01-10-2016, 02:21 PM | #41 |
Newbie Join Date: Aug 2015 Location: Grand Rapids
| Re: MaxBonv Toyo Ascender Class 1
Really cool build! Definitely following this.
01-10-2016, 08:41 PM | #42 |
I'm likin' your whitepaper so far! You have my attention sir! |
01-11-2016, 05:12 PM | #43 |
Quarry Creeper Join Date: Aug 2010 Location: Varese - Italy
While waiting for milling, at the end of this week will be new transmission and center transfer case, i worked on the axles, a bit of extra metal, a bit of weight : Comparative weight stock axles, modify axle: ( for USA users online converter grams / oz ) Front axle: Rear Axle : |
01-11-2016, 05:15 PM | #44 |
Wow, more beautiful machine work!
01-13-2016, 04:27 PM | #45 |
Looking forward to receiving the parts for the transmission and transfer case, i'm realizing all the final details, such as the supports leaf springs . |
01-13-2016, 05:52 PM | #46 |
Rock Crawler Join Date: Aug 2009 Location: San Antonio
Dam, I wish I could hang out with you for a few days. I want to be your friend. I'll bring my wallet. |
01-14-2016, 04:54 AM | #47 |
| Re: MaxBonv Toyo Ascender Class 1 |
01-14-2016, 05:21 AM | #48 |
Pebble Pounder Join Date: Jan 2015 Location: Calgary
I want those axel housings lol Sent from my SM-G870W using Tapatalk |
01-14-2016, 08:31 AM | #49 | |
| Re: MaxBonv Toyo Ascender Class 1 Quote:
For them you can contact the boss of The Scaler Store by email: thescalerstore@gmail.com | |
01-14-2016, 12:16 PM | #50 |
Yeah I'll be looking into that. Sent from my SM-G870W using Tapatalk |
01-15-2016, 04:22 AM | #51 |
... work in progress |
01-15-2016, 01:13 PM | #52 |
Same pic as the other day. I've been looking at my Ascenders and noticed it's interesting how the two rear most bodypost mounting holes are way low in the rear crossmember almost like Vaterra wanted us to mount TF2/Bruiser bodies on these! I like it! |
01-15-2016, 04:43 PM | #53 | |
| Re: MaxBonv Toyo Ascender Class 1 You are a keen observer Quote:
of the chassis, are higher, that is they have a lower depth, my drop bed is handmade Today i was in a mechanical workshop to take a central transfer case Is very small, see a comparative with the transfer case GCM : Comparative weight : my transfer case 45 grams, GCM transfer case 62 My transfer case have a possibility to change gears, ratio range is 1:1 - 1:42, overdrive included and output for transmission shafts with inverse rotation | |
01-15-2016, 06:02 PM | #54 |
Quarry Creeper Join Date: Jul 2011 Location: ireland
how much for the t case
01-16-2016, 05:48 PM | #55 |
01-16-2016, 07:32 PM | #56 |
Rock Stacker Join Date: Apr 2008 Location: Salt Lake City
My god the engineering is outstanding Sent from my iPhone using Tapatalk |
01-16-2016, 10:56 PM | #57 |
I guess your bed is dropped more than even TF2. Are the transfer case screws enough to locate the two case halves? Last edited by Natedog; 01-18-2016 at 03:45 PM. |
01-18-2016, 03:52 AM | #58 | |
| Re: MaxBonv Toyo Ascender Class 1 Thanks Quote:
My need is to have a performant Class 1 , with a mechanical/suspensionconfiguration with all points scaler The 4 screws of the transmission cover with holes are very precise measures decimals. Transmission installed, here it is where I wanted to, especially the height of the motor / transmission, side view : Side view from below: Seen from above, the measures of this transmission allows for installation between the shock Towers | |
01-20-2016, 11:50 PM | #59 |
That looks awesome, I love the low CG of motor/transmission and leaf springs in line directly under the frame rails! :thumbsup: Nicely shimmed leaf spring mounts to get them exactly where you want them. That motor is low, it must side-hill like a mountain goat! |
01-21-2016, 08:00 AM | #60 |
Very nice my friend. I like how you did the over and under on the transfer case. Looks simple but very strong. You definitely have a comp worthy Ascender. |
MaxBonv Toyo Ascender Class 1 - Similar Threads | ||||
Ascender for Class 1? We will see.... | jrkilburn | Vaterra Ascender | 98 | 02-21-2017 06:38 PM |
The maxbonv KoH Twin Hammers | maxbonv | Vaterra Twin Hammers | 207 | 02-24-2016 03:28 PM |
Toyo | T-Man | Traxxas Crawlers | 13 | 10-28-2004 11:31 PM |
