Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: RCBee TRX-4 Honey Comp Crawler Build Full Mod
Old 04-19-2021, 08:33 PM   #141
Default Re: RCBee TRX-4 Honey Comp Crawler Build Full Mod
Only had time to get the bottom half cab done but tonight I am putting some little touches and paint it with some of my wife’s acrylic paints the front grill and wipers they came out pretty nice! Tomorrow I’m going to do the top part of the cab candy yellow and then tint out the windows with hexes then clearcoat this baby and see if I can get her on the rig by this weekend! BUZZZZ....
Honeyman108 is offline   Reply With Quote
Old 04-21-2021, 07:42 AM   #142
Got the body painted yesterday and its still an experiment but I think I got a good result and a clean body now starting to put the accessories back on the rig and then Crawltime.... BUZZZZZ......
Old 04-21-2021, 08:51 AM   #143
That’s cool!
The honeycomb hexes are an awesome touch!!!
Cant wait to see it in action!!!!
Benp is offline   Reply With Quote
Old 04-21-2021, 10:11 AM   #144
Got all the accessories mounted minus a couple lights im working on today and im pretty happy with the color it definitely pops in the daylight and I was experimenting with the hex stencils and window tint paint and didn't quite hit the bullseye but I got a cool looking rig out of it and will post some photos and videos of this rig n action..... BUZZZZZ......
Old 04-21-2021, 10:15 AM   #145
Originally Posted by Benp View Post
That’s cool!
Thanks Benp........ BUZZZZZZ....... Experimenting and got this but I learned a lot and im happy with the rig lets see how it does on the rocks and the trail...
Hey Benp I got this 4ws TRX4 sport comp build im starting today and will post today and need some help I got all the parts to make it a great comp build and lots of options with electronics and motors and servos . Lets Chat Soon BUZZZZZ.......
Old 04-21-2021, 02:17 PM   #146
Here are a couple of pics of the rig and body and will take outdoor pics when weather is better but still looks cool!!! BUZZZZ.......
Old 04-21-2021, 04:50 PM   #147
Here are some pics with the suspension engaged and some articulation on the new F250 cab..... BUZZZZZ.......
Old 04-22-2021, 06:47 PM   #148
Got the rig ready to run and took her outside to the backyard for some pics and a quick video and im really happy with the way she is handling everything!!! the winches work great and even though I messed up the top half somewhat it looks pretty cool with the sky blue!!! Next couple dayside is going to the big rocks at the park BUZZZZZZZ......
Old 04-26-2021, 05:56 PM   #149
Another pic.... BUZZZZZ....
Old 05-14-2021, 07:20 PM   #150
Hopefully making a video with this one soon BUZZZZZ.......
Old 05-14-2021, 07:24 PM   #151
Smore BUZZZZZZZZZ........
Old 05-15-2021, 07:13 AM   #152
Turned out good!
Looking forward to the vids!
Old 05-15-2021, 08:19 AM   #153
Turned out good!
Hey Benp.... ME Too...... Im goin to try in the video to pull the truck apart with the winches to the point it will lift the truck in the air, then I know I will bw able to pull 2 rigs at once just fro fun..... BUZZZZZ.......
Old 05-22-2021, 12:35 PM   #154
Im about to do a proper Video with this BEEast and am going to switch the rear servo To the internal spool Reefs 800 smart winch and see if I can configure the Reefs micro winch in the front to fit a DSM micro servo mount that's pretty tight so if not i have to wait for a Shapeways order that has a front servo winch mount that is super compact but lets see what Works and also beelieve it or not I may switch the front Reefs 777 for the new Holmes Hobbies SHV800 other than that the Rig is pretty stout and very capable im also putting the Holmes SHV800 so I can use 4s on this rig and see what what's different.... BUZZZZ......
Old 05-23-2021, 09:13 AM   #155
Out to the rocks for some real action to test these babies and get 2 videos of each at 2 awesome spots at Percy Warner Park in Nashville TN...... the HoneyBee Rescue Rig is a little heavy and may need a little weight reduction but she is rocking the Holmes Trio Magnum Crawlmaster / BRXL ESC & Soon The SVH800 Servo and 4s Lipo should make this a rescue machine and the tell of the hive will tell ASAP...... BUZZZZZZ. BACK. SOOOON........ BACK. SOOOON........
Old 05-25-2021, 05:41 AM   #156
Looks great! Thanks for the info and for posting!
Juanito is offline   Reply With Quote
Old 05-28-2021, 07:14 AM   #157
BUZZZZ Juanito hope all is well and Thanks for the shout out hopefully I get the servos swapped out and put this Rescue rig to work this summer..... Hopefully ill post something today or tomorrow on the build.... BUZZZZZ......
Old 05-28-2021, 03:24 PM   #158
BUZZZZ crawlers tonight im working on swapping some electronics and adjusting the micro servo in the front I just installed the Holmes shv800 cant wait to see the torque on this beast with 4S...... BUZZZZZZ.......
Old 07-11-2021, 08:33 PM   #159
Finally getting back to the bench after a long break and was able to finally finish this rig with the expectations I had and got all the electronics swapped out and set on the radio and am looking forward to putting her to work!! The Reefs spoolless 800 is a very strong winch....
Old 08-07-2021, 07:24 PM   #160
BUZZZ CRAWLERS its been a long time I had a lot of good time to be at the bench working and crawling and that's this weekend and im diving in!!!!!
After testing this rig several times im going to swap the winches and move the Reefs Internal Winch to the front and build a front axle for the rear and use the triple 4 servo mounted on the axle and also remove the brass diff cover and replace with RC4WD aluminum diff cover also going to remove the LCG battery tray to give room for the rear axle mounted servo and replace with a link rod so should be an easy fix going to try to finish it tonight wish me luck!!! BUZZZZZZ.........
Tags
comp crawler, honey rig, hot racing, trx4
RCBee TRX-4 Honey Comp Crawler Build Full Mod - Similar Threads
TRX-4 Honey Comp Crawler Maiden Voyage Honeyman108 Traxxas TRX-4 3 10-28-2020 09:20 PM
Full Drop Bed TRX-4 Bronco Project Build 55ovalcharlie Traxxas TRX-4 42 11-26-2018 03:53 PM
Traxxas TRX-4 Scale Crawler Full Review and Test Drive! driftomaniacs Scale Videos! 1 05-23-2017 06:32 PM
Pics of my Full Mod Crawler thorn4run General Crawlers 28 01-30-2007 06:19 PM
TXT Crawler.... Stone Cold Crawler... Full Tube Scale build RockSpyder Tamiya Txt-1 and Juggernaut 6 12-14-2004 09:40 AM
