08-09-2010, 04:25 PM | #241 |
Rock Crawler Join Date: Oct 2008 Location: Italy
08-11-2010, 04:30 PM | #242 |
These tires worked amazing, i pulled so many lines that my rovers can't do and so many other lines they stuck better than the rovers. Only problems i had with them was there's a couple of lines that need less traction and just let your crawler slide down and these stuck to the rock and caused the crawler to roll over. I also noticed on a v shape ledge with an major undercut about 10 inch tall these i don't know why but they didn't want to go down smoothly like my rovers did, i could make that line every time with my rovers i tried that line 5 times with the boss claws and i only made it once. But hey i'd rather take a roll over from going down hill than not finishing a course because you can't make it up a hill. Oh i forgot my foam setup. rears i'm running stock foam on proline 8 shooters and 1 wrap of weight (its wide piece, not sure how much one wrap weighs) and the fronts are also mounted on proline 8 shotters with 2 wraps of weight and proline oversized memory foam with 1/2" of rover foam on each side of it. My car weighs alot and i think it could still use some more sidewall support but i works great right now so i may leave it unless i see the side walls are giving me serious issues.
08-11-2010, 06:43 PM | #243 |
Quarry Creeper Join Date: Apr 2009 Location: Lincoln
I just ordered some of these, where is a good starting point for a sub 5 lbs berg for foams. Maybe stock sedona foams for the front and stock losi pinks in the rear. Thanks TY
08-11-2010, 08:07 PM | #244 | |
Sub 5lb berg? That's a light berg! probably the same setup i'm gonna try on my near 5 lb sss-R. Single stage mems up front and Nova DD's out back | |
08-11-2010, 08:32 PM | #245 |
Gold Star Baby! Join Date: Feb 2009 Location: Arizona
Well I guess its my turn to reveal my Claw set up..actually I have been watching a certain someone in our club run these with a light rig..he liked them then didnt like them..we worked out a trade and I ended up with a brand new pair..Lets just say..WOW !!!!!! My crawler weighs 6.2 lbs-WheelWorks wheels and of course a V3 Beetlejuice chassis... set up as follows: rear stock Losi claw foam..pink I think and now for the kicker..Frt is a special foam I have been using for some time..pool noodle foam.. with stock rover foam..it gives me the right density that I preferr.. I will be doing further testing...but as for now I am impressed with my set up..I also would like to thank everyone in this thread for there input..I have read this thread a couple times..even tho I was sure my set up was going to work..all the info helped me make it happen.. Marc |
08-11-2010, 10:46 PM | #246 |
'08 2.2 National Champ Join Date: Nov 2006 Location: UTRCRC
My set showed up today. I got them mounted up following suggestions with some tweaks of my own. I think I found my new favorite tire I only have a bit of front yard crawling but even with slightly wet tires I was making it up lines that I was struggling on with other tires. |
08-11-2010, 11:53 PM | #247 | |
Rock Crawler Join Date: Jan 2009 Location: San Gabriel, Crawlerfornia.
08-11-2010, 11:58 PM | #248 |
08-12-2010, 01:48 AM | #249 |
How do they perform with wide wheels?? I was thinking of running my boss claws with stock width axial wheels.
08-12-2010, 07:51 AM | #250 |
08-12-2010, 09:32 AM | #251 |
| I'm running mine on proline 8 shooters, i'm not sure of the width but they seem to run good, they run more lines than my rovers do. They may run better with narrower wheels but i don't have any so i don't know.
08-12-2010, 12:39 PM | #252 |
I have a few more packs though them now. I'm very impressed, especially considering there was wet sand all over them. |
08-12-2010, 12:44 PM | #253 |
Rock Crawler Join Date: Sep 2008 Location: Utah
Looks great Zach, I dig how smooth they are, no bouncing like a typically lugged tire.
08-12-2010, 12:44 PM | #254 | |
RCC Addict Join Date: Aug 2007 Location: Seattle
My new favorite crawling pic. Thanks! I'm going stir crazy waiting on my set. Bought used and there taking a bit to get here but the plan is trying a super soft setup on my fronts with UCW's. | |
08-12-2010, 02:15 PM | #255 |
08-13-2010, 03:30 PM | #256 |
At what point of wear do you think these are done? The pins on mine are getting pretty hairy and fuzzy looking. It could have been the kind of rock I was on the last couple of times out, but i coudln't get the tires to perform as well as what they have been. I run some toe in, and I can definitely see more wear on the outside half of each front tire too. |
08-13-2010, 03:57 PM | #257 | |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
08-13-2010, 04:17 PM | #258 | |
Got any pics? | |
08-14-2010, 08:53 PM | #259 |
Frustrating.. I told a friend that these were the next best thing since sliced rovers and we have yet to mount one. Two brands of wheels, foams narrowed and stock width, two- four hands, trimmed flashing, rubber bands, dusty tire, washed tire, and nothing is working. I've build wheels just fine before these. It's like the design relies on just the ring pinching against the rim.. They just pull out. There's about 5 hours into these and only the face of a wheel can be mounted and it's still not perfect. Sounds like he's putting his up for sale but this worries me that I won't get them on my rims. Sorry to vent here but I've read and re-read this and team drivers threads for tips and so far any style isn't helping us in our situation. Beadlocks tried so far are stock lcc's and some Tense that were narrowed to .7 |
08-14-2010, 10:05 PM | #260 |
Quarry Creeper Join Date: Mar 2010 Location: Central NC
I had some trouble mounting mine, I run them on stock LNC wheels, but I had a buddy give me a hand and we got them on without too much trouble. Think it took us about an hour to get them mounted but getting the first one done was the hardest. Once we figured out a technique, the other 3 went on alot smoother. Try putting a roll of electrical tape or another wheel under the wheel your trying to mount the tire on. Then have a buddy push down on the tire while you mount the beadlock ring. The Boss Claws do take a bit more patience to get mounted but it's doable so keep at it. |
