06-14-2013, 03:32 PM | #21 |
Quarry Creeper Join Date: Oct 2012 Location: high desert CA.
| Re: TH Product Suggestions - Rants Welcome - BMRC
i think its all a simple fix of someone creating a spindle to move the drive angle up but keep the ride height the same,, i looked at quite a few options at the lhs for a spindle to do such thing but didnt have any luck,, i dont have a mill or i would try to make my own out of aluminum ill see if i can come up with a CAD file or something tho and maybe someone then just needs to make it??
06-14-2013, 06:15 PM | #22 | |
Quarry Creeper Join Date: Dec 2012 Location: SoCal
| Re: TH Product Suggestions - Rants Welcome - BMRC Quote:
and I pondered putting a Chevy in my '73 Bronco just to piss people off !) How much wider is the exo hex to hex? That would be the determining factor anyway for me personally. I gotta admit I'm not much of a scale guy - I don't understand how you can call the TW a scale model anyway with regards to this. It's supposed to be a scale rock racer which is unlimited in most ways by definition. There could be a trend towards wider front ends right now for all we know, it's the nature of 1:1 competition, maybe next year EXO wide would be scale - ha I sure don't mean to offend anyone, this is just my opinion (wacky perhaps) | |
06-14-2013, 06:39 PM | #23 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
The exo front is too wide for a 1.9 rig, unless you plan on offering shorter arms and links..
06-14-2013, 06:50 PM | #24 | |
Shorter arms would defeat the purpose completely I don't mind wider at all but there is a limit. I'm trusting BMRC took this into consideration Last edited by photon_trap; 06-14-2013 at 06:53 PM. | |
06-14-2013, 07:59 PM | #25 | |
My terra-wraith is about 12 inches outside to outside with OMF's .185 hubs and Rockbeast II's. The exo front end would be wide because a 1.9 wheel could not be offset enough to keep the track width reasonable without rubbing the arms. Last edited by frdtrkguy; 06-14-2013 at 08:02 PM. | |
06-14-2013, 08:00 PM | #26 |
Rock Crawler Join Date: Dec 2011 Location: Virginia
| Re: TH Product Suggestions - Rants Welcome - BMRC |
06-14-2013, 08:32 PM | #27 |
Quarry Creeper Join Date: Sep 2010 Location: t(._.t)
what about an upright dual front shock mount that doesnt stick up too far? maybe using 90-95mm shocks. also, maybe a light bar. i like the idea up locking and unlocking front diffs. i would also sign up for a more scale, better looking rear axles truss. the stock one isnt really a truss, it just pretrudes out of the axles housing, and looks like an afterthought. i think new front arms are also in order. not longer, but beefier, and for the guys that are running upright shocks, have the shock mounts facing the right way. i like your guys envolvement in the TH where there is a lack of aftermarket support. |
06-15-2013, 12:03 AM | #28 |
Rock Crawler Join Date: Jan 2011 Location: Blaine, MN
why not keep the TW diff and just make a wide track kit? I know a lot of 2wd minis have wide track kits why not this? The only problem i see is the rear axle do you get a new one or some how widen it?
06-15-2013, 07:14 AM | #29 |
Nothing at all unusual about a wider front track width. I know it's an angle you dont usually see but any modern desert race car is substantially wider at front for many of the same reasons we are thinking - travel and relaxed driveline angles. A n early Porsche is another example; those are like a foot + wider at the front! (just an example, little in common I realize)
06-15-2013, 01:41 PM | #30 |
Quarry Creeper Join Date: Aug 2007 Location: Winnemucca
Yes a wide track kit, but not too much wider, still want it to look realistic-scalish. With upgraded shafts that won't break. I've also noticed the inner bearing on the spindle is really small and mine are worn out. If someone offers replacement spindles they need to have a little bigger bearing I think
06-15-2013, 10:48 PM | #31 |
Newbie Join Date: May 2013 Location: Parker
Just make the new arms with a little bit of a angle up at the spindle end to get the axle on the same plane as the arm. Wouldn't need a bunch of parts, just a arm swap. Would lose a little ground clearance, but you gotta trade something.
06-15-2013, 10:54 PM | #32 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
That is why I'm using the B4.1 rear arms on my TH, they have that kick up for the outer hinge pin carrier.
06-16-2013, 02:22 PM | #33 |
I wanna be Dave Join Date: Sep 2004
id like to see a wide track kit. even if its just a hex at the wheel.
06-16-2013, 03:10 PM | #34 |
Rock Stacker Join Date: Dec 2004 Location: here
Get vaterra to do a buy back program so i can get rid of this thing and replace it with something better.
06-16-2013, 04:59 PM | #35 |
06-17-2013, 07:34 AM | #36 |
| Re: TH Product Suggestions - Rants Welcome - BMRC update: the bell crank steering conversion plate for the stock cantilever shock setup is complete. it uses parts from the 2wd slash and requires you to switch to an aluminum servo horn. we just need to test it and take some pictures. the TH - EXO front diff conversion is about 70% complete. the lower plate is done and i'm currently tweaking the shock mount part of the upper adapter plate. as expected, no progress on vaterra differential upgrades. Wraith - EXO front IFS conversion is about 40%. |
06-17-2013, 07:45 AM | #37 |
| Re: TH Product Suggestions - Rants Welcome - BMRC Are you working on a bell crank set up for the upright shock tower design?
06-17-2013, 11:51 AM | #38 |
06-17-2013, 11:57 AM | #39 |
HELL YEAH BMRC way to keep the THs alive! when will we be able to see pictures of the exo conversion?
06-17-2013, 12:42 PM | #40 |
TH Product Suggestions - Rants Welcome - BMRC - Similar Threads | ||||
Craigslist rants and rave | demonoid369 | Chit Chat | 0 | 07-17-2011 03:12 PM |
BMRC BJ Build | BlueMonster | Tamiya TLT Crawlers | 9 | 03-10-2008 12:06 PM |
