Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: what other bodies have you guys been running?
Old 08-18-2017, 08:59 AM   #61
Default Re: what other bodies have you guys been running?
Originally Posted by Lenny718 View Post
Has anyone tried the proline Jeep Rubicon body? Thinking of picking one up
If you are talking about the 11.3" wheelbase body, then it might be a bit too close for rear wheels to have any kind of travel. I have mine at 12" and the shock is already leaning backward.
metblack328i is offline   Reply With Quote
Old 08-18-2017, 08:59 AM   #62
I should add that i have ordered a vaterra K10 body and cage. Will update once I install it
Old 08-18-2017, 11:59 AM   #63
Thank you that was the one I was looking at, glad I didn't order it.
Actually I apologize I was thinking of getting the 4 door one which I think is larger, hopefully it fits.
Lenny718 is offline   Reply With Quote
Old 08-21-2017, 06:09 PM   #64
Originally Posted by KMS View Post
From all the other 66 C 10 bodies added to the TRX-4 I have mounted mine a little higher ,,not by choice ,, It had something about the rear body post mounting part that comes in the parts bad ,The stock mount didn't line up I have since seen a vid where it can be turned and lines of with the raised box on top of the bed for shock towers my guess, So what am getting at is the rock sliders mounted in the stock location were 1/2' lower than body and I wanted to use the grove in the slider to hold the body,, Here's what I came up with .
did you paint the side panel white with chrome? is it a decal? On the C10
capone93 is offline   Reply With Quote
Old 08-23-2017, 11:48 AM   #65
Originally Posted by 92fox View Post
I'm digging the Summit body on the TRX4...how did it ever turn out?
I didn't make it far with that body. Too many things didn't pan out the way I wanted so I switched to a ProLine JKU body designed for the Summit/Revo. It fit like a glove and gave several benefits over stock. I'll post pics later today once I finish putting on the decals. Just got it back from my painter.
SCREAMER is offline   Reply With Quote
Old 08-23-2017, 06:46 PM   #66
Running PROLINE 1966 C10 body on my Traxxas TRX 4
Old 08-24-2017, 11:54 AM   #67
First (and bad) photos with the cherokee 2.0 body.
Itīs not fitted, only put on the chasis.
I need to short the WB and see if the inner fenders fit with this new body.
It has some more details than the one from Asiatees, like the rubber windscreen wipers(front and rear) or the gills(I donīt know how it is called this part in english) in the hood
the fenders are included
and also this interior
the light glasses are prepainted. It comes, of course, with the rest of the windows glasses, the door handle and the mirrors.
My BIG BIG DOUBT is which color combination should I take. Suggestions are welcome
Hope you like it.
Sabre8 is offline   Reply With Quote
Old 08-26-2017, 05:56 PM   #68
My new Jeep JKU body. This was the first rc body I ever painted and I think it came out pretty good, just need some aftermarket bumpers since there's a gap between the body and stock ones .
Old 08-28-2017, 08:48 AM   #69
I think this G4x4^2 body has a lot of potential for a build (especially considering the 1:1 version has portal axles and selectable locking diffs)
https://www.asiatees.com/article?%5B...d-Body&id=3020
Should (in theory) match up with the 312mm wheelbase position fairly well, although it is a bit on the heavy side
VTBruiser is offline   Reply With Quote
Old 09-02-2017, 03:50 PM   #70
Axial RTR Rubicon body. Been recycling this body on trucks for a while. Just stuck axial body posts in the TRX4 post holes and they line up perfectly with the stock drilled body holes. Real easy...
ElChupacabra is offline   Reply With Quote
Old 09-04-2017, 10:56 AM   #71
Vaterra k10 roll cage and C10 body.
Old 09-04-2017, 11:28 AM   #72
Nice! Very good to know about the body posts. Smart on Traxxas part to bake in the compatibility with the SCX 10 (same with the bumpers). The folks at vatera could learn a thing or two from them
AggressorBLUE is offline   Reply With Quote
Old 09-08-2017, 02:05 PM   #73
66 C10 cab with proline utility bed and the stock trx 4 fender and inner flares and inner fenders and stock accessories
Sent from my LG-M150 using Tapatalk
Bengriggs is offline   Reply With Quote
Old 09-11-2017, 09:42 PM   #74
Just wondering if anyone has tried to mount a hard body to the trx yet?
solo1 is offline   Reply With Quote
Old 09-13-2017, 10:29 AM   #75
Originally Posted by fr8cture View Post
I got the body mounted then after laying a coat of paint on the bed I noticed this...
What color is this? Been looking for something similar for my 66 ford body.
RCAddiction is offline   Reply With Quote
Old 09-17-2017, 04:11 AM   #76
Finally I put the cherokee body...
But I also painted an original clear body:
that I like more, I still can use the inner fenders to keep the inside clean and in case of any accident the lexan body wonīt suffer any damage because of the exo cage.
I am not sure if I choose the right color... The best thing are the clear windows
Old 09-17-2017, 09:44 AM   #77
"But I also painted an original clear body that I like more, I still can use the inner fenders to keep the inside clean and in case of any accident the lexan body wonīt suffer any damage because of the exo cage.
I am not sure if I choose the right color... The best thing are the clear windows"
I like the paint job you did on the original - the blacked-out sections look great, add a unique look.
Hard to do with white, but some other color on the interior could add a finishing touch.
To keep the white from being darkened, though..... not sure - maybe silver or light gray?
durok is offline   Reply With Quote
Old 09-17-2017, 01:25 PM   #78
I'm working on Proline's '66 C10.....
TRX4_19
bilinvic is offline   Reply With Quote
Old 09-17-2017, 09:13 PM   #79
waiting for parts for my trx, I have been playing with some bodies from other builds...
Shortbed 72 (my current SMT body)
Longbed 72 (my current bomber based truckbody)
Blazer (old clod body)
Doved nose/Tail 81 chevy
Smashed 81 chevy the TRX's current body
Lanky is offline   Reply With Quote
Old 09-22-2017, 05:04 AM   #80
Bought the body from a member here. Loving it so far.
AGHolman is offline   Reply With Quote
what other bodies have you guys been running? - Similar Threads
Where's all the S.E. WI guys running at? Mopardude Wisconsin 12 11-20-2015 05:03 AM
How much caster are u guys running? wingnutcrawler General Scale Talk 3 03-27-2015 09:10 AM
RX/Tx? What are you guys running? molina Axial Yeti 18 03-07-2015 09:14 PM
Wraith bodies? What bodies are you running? AXLE 69 Axial Wraith 29 09-25-2014 01:17 PM
what shocks are you guys running? bro_die Axial SCX-10 21 06-17-2011 09:06 AM
