Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: Project "RAMROD"
Old 06-01-2006, 09:00 AM   #21
Originally Posted by run2jeepn
Well here are my 2.2 Red Rocks. You can see how much ground clearance they will give. I haven't got my Wheels in yet.
Here is a pic showing the Stock TLT Spur gear and Pinion on the Stealth tranny. I don't know if it's low enough, but if it is. It may help out a few others and save a few bucks.
It seems to be a Spur 83T and the Pinion 24T
I run a stealth in mine.......I run a 13T pinion and an 83 T spur ......I radiused the back side of the stealth to get the motor closer so I could use a smaller pinion. good work.
rockwerks is offline   Reply With Quote
Old 06-01-2006, 09:33 AM   #22
Originally Posted by dezfan
Be careful w/ the Tamiya gear. I think (not 100% sure) it is a metric 48 pitch and standard 48 pitch gears won't work w/ it. If it is standard 48 pitch, then great find!
rockwerks, have any pics of your mod to the Stealth?
What does the pitch of the gears have to do if you use the stock TLT Spur gear and the stock TLT Pinion gear? What is the pitch?
Old 06-01-2006, 10:10 AM   #23
The stock TLT pinion will work fine. But if it a 24 tooth, then it will be to big to use for crawling. You will be geared a little to high. Although not to bad w/ the 83 spur and 65t motor.
But if you do try to switch to a different smaller pinion and the spur is a metric gear, then a standard gear won't mesh w/ it.
See the teeth on the stock Stealth tranny you have? That is 32 pitch. The gears we use are 48 pitch and have a smaller tooth but give you more adjustability w/ your gearing. And 64 pitch has even finer teeth and even better gear ratio adjustability.
stealth GT trans.........32 pitch so you are correct.
Old 06-01-2006, 10:16 AM   #24
If it's not low enough. I ordered a Robinson Racing Pinion Gear 48P 18T and a Associated Stealth Spur Gear 48P 81T last week. Also I was going to order Servo savers and I found that the TLT kit came with 2 of them. so that saved me a few bucks.
Old 06-01-2006, 11:39 AM   #25
Man I just found 12T-24T (48P) that are Metric at TowerHobbies. I could have just bought a different Pinion and kept the stock Spur gear. The Spur gear that comes with the Stock TLT-1 Kit is just small enough for Revo Shafts to fit. You couldn't fit any bigger Spur gear on there. I mean I only saved $3. I may just buy a 12T Metric Pinion So I will have a 83T Metric Spur, 81T Standard Spur, 18T Standard Pinion, 24T Metric Pinion and a 12T Metric Pinion.
Old 06-01-2006, 12:59 PM   #26
W/ the 83 TLT spur a 12T metric pinion might be to small. It might not engage the spur even w the motor as far forward as it will go.
You mean that the pinion would be to short to reach?
Old 06-02-2006, 05:36 AM   #27
Well I got my steering links on the axles done for now. Moved them on top of the axles and put the brake line over the tierod. I can't do the top one yet intill I get my Servo's in the mail and mounted. Just got my e-mail from TowerHobbies.com my Jeep Body, Wheels, and Tranny parts are on there way. I can't start on the tube chassis till the Body gets here either.
Old 06-02-2006, 02:43 PM   #28
Well I just check usps.com and found out my wheels, Spur gear and Body are at home waiting for me. SWEET
Old 06-02-2006, 03:14 PM   #29
that first pic should have a honda under the tire of your jeep not american car
R/C_rock_rebel is offline   Reply With Quote
Old 06-02-2006, 04:07 PM   #30
I would start working with some of the new parts, but I have 2 SoftBall games tonight.
Old 06-02-2006, 04:21 PM   #31
Well I got the tires on the rims. Not Glued. The wheels need to be narrowed. I will also need to widen my axles too. I will be going with a wheelbase of 13.5 to 15in....?
Old 06-03-2006, 12:43 PM   #32
wat happened to that supercoupe?
Pegasix is offline   Reply With Quote
Old 06-03-2006, 12:46 PM   #33
It went to the Junkyard. After I took a few things off for my Jeep.
Old 06-05-2006, 12:14 PM   #34
Well I bought the wrong rods for brazing. I have to return them and buy the right ones. I got most of the center cage bent. Well here are the pics. I just have them taped in place for now.
Old 06-05-2006, 11:30 PM   #35
Well I got my Tranny parts in and my pinion. I also missed a package from HONG KONG. I hope it's my MOPED, but I also ordered TLT Bearing kit too. I will be buying the right stuff to put my tuber together with. I should be getting everthing rolling along very soon.
Old 06-06-2006, 08:59 AM   #36
Well I started to swap all my tranny stuff from my RC10GT to the B4 case. I just found out the gears don't swap. The Diff gear is way to big. The two little gears and all the bearings swap fine it's just the Idler gear that won't fit.
Old 06-06-2006, 10:57 AM   #37
Well here is the picture of the RC10GT gear with the new B4 Tranny case.
The gear is as far is it will go. All the other gears switch just fine. I am holding the RC10GT gear in the new tranny case. In the back ground is the RC10GT case still with the gears.
Old 06-06-2006, 11:01 AM   #38
On a lighter note I got my MOPED ESC V16R nad my Axles bearings in today. All that is left to come in is my Servo's. Should be here any time.
Old 06-06-2006, 12:35 PM   #39
Here is then one I needed. I guess I just bought the wrong part. I'll find that thread I got my info from and fix it. I'm sending mine back and exchanging it for this one. I ordered a motor plate, but I don't think it will work either. I guess I'll want to see what I can do with what I got.
http://www2.towerhobbies.com/cgi-bin...L=++&search=Go
#LXEAC0
The old motor mount won't work either.
Old 06-06-2006, 03:06 PM   #40
I have put together a TLT-1 to Rock Cralwer Help book. There is over 100 pages of how to do and what parts to use. Plus a lot of pictures. I have dug up everything I could find. And as soon as I'm done with this project. It's amazing of all the research I have done I still haven't figured everything out by far.
