02-16-2006, 03:49 PM | #121 |
Rock Crawler Join Date: Sep 2004 Location: Santa Rosa
Here is the link on Tower for the suspension stays: http://www2.towerhobbies.com/cgi-bin...&I=LXGKG9&P=PU They are only listed with the parts for the Rock Buster. Took awhile to find it again but I knew it was there. Here is the link for the Rock Buster parts also on Tower: http://www2.towerhobbies.com/cgi-bin...=TAMC0201&P=PU |
02-16-2006, 04:31 PM | #122 | |
And if you think that's a dodgy steering setup, look at what comes in the TLT kit: that 1-1/4 inch aluminum post they give you is supposed to go on the steering knuckle! (Max Climber manual pg 25) | |
02-16-2006, 10:07 PM | #123 |
Looks like an old 1:1 Chevy on a 70's Blazer frame project! I love it! |
02-17-2006, 06:04 AM | #124 | |
Rock Crawler Join Date: Jan 2006 Location: Nebiru, OuterSpace
thanks a TON!!! very helpful!!! | |
02-22-2006, 05:53 PM | #125 |
Played around with shock mounting locations a bit, trying to get the ride height and CG down a little bit while maintaining travel and artic. It's 70% droop, still some compression to it, but I managed to drop the ride height by a good half inch so it's a bit more stable out there on the rockpile. For those of you building one (both of ya) here's what I did: Move the rear shocks inboard, and onto the front of the crossmember to give them some more angle. This also means you won't have to hack the framerails for clearance. Move the front shocks down beside the lower link mounts, and use the single link mounts rather than the double mounts to avoid hitting the spring cups. The skidplate drags a little now, but that's what it's there for. Last edited by microgoat; 02-22-2006 at 05:56 PM. |
02-22-2006, 06:01 PM | #126 |
With the shocks in that location, it looks more like a full scale mounting location. |
02-22-2006, 09:08 PM | #127 |
wow, I bet that thing handles like a truck should! Put a faster motor on it! Gear it down with more power!!
02-22-2006, 09:41 PM | #128 |
Rock Crawler Join Date: Nov 2005 Location: dallas
NICE!!!it looks like youre getting that chassis all tuned up
02-23-2006, 10:05 AM | #129 |
Goat, I like that setup much better, looks like you have really got a handle on it now, almost comp worthy. |
02-23-2006, 01:40 PM | #130 |
It's almost comp worthy. I run it back-to-back with my Deep Vee chassis (which will be making its Colorado debut this spring) and it's not too far behind once I swap on the weighted Moabs. The high battery position hurts it some, and the servo on the chassis does limit both artic and overall travel, so it's not a true comp truck, but it's not a shelf queen either. A good TVP design will own it every time because it's so damned heavy, but I never intended it as a comp truck. It's a capable scaler, and a pretty good one now. Anybody want one? I've gotten a couple e-mails from the other forums it's been on; almost enough to do a run. |
02-28-2006, 05:47 PM | #131 |
I made up a set of new wheels for it (details in the wheel & tire forum) that I think look a lot more scale, like 44's on 15's. Since the TLT was designed around 1.9 inch tires anyway, and the Dawgs are a tight fit on 2.2's, well, why not...
02-28-2006, 08:04 PM | #132 |
tasty! Got any sheets of black plastic or metal to hide parts? That would kick ***.
08-15-2006, 04:27 PM | #133 |
time to bring this thread back from the dusty shelf it was on. |
08-15-2006, 07:06 PM | #134 |
The thread may be on a dusty shelf, but OG's been out on the trail. Still my favorite rig.
08-15-2006, 07:58 PM | #135 |
RCC Addict Join Date: May 2006 Location: Roseville
Wow goat... Excellent rig, one of my favorites. Glad I asked about it. |
