01-29-2006, 06:32 AM | #81 |
Hell yeah that's a gun rack back thur! With a name like Barnyard Buster, would you expect anything less? |
01-29-2006, 08:48 AM | #82 |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
I skimed around the thread and could find this question, Why are you running TLT shocks? How do they work? Soft/Hard? Frame looks sick and the gun rack is cool "Free to bear arms" I like it.
01-29-2006, 09:44 AM | #83 | |
RCC Addict Join Date: Nov 2004 Location: Redding, CA
Chassis and truck look great. | |
01-29-2006, 10:09 AM | #84 |
Why TLT shocks? Mostly because they came with the kit, and the springs seem about right for this rig. They have a nice look, but they're not the best performing shocks by any stretch of the imagination. Not very smooth, limited travel and no spring selection whatsoever. It happens that the springs they come with work okay, so I left 'em on there. If you want better performance, a set of Pede fronts (the shorter ones) with Mini LST springs (green front, silver rear) works very well. You have to watch frame clearance in the back, though, with fatter shocks. Even the TLT shocks rub the frame unless they're mounted inboard on the axle like the pic below. Also, you'll want to single-narrow the backside of your rims so they don't hit the front links at full lock, but you'll probably do that anyway. |
01-29-2006, 11:45 AM | #85 |
Quarry Creeper Join Date: Aug 2005 Location: On the yellow dummy dumper
that thing is incredible! i really like the gun rack, where did you get it from??
01-29-2006, 01:37 PM | #86 |
The gun rack is on an Autographics sticker sheet, along with the steer horns and some other rednecky stuff. It seemed fittin' |
01-29-2006, 01:59 PM | #87 |
Looks great Stu. I hope you're bringing that down with ya!
01-29-2006, 03:15 PM | #88 |
Quarry Creeper Join Date: Jan 2005 Location: uk s,wales blackwood
reguarding the tyres hitting the front links couldnt you move the bottom links inboard on the axle and chassis
01-29-2006, 03:19 PM | #89 |
That's a possibility. But I wanted to narrow the wheels anyway And you bet it'll make the trip in April. I show this thing off every chance I get. |
01-29-2006, 04:45 PM | #90 |
Pebble Pounder Join Date: Dec 2005 Location: Albuquerque
that is swwwwwwwweeeeeeeettttttt dude i like it especially the gun rack
01-30-2006, 08:19 AM | #91 |
After sobering up a little, I can tweak the front pinion angle a bit. For this initial build, I just pulled the parts off the development mule and put them on the prototype without making any adjustments. Since the mule was made from .032 sheet and the proto is 1/4 inch, the triangulation geometry's off a little, resulting in a droopy pinion. Make the top links an eighth longer and the problem will go away. Since they're Jato turnbuckles I can do it in about five minutes. And it's still nowhere near as steep as a Bruiser's. |
01-30-2006, 09:58 AM | #92 |
Looks nice and I love the gun rack stickers! |
01-30-2006, 11:45 AM | #93 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
Looks like the back window of my Rover.
01-30-2006, 12:23 PM | #94 | |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
01-30-2006, 01:33 PM | #95 |
Looks awesome Goat, can't wait to see a few of these built up.
01-30-2006, 02:56 PM | #96 |
PayPal barnyardbuster@gmail.com and start the ball rolling right now |
01-31-2006, 11:20 PM | #97 |
| BB+SW2= alphabet soup?
Thought I'd try Bender's SW2 link mounts on the Buster chassis, and I'm glad I did. This thing deserves a better link mount than a homebrew hackjob, and the SW2 fits right in with all the shiny aluminum I must be that lucky or that good, I didn't have to change the upper link mounts on the frame like I thought I would. These fit, no extra holes required. The Maxx shocks and Mini LST springs hold up the truck better than the TLT shocks & springs, and the pimp lean is gone. Production chassis will be cut away in the rear for shock clearance. |
01-31-2006, 11:22 PM | #98 |
Are you going to have more mounting holes on the production version?
01-31-2006, 11:26 PM | #99 |
Wasn't planning on it. I prefer a clean look, and you can play with the axle end of the link to make your length adjustments. I may add another shock mount in front if you want to jack it way up, but I'm thinking not.
02-01-2006, 09:23 AM | #100 |
Looking Schweet Goat!
