12-04-2015, 06:12 AM | #21 |
Rock Crawler Join Date: Aug 2009 Location: San Antonio
| Re: MaxBonv Toyo Ascender Class 1 |
12-07-2015, 12:42 PM | #22 |
Quarry Creeper Join Date: Aug 2010 Location: Varese - Italy
Finally some upgrades to my Ascender, all brand Vaterra. My intention is to test every upgrade and evaluate them one by one. First of this, disc brake Aluminum axle upgrade Aluminium Shocks An important modify that I wanted to do, is to increase the camber angle when the wheels steer Today's test gave me great satisfaction, I have seen very important improvements in driving on hard steps |
12-07-2015, 02:26 PM | #23 |
Quarry Creeper Join Date: Jan 2014 Location: Ukiah
Beautiful. Just beautiful Sent from my LGUS990 using Tapatalk |
12-07-2015, 02:28 PM | #24 |
12-07-2015, 04:09 PM | #25 |
Quarry Creeper Join Date: Nov 2007 Location: Nor-Cal; Olivehurst/Yuba City
Thought the brass knuckle weights were illegal in class 1
12-07-2015, 04:49 PM | #26 |
| Re: MaxBonv Toyo Ascender Class 1 X2, brake rotors painted up look great, that extra caster really helps steering and on steep climbs ime. Nicely built truck keeps getting nicer and nicer. Painted up the brake rotors look great! Any body off pics? EDIT: RC4WD MTZ's are one of my favorite looking scale 1.9 tires, they look amazing! |
12-08-2015, 06:10 AM | #27 | |
| Re: MaxBonv Toyo Ascender Class 1 This is the answer of R2j, a member of the Committee SORRCA. Quote:
12-09-2015, 03:02 PM | #28 |
Thanks, looks good and I've changed over to the XT-60 plugs that come on Turnigy lipos, they are just a better connector over Deans...way easier to solder, re-use, better contact even after repeated use, nice to grip for un-plugging.
12-11-2015, 12:54 PM | #29 |
| Re: MaxBonv Toyo Ascender Class 1 I'm sorry but I did not understand well, you prefer the Deans or XT60?
12-11-2015, 01:00 PM | #30 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
He likes the XT60
12-11-2015, 03:23 PM | #31 |
12-11-2015, 07:44 PM | #32 |
12-13-2015, 11:56 PM | #33 |
The winter, the cold and the snow closed the season of scaler, now is the time of important modify for the season 2016. First step, which affects all mechanical layout, are the new suspension, leaf springs . We start from what does not exist, the drawing : And you get to leaf springs finished : This is the first prototype, two different designs, a simple leaf spring and a special leaf spring with connections for anti wrap bar |
12-14-2015, 12:33 AM | #34 |
Very nice! Delrin, HDPE, or?
12-14-2015, 08:41 AM | #35 |
12-14-2015, 09:45 AM | #36 |
And how they do in cold weather with sudden shock force.
01-02-2016, 10:47 PM | #37 |
Rock Stacker Join Date: Jun 2010 Location: Goodyear/ West Phx
OMG... just wow, nice job on the rig!!!
01-10-2016, 06:45 AM | #38 |
Delrin Leaf springs have already been tested in various conditions of temperature, in Italy for many years that are used... It 's time to do something very serious, even in a Class 1... The best projects, starting from a blank sheet of paper, here is what I drew on my: Stock mechanical configuration Low Center Gravity mechanical configuration Comparison of the two configurations Red Lines = quota limits upper and lower overall dimensions of mechanics Yellow Line = center distance mechanics with considerable weight Up to you considerations on improving dynamic |
01-10-2016, 12:20 PM | #39 |
Looks really good, can't wait to see your next move! "Thumbsup"
01-10-2016, 01:53 PM | #40 |
Next move? The white paper had still need to be written To obtain a mechanical configuration suitable for the Rules SORRCA Class 1, and maintain a low center of gravity, it was necessary to design a new front transmission and a new central transfer case, both with very small dimensions : I installed the leaf springs to check operation and geometries. Then I chose the new propeller drive shafts, SDI International, but I wanted to keep the original system input axle, in my opinion the Vaterra original project is very nice, and technically very interesting. Is the only system that guarantees of very reduced dimensions. Here's how I made the connection between the propeller shaft Vaterra and the SDI: |
MaxBonv Toyo Ascender Class 1 - Similar Threads | ||||
Ascender for Class 1? We will see.... | jrkilburn | Vaterra Ascender | 98 | 02-21-2017 06:38 PM |
The maxbonv KoH Twin Hammers | maxbonv | Vaterra Twin Hammers | 207 | 02-24-2016 03:28 PM |
Toyo | T-Man | Traxxas Crawlers | 13 | 10-28-2004 11:31 PM |
