Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Chaotic TH Full Size Shift Servo Plate - Carbon Fiber!!
Old 02-28-2013, 07:39 PM   #1
Default Chaotic TH Full Size Shift Servo Plate - Carbon Fiber!!
Vaterra Twin Hammer Shift Servo Mount
Tired of blowing up those tiny shift servos?? Go Full size!!!
Now you can our full size servo mount that bolts directly in place of the stock mini servo. This is designed to use your factory parts to save you some money.
Super Thin so it doesn't add extra height to your servo for body clearance...
Includes:
.030 Carbon Servo plate
3mm nut
3mm Flat Head Screw
Weight:
Only 2g
Click Here for more pics and pricing
Chaotic Crawlers is offline   Reply With Quote
Old 02-28-2013, 07:39 PM   #2
Default Re: Chaotic TH Full Size Shift Servo Plate - Carbon Fiber!!
Pretty simple to install...But here is a quick how to...
Basic pic with the new servo plate and trans....Includes the super thin plate, screw and a 3mm nut.
I started putting in the new tapered screw first. To prevent possible splitting of the trans hole I recommend taking a drill bit or body reamer slightly to the top of the hole before installing the mount. Then I used the stock screw and servo post from the stock mini servo. Once both in I tightened them both down.
Next put on the other servo post supplied in TH kit. This is where you use the supplied nut to tighten it.
Put the full size servo of choice on the plate and use the stock screws to hold it tight. The stock servo posts only allow you to hit the bottom two screws. This is plenty strong. BUT...If you want this mount also accommodates aftermarket full size servo posts.
Connect up your stock shift linkage and Wallahh...No more worrying how long the mini servo will last...
Set your end points and enjoy!!!
Old 02-28-2013, 09:06 PM   #3
did that screw hole crack where the new tapered screw went into?
twisted is offline   Reply With Quote
Old 02-28-2013, 09:19 PM   #4
It cracked on a previous mount attempt...
FYI do not over tighten!! Haha
Still seems super strong though!!
Old 02-28-2013, 09:59 PM   #5
good to know. i just got a TH. after esc and motor upgrade i will prolly go with a better shift servo for peace of mind.(with your mount). i did re adjust the epa, hopefully that helps.
Old 03-01-2013, 09:52 AM   #6
Wallahh!
lol
SubyJeff is offline   Reply With Quote
Old 03-06-2013, 10:05 PM   #7
We have temporarily lowered the price on these for an Introductory SALE...
Please check them out on our website for the updated Price.
All the orders made to date will be refunded the Sale difference...Thanks for the support!!!
Chaotic TH Full Size Shift Servo Plate - Carbon Fiber!! - Similar Threads
~Chaotic Special Bodiless....Pro Edition~ *NOW IN CARBON FIBER* 53 willys Axial XR10 160 03-24-2012 10:31 AM
Full size servo plate TAT76 Losi Mini-Rock Crawler 3 08-30-2010 02:26 PM
LOSI Carbon Fiber servo / lipo mount - any PICS with full size servo? mascman Losi Mini-Rock Crawler 10 12-16-2009 08:35 AM
Carbon Fiber Lipo/servo battery plate now shipping Rich Trujillo Losi Mini-Rock Crawler 23 04-01-2009 12:24 PM
Axle plate that fits full size servo and battery? Wild Snapper Losi Mini-Rock Crawler 8 03-14-2009 12:39 AM
