06-16-2009, 08:56 AM | #21 | |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
I'm running the springs compressed more on one side to make up for weight imbalance and/or slight differences in the shocks. I basically set it up so that when I compress the suspension by hand, both shocks respond the same and settle to the same height. Doing this seemed to make the rig a lot more predictable when I hammer it on long vertical climbs. | |
06-16-2009, 09:28 AM | #22 |
Newbie Join Date: Jun 2008 Location: Socal
I have run with Jake and his rig it's works as good as he said, dont hurt Jake was driving. great job Jake, see you Sat good luck as if you need it.
06-16-2009, 09:29 AM | #23 | |
Rock Crawler Join Date: Apr 2009 Location: NorCal
06-16-2009, 09:39 AM | #24 |
RCC Addict Join Date: Feb 2007 Location: Chucking rocks at your little truck!
Look's great man. Do you have any pics of the battery tray without the battery on it? Also what is your belly clearance at ride height and full droop. Thanks, keep up the good work. |
06-16-2009, 10:23 AM | #25 |
Quarry Creeper Join Date: Jan 2009 Location: El Cajon San Diego
| I can't speak for Jake, but with my 17.5, I just switched from 14t to 12t. I loose wheel speed, but it gives me better torque and is more forgiving on the motor when in binds and doesn't run as hot.
06-16-2009, 11:48 PM | #26 | |
With this rig, I prefer a slower driving style anyway. Wheelspeed can only get you so far, but driving technique can take you a long ways. Still, there are some places where it doesn't hurt to have extra power | |
06-17-2009, 12:30 AM | #27 |
Thanks for the help. I too like to take it slow and never really understood the need for speed,,untill I got a little and saw how in some places it's the ONLY way to get over something,,,I want it all I guess. |
06-17-2009, 12:29 PM | #28 | |
RCC Addict Join Date: Feb 2005 Location: Minneapolis
Doesn't running the upper links higher on the chassis make the chassis reaction a little firmer? | |
06-17-2009, 01:56 PM | #29 |
| There's a few things to factor in. What kind of springs you are using and their angle. Laying them down should soften them up.
06-17-2009, 02:04 PM | #30 | |
Raising the upper links changes the squat/anti-squat in the rear and dive/anti-dive in the front. It should also eliminate some chassis roll. P1choco is right though, shock angles and springs and oil play a big part in this too | |
06-17-2009, 03:51 PM | #31 |
RCC Addict Join Date: Jan 2009 Location: O.C
| Quote: |
06-17-2009, 05:19 PM | #32 |
06-17-2009, 10:36 PM | #33 |
| I'm not positive on the rate, but the soft rate feels really close to a Gray Losi spring (1.6), and the stiffer rate feels about like a Losi Yellow(2.0). Basically, its softer then a Losi white spring for the first half, then stiffer in the second half. I did a little more experimenting today, and put Losi 45wt. oil in both the front and rear shocks. With my front shocks layed down all the way, and the rears in the middle hole on the arm, the rig was awesome. Super predictable, smooth, and planted everywhere. The suspension reacts pretty slowly with the 45wt, but I didn't feel that it was too slow anywhere. Again, this was on some pretty grippy granite, so I didn't need to use a ton of wheelspeed. I would probably stick with the lighter oil if I was going to run on slippery stuff. I'm going back out tomorrow, so I'll grab some action pics and maybe a little video |
06-17-2009, 11:19 PM | #34 |
What's your ride height with the changes to the shocks?
06-17-2009, 11:30 PM | #35 |
no talent hack Join Date: Feb 2007 Location: Redwood City
great job on this jake! i know this is making the lives of alot of losi owners easier
06-18-2009, 06:57 AM | #36 |
06-18-2009, 07:27 PM | #37 |
RCC Addict Join Date: Aug 2007 Location: Rohnert Park
Del Monte: What's your cure for the lower links at the chassis popping off all the time? I've heard about the o-ring trick, but I'd rather find a solution that does not bind the suspension at all.
06-18-2009, 07:33 PM | #38 |
Slip a washer on that is larger than the ball. If it pops off the washer holds the link in place. I had to do this with the Losi XXX-T.
06-18-2009, 08:26 PM | #39 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
06-22-2009, 03:06 PM | #40 |
| I've really slowed down my driving style with this rig compared to my TLT's. With a little weight in the tires and some shock tuning, I feel that this rig can crawl just about anything that my old rig had to power up. Compared to my old Banana TLT rigs, my Losi has a ton more suspension travel. I can really move slowly and let the rig soak up everything. My ride height is still between 2 1/4 and 2 1/2", so I can still climb and sidehill great. I've been running full standard foams with a little trimmed off the inside diameter, and this really helped keep the tires from folding in the off-camber stuff. My original Top Banana rigs sidehilled a little better because they were so low, but the Losi is tons better all around. I'll get some good comparison videos up when I have a chance to get out and shoot video |
