Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: what other bodies have you guys been running?
Old 09-22-2017, 09:10 AM   #81
Default Re: what other bodies have you guys been running?
Im running the Proline 4runner im at work so no pics at the moment here is how i shortened the wb: I made 2 sets of front Lower links first set was 3/32" brass rod (which gained no weight) then I made a set out of 1/4" brass rod ( which doubled the link weight) Installed the 1/4" on the front lower. I then used the stock front lowers on the rear and the 3/32 brass on the rear upper. The uppers and lowers on the rear are the same size. but that will put you dead nuts on 12.3" i also moved the rear shock towers fwd and used the plastic piece included in the bag to keep stock mounting holes
ruinx is offline   Reply With Quote
Old 09-24-2017, 04:46 PM   #82
https://flic.kr/p/XJSyUE
Not quite finished yet but i think a good start!
solo1 is offline   Reply With Quote
Old 09-24-2017, 10:15 PM   #83
Progress with my new TRX4 body....
TRX4_28
TRX4_30
TRX4_29
TRX4_27
bilinvic is offline   Reply With Quote
Old 09-24-2017, 11:04 PM   #84
Tossedman's Avatar
Looks great Bil! Is that the SSD bumper?
Tossedman is offline   Reply With Quote
Old 09-24-2017, 11:17 PM   #85
Thank you....yes, SSD front bumper. I have a rear bumper coming from RPP.
Old 09-25-2017, 12:05 PM   #86
Does anyone know who bought the new bright trailcat and started the post about running the on their trx? Pretty sure it didn't work out but the frustrating thing is I was looking at the thread last night and cannot find it after looking and searching. Thanks
geauxktm, is offline   Reply With Quote
Old 09-25-2017, 12:36 PM   #87
Originally Posted by ubernewb View Post
ah-ha! good eye.. totally failed to notice he was still using the straight mount.
Are you saying there's more than 1 mount setting or mounts can be moved on rails?
A couple looks I've ran. Trimmed Ascender body and a Comanche body I bought for $5 at lhs.
Old 09-28-2017, 06:40 AM   #88
I am a Ford guy, so when I saw this body, I had to give it a shot. Proline 66 F100 for the T Maxx. I think it turned out alright.
Sent from my SAMSUNG-SM-G935A using Tapatalk
slickwill16 is offline   Reply With Quote
Old 09-29-2017, 02:10 PM   #89
Started off with the full Hilux body and now ended up with the axial bed cage. This is my first go around so it’s still a work in progress.
NeedMoreLow is offline   Reply With Quote
Old 09-29-2017, 11:08 PM   #90
Looks great! Try swapping the front and rear bumper supports, keep them flipped. this will raise the front bumper/ lower the rear. This will allow you to drop the rear bed cage. Then space up your sliders. I used 2 revo ball ends stacked, and longer screws...
Lanky is offline   Reply With Quote
Old 09-30-2017, 03:27 PM   #91
Thanks. I removed the piece that locks the battery in last night because that was holding the cage up really high like in these pics. I'll swap the bumper supports around now too.
Old 10-02-2017, 01:34 PM   #92
Old 10-03-2017, 03:47 PM   #93
Mog cabin without make up now.
https://www.youtube.com/watch?v=RaALt525gTE
Traildriver is offline   Reply With Quote
Old 10-06-2017, 12:34 PM   #94
solo1, Where did you get the shorter suspension links to run this body? And how long are they?
Last edited by Dman07; 10-06-2017 at 12:35 PM. Reason: Didn't name the person I was addressing
Dman07 is offline   Reply With Quote
Old 10-06-2017, 03:14 PM   #95
Used the 100mm front links top and bottom in rear. Had to thread 1 end of each 5 mm more then cut them to 95 mm overall length. This gives 295 mm wheelbase
Old 10-06-2017, 03:22 PM   #96
Another shot
Old 10-06-2017, 03:43 PM   #97
Dude that looks awesome I've definitely seen Jeeps in that color IRL too. Does it have the spare on the back or are you leaving that off?
Mountainsofbeer is offline   Reply With Quote
Old 10-06-2017, 04:06 PM   #98
Leaving it off for now too much fun as is!!
Old 10-06-2017, 05:35 PM   #99
Another
Old 10-08-2017, 10:37 PM   #100
Got any pics since you lowered the body some more?
92fox is offline   Reply With Quote
what other bodies have you guys been running? - Similar Threads
Where's all the S.E. WI guys running at? Mopardude Wisconsin 12 11-20-2015 06:03 AM
How much caster are u guys running? wingnutcrawler General Scale Talk 3 03-27-2015 10:10 AM
RX/Tx? What are you guys running? molina Axial Yeti 18 03-07-2015 10:14 PM
Wraith bodies? What bodies are you running? AXLE 69 Axial Wraith 29 09-25-2014 02:17 PM
what shocks are you guys running? bro_die Axial SCX-10 21 06-17-2011 10:06 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
