12-28-2019, 03:30 PM | #721 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
| Re: What did you do to/with your Ascender today |
12-28-2019, 03:58 PM | #722 |
I wanna be Dave Join Date: Apr 2012 Location: Merrill, WI
01-02-2020, 11:42 AM | #723 |
Pebble Pounder Join Date: Jan 2019 Location: Corning
Gravity defying!!! Ok, ya got me. No I’m not very tech savvy!!
01-02-2020, 02:28 PM | #724 |
RCC Addict Join Date: Sep 2015 Location: Southern Maine
| What did you do to/with your Ascender today Decided to put my Codyboy chassis to use with my bobbed blazer body. Think this will make a good combo. There is a local laid back comp that I’d like to use this truck for. Haven’t had much time at all to run my trucks but have the itch to build something so I figured I’d modify this set up. This is still just mock’d up and body is a bit crooked but will update later. Ben Sent from my iPhone using Tapatalk |
02-03-2020, 12:38 AM | #725 |
Quarry Creeper Join Date: Feb 2016 Location: Pembroke ON Canada
Took some time been pretty busy but finally got around to doing some work on the front one of the K10 honestly just moved the link above the knuckle from under. Sent from my FRD-L14 using Tapatalk |
02-04-2020, 11:19 AM | #726 |
Going to be Dremeling the center shaft to the correct length Sent from my FRD-L14 using Tapatalk |
02-04-2020, 06:37 PM | #727 |
Almost there need to create longer flat areas for the set screw. First off new Dremel disks. Sent from my FRD-L14 using Tapatalk |
02-07-2020, 01:12 PM | #728 |
Drive shafts not finished yet but i started mounting the body. It was only 4am when i realized i should possibly go to bed. POWER WAGON Don't Care! (Bonus if you have heard this saying before you get a cookie) Sent from my FRD-L14 using Tapatalk |
02-20-2020, 10:41 PM | #729 |
Finally do the mechanical part. Just needs locktite tomorrow. Sent from my FRD-L14 using Tapatalk |
03-26-2020, 04:35 PM | #730 |
so now working on relocating the battery on my K10 i decided to hold off on the power wagon until i get the battery relocated. thinking in the front of the servo should make for a good area for this. still alots of testing to due and placement ideas
03-26-2020, 07:16 PM | #731 |
Newbie Join Date: Mar 2020 Location: Canada
In the last 2 weeks I've painted the body and grill, built a wooden deck, built a new bumper. Now just building some rock sliders. Sent from my SM-G930W8 using Tapatalk |
03-28-2020, 11:10 PM | #732 |
The cosmetics are not very pretty at the moment but the function to retain the battery within the frame rails without it falling out the sides. But it works and ill do some better fitment it's only a 3s 1500 Helios rc thats got to fit with. More wire management to happen. Sent from my FRD-L14 using Tapatalk |
03-30-2020, 12:07 AM | #733 |
Got to running the K10 in the basement today. And as i thought it would happen the front drive shaft is creating a clicking sound. Im sure it's a easy fix. Nothing internally binding or bad bearings the crown n pinion are shimmed to the best i can get it. Sent from my FRD-L14 using Tapatalk |
04-12-2020, 06:06 AM | #734 |
Newbie Join Date: Dec 2019 Location: Spokane
when I get bored I build well no work and having some money I built this this is a start I am going to run it around the back of the garage Last edited by Roland The Headless; 04-12-2020 at 06:07 AM. Reason: the pix are there but dont come out when I post ??????? |
05-06-2020, 08:41 AM | #735 |
Newbie Join Date: Oct 2016 Location: Chicago Burbs
05-25-2020, 02:44 PM | #736 |
Rock Crawler Join Date: Dec 2005 Location: Marietta
My Ascender has been sitting on the shelf for too long. Time to give it some love since it's my only unmodified RC. First, I stretched the wheel base and fitted the Power Wagon cab I have had sitting here for the last year or so. Then I built a custom front bumper to go along with it since the stock bumper was way too wide for the Power Wagon grille. Next, I have to narrow up my old set of Scaler Fab sliders. I may start that today, but it's probably a project for another day. |
05-25-2020, 05:52 PM | #737 |
That’s going to look awesome. I really like that body with the cage. With no fenders and that front bumper, that’ll be an all business rig for sure. Ben |
05-28-2020, 06:30 AM | #738 |
Technically this was yesterday, but I cut up and remade my sliders to better fit the body. |
05-29-2020, 04:21 PM | #739 |
Painted the body. |
07-28-2020, 09:30 AM | #740 |
Newbie Join Date: Oct 2018 Location: dublin
^^ this is how I want to do mine. Nice job! I may keep the standard wheel base.
What did you do to/with your Ascender today - Similar Threads | ||||
i got a vaterra ascender rtr today | 4x4pornstar | Indiana | 8 | 12-20-2015 11:29 AM |
My Ascender Built, One Bad ascender | CustomCrawlRCMike | Vaterra Ascender | 3 | 07-03-2015 03:45 PM |
