01-10-2014, 05:12 PM | #61 |
Quarry Creeper Join Date: Apr 2006 Location: SLC, Utah
Mine are the V2. The difference is the accents cut into the face. The v1 does not have them
01-10-2014, 05:44 PM | #62 |
Rock Stacker Join Date: Dec 2013 Location: San Jose
01-10-2014, 07:42 PM | #63 | |
I have not had a chance to test them yet, Once I get my new ESC in the mail I will test them out. | |
01-15-2014, 03:45 PM | #64 |
I tested out the eBay beadlocks today the tires bound up at one point and the tires never spin around the rim or pulled a bead. IMO they are well worth the money |
01-15-2014, 03:46 PM | #65 |
| Low cost aluminum 1.9's
Double post
01-17-2014, 04:09 AM | #66 |
Glad to hear Tom95YJ! And thanks for doing the test and taking the pics. Now I really can't wait... Sent from my ASUS Transformer Pad TF300T using Tapatalk Last edited by kuyawil; 01-17-2014 at 04:11 AM. |
01-24-2014, 11:34 AM | #67 |
Newbie Join Date: Nov 2013 Location: west georgia
| Re: Low cost aluminum 1.9's |
01-24-2014, 01:02 PM | #68 |
Looks good. Did you use the stock foams that came with the Rock Beasts? I switched to the CI Deuce's Wild foams for the Rock Beasts and the fit was perfect. The sidewalls also hold up well when side-hilling. Check them out when you get the chance. Sent from my ASUS Transformer Pad TF300T using Tapatalk |
01-24-2014, 01:09 PM | #69 |
Yeah I used the dual stage foams that came with them. To me they seemed waaaay to big. I'll check those out though. Thanks
02-28-2014, 08:11 AM | #70 |
Quarry Creeper Join Date: May 2005 Location: Ontario, Canada
What do you guys think of these? They look like a slightly smaller Irok tire? 5pcs 1 9 Alloy Beadlock Rim Wheel 114mm OD Crawler Tire for RC Crawler Car | eBay |
05-05-2014, 07:23 PM | #71 |
Newbie Join Date: Oct 2012 Location: Martinsville
Serious question, would anyone be able to tell me if the wheels have the same headlock ring bolt pattern as the axial beadlocks? if so, that means you can use the gear head delrin rings or locked up rc rings on them
05-05-2014, 07:59 PM | #72 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
^ x2 - Wanting to know.
06-25-2014, 08:28 PM | #73 |
I've switched tires again so sofar 2 sets of tires have been mounted and dismounted no stripped hardware and they still hold a bead on high traction surfaces with 3s lipo and heavily weighted wheels. Sent from my iPhone using Tapatalk |
06-26-2014, 03:55 AM | #74 |
Pebble Pounder Join Date: Jun 2011 Location: Rio Brisbanero Australia
i got a set of there wheels well over a year ago now , and apart from the hardware there brilliant |
10-16-2014, 07:22 PM | #75 |
Rock Stacker Join Date: Apr 2014 Location: Longmont
How are these wheels doing? Is anyone using the madbeast with them?
10-16-2014, 10:36 PM | #76 |
Quarry Creeper Join Date: Dec 2013 Location: Pevely
On page 1 post 8 someone is using them with pitbull rockbeast. I'm not sure but I'll bet the bead is the same so they should work.
10-16-2014, 10:53 PM | #77 |
Thanks chopfather. I came across some other wheels this seller has also in his ebay store. I haven't made a purchase yet though.
12-13-2014, 06:30 AM | #78 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
I just wanted to update this thread after what I just stumbled across. Now and then when I get bored looking at my wheels, I do a little window shopping on ebay. I just found this set of aluminum beadlocks that are so cheap, I might have to just get a set for the hell of it for maybe doing tire tests instead of having to mount and dismount tires all day. Check this out...4X RC 1 10 Car Rock Crawler 1 9" Black Wheel Rim Silver Aluminum Beadlock 4037 | eBay |
12-13-2014, 08:49 AM | #79 |
Rock Crawler Join Date: May 2012 Location: Washougal
Those look like plastic to me. Just the rings are aluminum.
12-13-2014, 10:03 AM | #80 |
Low cost aluminum 1.9's - Similar Threads | ||||
Low cost new look | ke6geu | Axial AX-10 Scorpion | 22 | 01-03-2014 02:39 PM |
New used honcho w/ courier body low cost fun machine! | wrx-n-ktm | Axial SCX-10 | 11 | 01-03-2014 02:37 PM |
new low profile servo option for 1.9's | Nabil | Electronics | 13 | 03-08-2011 06:24 PM |
Could this be used as a low cost power supply for charger? | Larry62 | Electronics | 7 | 05-22-2008 04:10 PM |
Hi Torque, low cost...too good to be true?? | metomwhou | Electronics | 6 | 01-31-2006 04:39 PM |
