07-28-2010, 09:32 AM | #181 | |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
07-28-2010, 09:33 AM | #182 |
07-28-2010, 09:50 AM | #183 |
Newbie Join Date: May 2010 Location: Nevada County
Thx Del Monte, I actually thought about the support issue and added a full wrap of 4g audio power wire around the inside of the fronts last night. This equals about the same volume and shape of maybe 2.25 wraps of weights and adds 3oz. So with that, I took out 3 slugs from the rim, so 6 oz total per rim. Still felt similar as before, but i talked with a good buddy that owns a machine shop. Im thinking about having him mill all 4 rims down to maybe .9", somewhere in between what i have now, and the narrow .7" you and a lot others are running. You think thats a good plan,? mill them more, keep them the same? I wish i could buy 2 setups, but good rims are just a little too pricey. I have some Rock Claw foams laying around but i cut wedges out to soften them up awhile ago.
07-28-2010, 04:44 PM | #184 |
Rock Crawler Join Date: Jan 2009 Location: San Gabriel, Crawlerfornia.
Do any of u have pics?? Lets see some pics for us to enjoy.I should be getting mine in a couple of days to go along with my new build.
07-28-2010, 07:48 PM | #185 |
Rock Crawler Join Date: Jul 2010 Location: VOLS!
Took my boss claws for there first drive today. They worked great! I was able to go anywhere i could get the truck to point. This was on rocks that we just pull out of the woods to start making a course out of and they had not been drove on yet, still had dirt and moss all over. The set up i was running: truck rtr 5.58lbs front wheels total 13.6oz rear wheels total 9.3oz On the rear i stayed with the pink foams On the front i used pink foams plus i cut my stock rock crawler gray foams in half and add one half to the out side of each pink foam. having to much fun only took a couple pics. |
07-28-2010, 08:38 PM | #186 |
Think I got them dialed in finally. They seem to work best for me when the fronts are a little on the hard side. Not quite stock foam hard... but harder than NovaDD foam. They are a mix of proline dual outer memory foam wrapped over NovaDD inner foam. They performed the best yet today at our weekly comp/GTG. |
07-28-2010, 09:00 PM | #187 |
Rock Stacker Join Date: Mar 2009 Location: St louis
| losi boss claws
Has anyone tried the stock Sedona foams in these tires yet.I just picked a set and thought i would try the sedonas ,ill post tomorrow night how it went.
07-28-2010, 09:28 PM | #188 | |
Rock Crawler Join Date: Sep 2008 Location: Utah
07-29-2010, 10:25 AM | #189 |
07-29-2010, 01:53 PM | #190 |
lol yeah I am right there with ya!
07-30-2010, 01:22 AM | #191 |
Quarry Creeper Join Date: Dec 2008 Location: Ramona
does anyone know anything about these slw adapters? i got them but the holes in center is way too big??? |
07-30-2010, 01:24 AM | #192 |
Rock Crawler Join Date: Nov 2008 Location: lakeside
post up a pic so we can see it.
07-30-2010, 01:36 AM | #193 |
here it is..
07-30-2010, 01:40 AM | #194 |
on the hub/hex.. hard to tell but try.
07-30-2010, 07:56 AM | #195 |
Rock Crawler Join Date: Dec 2008 Location: With the ATL Crawlers
Mines the same way. It's b/c those are for the super 300 axles. VP is now selling the adapters for Losi's
07-30-2010, 08:25 AM | #196 | |
RCC Addict Join Date: Feb 2007 Location: Chucking rocks at your little truck!
This is for the SLW series. http://www.vanquishproducts.com/vp-slw-hex-hubs.html Everyone has plenty of options. I run the DH 585 up front fully loaded and rear SLW with 600. I like it a bit wider then stock for stability while jumping . | |
08-01-2010, 08:46 PM | #197 |
| Oversize memory foam doing work yo. |
08-02-2010, 02:22 AM | #198 |
ok thanks guys, i talked to corey from rpp, he is willing replace them for losi adapters.. thanks again. im just bummed that the xcelorin esc lit the capacitor on fire after only running one battery? after i got the second esc from horzion.. sorry i know this is not electronic forms.. im getting distrusted with it.
08-02-2010, 07:28 AM | #199 |
08-02-2010, 02:50 PM | #200 |
| It's a two stage regular foam, however I don't know exactly what they are. They were a present. Very close in feel to a regular Losi grey foam from a Rock Claw, surrounded with a much softer outer white foam, resembling something from Proline maybe. Together they more or less fit inside the Boss Claw with minimal bulge action. Squeezing them from the outside they are fast reacting and somewhat soft. Squeezing them from the sidewall near the bead they are about twice as stiff. They are able to support the truck on a diagonal, whereas the fronts almost crush down to the wheel. |
