02-15-2007, 10:45 AM | #47 |
| My Bronclod build
Well, you can look here for a write up of my build: Bronclod, 2nd try and some more detailed description of the frame here, its bronclods evil big brother: Monsterclod 1:6 with Nylint body and here are some more recent pictures: With my new Ford Ford F 100 Body: i just removed the rear steering and added the rear dig: rear lock out rear setup the original Bronco Bodied pic Rear dig close-up's: switch disengaged, rear motor ON switch engaged, rear motor OFF btw, the next organ donor is already wating for treatment: this time I think I 'll build a "pimp cane" sort of crawler... Last edited by yeti69; 02-15-2007 at 11:01 AM. |
02-16-2007, 06:20 PM | #48 |
Newbie Join Date: Jul 2006 Location: blue springs
I found a switch at radio shack hear is the link to this item http://www.radioshack.com/product/in...tId=2049719&cp Just got done setting up my 2.2 With dig works good
02-22-2007, 01:34 PM | #49 |
02-22-2007, 02:03 PM | #50 |
Rock Crawler Join Date: May 2006 Location: Surrey, BC, Canada
run2... Thanks for that vid... That puts more in favour for doin' D.U.D over 4WS in my mind... Less to deal with and works like a charm...
02-22-2007, 02:24 PM | #51 | |
02-22-2007, 02:32 PM | #52 |
I'm running a rather short chassis... The Gecko II is only 13 1/2" WB and I use rather small tires as well... The D.U.D. would do me rather well for the time being... I'm not really interested in dual ESC and 4WS yet... Maybe on a longer chassis or if I put bigger wheels on it... And the D.U.D. would be more cost effective at this time in my crawlers life... I just need a 3ch radio now...
02-22-2007, 02:58 PM | #53 |
Looks good man! Makes me want to convert my Super to a 2.2.
02-23-2007, 01:41 AM | #54 |
Quarry Creeper Join Date: Mar 2006 Location: Australia
I thought of this mid last year, but havent done it yet because i only have 3 chanels, and already have 4ws on my super. With all the knowlege on this board i am very suprised that nobody has suggested an idea to lock the motor by its own strength. ... when you turn a motor, it generates electricity. Try this...Grab your clod... remove the battery and spin one of the axles quickly..... the other one will move, running on the electricity generated by the axle in your hand. If you grab a spare wire (with aligator ends is easiest), and short across the motor (without battery in)... you will notice it is a lot harder to turn. So, by wiring the dig switch to remove the power and short the motor, you effectivly gain a free brake. If you use a microswitch such as this one, you will notice there are 3 poles on the switch. Wire up a dig as described in this thread, and make sure it works like it should. Then, add a wire to the positive on your motor, then solder that to the spare pole on the switch. now, when you trip the switch, not only does it disconnect the power from the esc... it now shorts across the + and - on the motor, providing resistance for your dig. instant brake |
02-23-2007, 06:56 AM | #55 |
Dirt Addict Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
Nice observation and an interesting idea. Wouldn't you have to make sure you break the ESC connection before you make the motor short connection? Jay |
02-23-2007, 07:26 AM | #56 | |
02-23-2007, 08:42 PM | #57 | |
02-24-2007, 02:26 AM | #58 |
Yes, Tzi, you are absolute right, but... The only reason not to do it is that I don't trust the microswitch, i know that technically it disconnects the 1 contact and then connects the other but I don't want to bust my esc... 'cos the switch is very inexeppensive, the ESC not. And, as run2... explained, it already works good without the shortcutted motor |
02-24-2007, 09:54 AM | #59 |
Far as I know, all you're doing with the switch is disconnecting the feed from the ESC... That won't do anything bad.. It'll send full power to the front motor but I can't see if frying anything out as long as yer not tryin' to dig while yer movin'...
03-05-2007, 01:45 PM | #60 |
| shortcut won't work
Hi, Tzi, I tried that one out, but there occurs a problem. If you use the 3rd contact to connect the "plus" line from the motor you end up with a short cut in the back AND the front motor, due to the parrallel connection of the 2 motors. So you have 2 shortcut motors and will end up with a ruined ESC, so it is good enough to disconnect the rear "minus" line. Markus |
