01-22-2014, 03:21 PM | #101 | |
Rock Crawler Join Date: May 2013 Location: Rancho Cucamonga
| Re: Pockets70 Twin Hammers Quote:
The Gmade piggybacks leak from the top seal if it's not tight. Also, after oiling the internal o-ring cartridge, put a dab of grease on the top o-ring before sliding the shaft through it. This can help prevent leakage and damage to the o-rings. Be patient and take your time when bleeding them too. Slowly filling the body is the best way to limit how much air gets trapped in them. Be sure to SLOWLY slide the piston assembly into the body so you don't trap air under the piston. | |
01-22-2014, 03:44 PM | #102 |
Quarry Creeper Join Date: Dec 2013 Location: pot noodle mines wales uk
im thinking about going front upright on the tuber mate ? i got some 75mm gmade piggys on the front now i want to use , but cant decide ??????!
01-22-2014, 03:52 PM | #103 |
Pebble Pounder Join Date: Oct 2011 Location: Wichita
That's what is going on mine. Just need to have time to build the dumb things.
01-22-2014, 03:53 PM | #104 |
| Re: Pockets70 Twin Hammers |
01-22-2014, 04:01 PM | #105 |
I have 93mm on the front of mine and wish they were piggybacks, but the reservoirs won't fit with the stock front cage with my upright kit.
01-22-2014, 06:04 PM | #106 |
01-22-2014, 10:34 PM | #107 |
Yeah, unless you make them truly vertical like the BMRC set up or just say bollocks and do your own full tube cage to incorporate shock hoops.
01-23-2014, 06:48 AM | #108 | |
Rock Stacker Join Date: Jan 2014 Location: Belgium
Cheers | |
01-23-2014, 02:20 PM | #109 |
Expensive day. Just bought a set of Pit Bull Rock Beasts (thanks go to U4RC for the race attendee discount!!!). Hope these work! Also coughed up major coin to get started on a 2.2 build... |
01-23-2014, 02:25 PM | #110 |
great news on the beasts mate ! top top tyres , hope we are not loosing you here to the 2.2 sections ???? cheers shaun
01-23-2014, 02:59 PM | #111 |
Nope, just want to give the big dogs a shot. My TH will keep me racing while I build.
01-23-2014, 10:23 PM | #112 |
Quarry Creeper Join Date: Jul 2011 Location: Temecula
What are your 2.2 plans? Are you going for the comp or trophy class?
01-24-2014, 09:06 AM | #113 |
01-28-2014, 10:11 AM | #114 |
01-28-2014, 10:27 AM | #115 |
hahahahaha , i know that feeling mate !!!
01-28-2014, 10:36 AM | #116 |
New outdrives, relocating steering servo back to the chassis for more steering (clearance problem with the top mount plate), removing shifter servo (need to lock into 2nd gear), front shock bumpstop removal to replace with O-rings, new body panels, fabbing billet trailing arms.
01-28-2014, 10:41 AM | #117 |
jeeeeeeewwssuusss its only just been all done mate !! but i do know the terrible affliction we suffer from !!! lol great job cheers shaun
01-28-2014, 10:59 AM | #118 |
| Re: Pockets70 Twin Hammers Yeah, the outdrives were shot though. Lots of pin gouges so the shafts don't slide smoothly and cause binding. The uptravel is limited by the large bumpstops that Gmade includes with the shocks. I want to extend the rear end a tad, so longer trailing arms are needed. I figure, seeing as how I have a mill at work, it's time to make a set.
02-03-2014, 01:57 PM | #119 |
02-03-2014, 06:52 PM | #120 |
Quarry Creeper Join Date: Mar 2013 Location: Feather river canyon
I think the pit bulls are pretty good, I have a set.. What foams?
Pockets70 Twin Hammers - Similar Threads | ||||
Savage00's Twinny Twin Twin Hammers | Savage00 | Vaterra Twin Hammers | 16 | 09-19-2013 08:09 PM |
Twin Hammers in Twin Cities? | 89XJ | Minnesota | 7 | 05-06-2013 02:59 PM |
