06-19-2018, 08:02 PM | #81 | |
Quarry Creeper Join Date: Jun 2017 Location: Yavin 4
| Re: bilinvic's TRX4 Bronco Build Quote:
I was thinking of just overdriving the front, but if there is not huge gap in ratios then I may pick up the od/ud sets. | |
07-30-2018, 05:10 PM | #82 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
Some new 1.9 rims and rubber for the Bronco.... SSD slot wheels Proline Swampers (Predator compound) CI Lil' Nova 4.50 Comp Cut w/ Soft Outers (front) w/ Firm Outers (rear) Vanquish .225 SLW Hubs (black) Locked Up RC Acorn Wheel Studs I'm looking forward to trying out the new Super Soft Predator compound. |
07-30-2018, 07:04 PM | #83 |
Looks great, when I first seen those wheels I thought they would look right at home on the Bronco. Nice job |
08-13-2018, 07:15 PM | #84 |
Rock Crawler Join Date: Feb 2005 Location: stafford springs
I ended up ordering those exact wheels with the Hyraxes and then I came across this thread and immediately ordered the TSLs! Also ordered that battery tray. I put all the Samix bits on mine too except for the link mounts and I put the Samix brass hubs on my front axle. I put the LED kit in the body and plan on using the matte clear on the top just like that guy did in the video.
08-25-2018, 11:39 PM | #85 |
Another day out with the Bronco. Performance was pretty damn good...but I need just a bit more weight forward. I'll probably order a pair of Samix brass hub carriers and maybe even SSD's new Bronco front bumper while I'm at it!!! The Predator Swampers definitely added to some pretty spectacular crawls.....but with that being said, they sure are soft tires and I bound up a rear tire like I've never seen before. The result of this mess was a torn tire and a broken portal axle gear. My day was done |
08-26-2018, 04:06 AM | #86 |
RCC Addict Join Date: Feb 2012 Location: UK
Bah! The perils of traction! :-)
08-29-2018, 06:35 PM | #87 |
Pebble Pounder Join Date: Aug 2018 Location: US
| Re: bilinvic's TRX4 Bronco Build Quote: |
08-29-2018, 08:51 PM | #88 |
They don't make a slot wheel in black, but they all produce a slot wheel in silver that can easily be painted. SSD RC | HIGH QUALITY PRECISION MADE RC PARTS |
08-30-2018, 02:56 AM | #89 |
RCC Addict Join Date: Sep 2015 Location: Southern Maine
So those tires are the 4.75” tall xl super swampers? Just want to make sure. The look of the tires and wheels is awesome. How does it sidehill with the 4.5” foams you are using? Does the tire start to fold over? Thanks. Ben |
08-30-2018, 08:29 AM | #90 |
Newbie Join Date: Mar 2017 Location: Seattle
Wow! You really messed up your tire. What cause the gear breakage?
08-30-2018, 09:03 AM | #91 | |
The bound up tire caused the gear carnage! | |
08-30-2018, 09:56 AM | #92 |
RCC Addict Join Date: Mar 2018 Location: Ocala, Florida, USA
Gotta love the roots! Traction is a good/bad thing at times. The branch bridge on my course is known for twisting tires.
09-08-2018, 09:37 PM | #93 |
How much thicker are the slw .225 hubs than the stock hubs that come with those ssd slot wheels? Did you go with wider hubs for looks or was there interference with something? Thanks Ben |
09-08-2018, 10:53 PM | #94 | |
Quarry Creeper Join Date: Dec 2015 Location: Sutter
I’m pretty sure they are more narrow. They look to me to be closer to the 375 hubs. Sent from my iPhone using Tapatalk | |
09-08-2018, 11:37 PM | #95 |
The VP .225 SLW hubs are equivalent with the SSD hubs. I use them because Locked UP RC scale acorn bolts thread into the VP hubs, not the metric SSD hubs.
09-09-2018, 12:56 AM | #96 | |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
I saw a review on amain... someone saying that there was some play with the VP hubs and whatever hexes they were using. Do you notice any play or are they a snug fit with the trx4 hexes? Thanks . | |
09-09-2018, 05:47 AM | #97 |
Another noob question, what size are the scale lug nuts? Ben |
09-09-2018, 08:11 AM | #98 |
| Re: bilinvic's TRX4 Bronco Build |
09-09-2018, 08:17 AM | #99 |
09-09-2018, 08:31 AM | #100 |
No, 4-40 lug nuts with the VP hubs.
bilinvic's TRX4 Bronco Build - Similar Threads | ||||
bilinvic's TRX4 | bilinvic | Traxxas TRX-4 | 133 | 01-31-2020 10:20 AM |
bilinvic's SCX10.2 Build Ver. 2 | bilinvic | Axial SCX10 II | 185 | 08-03-2018 09:18 AM |
bilinvic's R1 Build | bilinvic | G-Made Crawlers | 82 | 03-14-2018 07:52 PM |
bilinvic's Ultimate SCX10 '73 Bronco Build | bilinvic | Axial SCX-10 | 24 | 05-03-2015 05:55 PM |
bilinvic's Second Wraith Build | bilinvic | Axial Wraith | 11 | 10-14-2014 05:39 AM |
