![]() | #1 |
I wanna be Dave ![]() Join Date: May 2015 Location: Moving
After my first "testing session" just messing around the house, I checked temps on the motor and ESC and both were much warmer than I thought they should've been for such a short run. I decided to check gear mesh and low and behold, I found this. The pinion was pushed out of alignment from the spur and the mesh was tight to the point of binding. The RTR setup has both motor screws in the "C" holes. I realigned the pinion back to the center of the spur first then moved the motor mount screws to the "D" position. Perfect! Just a slight *tick* and no more binding and I'm making full contact with the spur now. It's only three screws to pull the top spur and pinion cover so 5 minutes of your time will ensure a lot more life out of your motor and spur.
![]() | #2 |
Pebble Pounder ![]() Join Date: Nov 2016 Location: USA
I just checked the mesh on mine and it was super tight. It's on the "D" hole now. Also, I adjusted the pinion and had a bit of an issue with the pinion set screw hitting the spur gear so in my case it had to be moved out a bit. Just keep that in mind. All is good with the truck now. Thanks for posting Screamer! |
![]() | #3 |
Quarry Creeper Join Date: Aug 2014 Location: Glendive
Im glad I read this. Mine was set in the C holes and was very tight.
![]() | #4 |
Rock Crawler Join Date: Jul 2010 Location: Great Britain
So there are different holes for mesh and not a 'slider hole' ?
![]() | #5 |
![]() | #6 |
Newbie ![]() Join Date: Jun 2017 Location: S.E MA
my mesh was fine but the pinion was 1/2 way fwd on the mtr shaft like your's.....
![]() | #7 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Mesh will be fine, its the gear placement. Harley posted about this. I checked mine and it was alright (no contact or issues), but I did move it slightly to get 100% engagement. |
![]() | #8 |
Moderator ![]() Join Date: Sep 2008 Location: PA
![]() | #9 |
Always go over a RTR checking assembly, gear mesh, oil in shocks, etc...especially the "first batch" Production issues are bound to pop up.
![]() | #10 | ||
Screamer, thanks for the headsup and great pic! ![]() Quote:
![]() Quote:
![]() | #11 |
Rock Stacker Join Date: Aug 2005 Location: Spain
| ![]() ![]() Gear meshing Involute gears have the invaluable ability of providing conjugate action when the gears' centre distance is varied either deliberately or involuntarily due to manufacturing and/or mounting errors. Easy! ![]() DANotes: Spur gears: Gear meshing |
How tight/loose do you guys set your gear mesh? | big_poppa49 | Axial SCX-10 | 9 | 11-16-2016 02:15 PM |
Pinion gear and ring gear mesh question | flyboy320 | Axial Wraith | 18 | 01-09-2016 02:41 PM |
Gear mesh | rc crawler boy | General Crawlers | 12 | 07-29-2013 02:17 PM |
Bad Mesh on bevel gear and diff gear out of the box? | Elliott000 | Axial SCX-10 | 3 | 08-19-2011 06:37 PM |
bevel gear, ring gear mesh | rocksteadily | Tamiya TLT Crawlers | 5 | 05-09-2009 12:04 AM |
