04-04-2016, 11:16 PM | #201 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
| Re: Newbie
Looks like you had a blast. The single best thing you can do for performance right now is lower your suspension, which may require shorter tires. Narrowing the axles might also buy you enough tuck to lower even further. She's sitting very high right now, which kills your side hilling and climbing abilities. |
04-05-2016, 08:19 AM | #202 |
Rock Crawler Join Date: Jan 2016 Location: US
| Re: Newbie
I have some new shocks i am in the process of putting together hoping that will help some i had my front springs ran down to far also so my front was way to stiff and the shocks out back r dead and come to find out both have bent shafts so if that fails to improve i will go to 1.7 boggers really like the look of them tires LIFE IS GOOD |
04-07-2016, 10:00 AM | #203 |
| Re: Newbie Just got mounted last night havent tried them LIFE IS GOOD |
04-11-2016, 04:28 PM | #204 |
| Re: Newbie
Well the springs on the shocks r to stiff but got out to play today only got one pic before i stripped my upper front rod linkage LIFE IS GOOD |
04-12-2016, 11:29 AM | #205 |
| Re: Newbie |
04-12-2016, 02:31 PM | #206 |
Quarry Creeper Join Date: Jul 2011 Location: ireland
| Re: Newbie
hi hows the gpm parts holding up been thinking of buying some of there parts
04-12-2016, 04:57 PM | #207 |
| Re: Newbie
They have been great nothing has broke or stripped on me very happy with purches LIFE IS GOOD |
04-12-2016, 05:05 PM | #208 |
| Re: Newbie Good to hear, their parts used to be very hit and miss and usually required some finish work to get them to fit properly. Guy at comp the other day had full set of GPM Ascender goodies, shock towers, etc. in blue anodizing and he said that they have been fine. |
04-13-2016, 06:41 AM | #209 |
| Re: Newbie
I cant wait for my jcad plate to get here so i can finsh only 3 weeks to my first comp LIFE IS GOOD |
04-13-2016, 12:19 PM | #210 |
| Re: Newbie Color is a touch dark so i will change it next time i scratch it up to much LIFE IS GOOD |
04-13-2016, 12:32 PM | #211 |
| Re: Newbie
Did you strip it first, brake fluid, Castrol Purple Power or? First dark silver color was good.
04-13-2016, 02:06 PM | #212 |
Newbie Join Date: Mar 2016 Location: Basque Country
| Re: Newbie Thanks Just one more thing, we must remove the plastic left over from the bodywork or left and put over? Last edited by Mir2; 04-13-2016 at 02:30 PM. |
04-13-2016, 04:31 PM | #213 |
| Re: Newbie
Resanded then reprimer and coat i put it on thick and heavy clear itt is a diffrent paint from first job just looked better on top of can then on truck needs to be gun metal gray LIFE IS GOOD |
04-13-2016, 04:37 PM | #214 |
| Re: Newbie
Ah ok, I was thinking that gun-metal grey would be perfect...dang tops of the cans are rarely what it comes out like...some closer than others. |
04-14-2016, 07:34 AM | #215 | |
| Re: Newbie Quote:
LIFE IS GOOD | |
04-15-2016, 05:39 PM | #216 |
| Re: Newbie Better pics later LIFE IS GOOD |
04-15-2016, 10:43 PM | #217 |
| Re: Newbie
Finally got my plate bolted right up no problems and it included all hardware And some new shoes LIFE IS GOOD |
04-16-2016, 09:20 PM | #218 |
| Re: Newbie First off every ssd part i have bought has been awesome next i almost done with bertha i got some wiring and scale stuff to do but basically ready for my class 2 adventure also have a new to me blazer on the way LIFE IS GOOD |
04-17-2016, 11:16 AM | #219 |
| Re: Newbie Found me a nice creek bed to play on and a decent under bridge area i made about 15 feet till i tipped i need to fix that so i guess sway bar will go back on and i have a wheelie problem so i will take rear rotors off and see what happens LIFE IS GOOD |
04-21-2016, 01:21 PM | #220 |
| Re: Newbie
You picked up a only run inside the house for couple minutes used second Ascender? What's the plan for it? |
Newbie - Similar Threads | ||||
help from a newbie | judgeshock | Venom Creeper | 0 | 04-26-2012 06:52 PM |
Another Newbie. | john__505 | Newbie General | 3 | 01-19-2012 10:04 AM |
newbie with a jk | rch8r | 2.2 Scale Rigs | 29 | 07-06-2010 02:42 PM |
Newbie from SE Wi | andy736 | Wisconsin | 34 | 02-10-2009 01:04 PM |
im not a newbie | james22 | Comments, Suggestions, and Help | 13 | 05-16-2008 11:04 PM |
