Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Options for vertical front shocks? Options for rear setup?
Old 09-22-2017, 05:08 PM   #21
Default Re: Options for vertical front shocks? Options for rear setup?
It's not that much longer. Looks like it's supposed to have them.
Brake Weight is online now   Reply With Quote
Old 09-22-2017, 05:33 PM   #22
Slow is the new Fast
smog's Avatar
Originally Posted by GA Dawg View Post
What upper links are you running with those Yeti trailing arms?
Blue Monkey
smog is offline   Reply With Quote
Old 09-22-2017, 05:36 PM   #23
smog's Avatar
I would agree mostly, though in person the thing looks lankier from certain angles.
Old 09-22-2017, 08:04 PM   #24
There are some shorter trailing arms that may work. The 1/12 clone FEIYUE FY03 uses 96mm arms whereas the TH are 116mm. I have one of them and a spare set of arms, too. The only problem is they use m2.5 hardware.
Old 09-24-2017, 08:43 PM   #25
Found this. Anyone actually running this?
Originally Posted by wblteen View Post
You can use an Axial Yeti front shock mount (not the xl). It will bolt right in and it is much cheaper than any other option
Sent from my LG-H900 using Tapatalk
Old 09-24-2017, 08:59 PM   #26
I bought it but never ran it. Ended up buying a GCM plate before I could try ir
Sent from my SAMSUNG-SM-G935A using Tapatalk
wblteen is offline   Reply With Quote
Old 09-24-2017, 09:14 PM   #27
smog's Avatar
Only in my Exo Buggy
Old 09-24-2017, 09:21 PM   #28
I added to the title to broaden the thread some.
My search wording may be incorrect, but this is for those running the Yeti/Bomber/SMT rear trailing arms. TH arms are 116mm and the Axial arms are 142mm. The Axial are 26mm/1" longer. I haven't seen any real comparisons for lower mounting location of the shock. I know the Yeti 380 is slightly bigger and heavier as I have one.
Would it be a reasonable assumption that I could run the Axial arms with the 128mm Yeti rear shock vs TH arm and 110mm shock? Spring rate and dampening would need to be tuned.
Then in the front the 92mm Yeti shock with an upright mount? IIRC from yesterday's google session, the BMRC and GCM call for an 85mm shock. The front Yeti's can't really be shortened externally but can be 'shimmed' internally with a bumpstop quite easily. The Scorched kit called for an 80mm shock with 20mm worth of compression. Claimed this was exact range of the TH driveshafts.
What are you hoping to gain with running longer trailing arms?
I ran yeti length trailing arms in mine for a while. It did seem to provide some more articulation in the rear, but because of the longer wheel base I noticed the TH got hung up on stuff more often than when I ran the stock length trailing arms. I'm more of a basher than anything else, and no suspension tuning expert, but I couldn't pick any improvement in high speed handling either, so put stock units back on....
Rotare is offline   Reply With Quote
Old 09-24-2017, 09:23 PM   #29
I put two on my Exo for the body posts. But I have the leftover from the Exo I can use or at least use as a starting template for a homemade mount.
Old 09-24-2017, 09:28 PM   #30
Just because I have several sets of Yeti/SMT TArms. It will stay stock for several months.
Old 09-24-2017, 09:44 PM   #31
smog's Avatar
Clearly it is a useful piece.
It is a simple option I never thought to try with the TH. Post up a pic if you do a mock-up. I a man very curious to see it done.
Edit: you did that to bypass the difficult access to the Exo's guts?
Old 09-24-2017, 10:00 PM   #32
Default Options for vertical front shocks? Options for rear setup?
I got the Exo as a roller with a hack job Wraith cage attached. Good deal at the time... Now the Exo cages are sky high. I had this body with almost the perfect wheelbase I figured it make a cool SCT styled basher. So far so good once I've gotten CVDs in it.
Old 09-30-2017, 03:32 PM   #33
Well. I swapped the ESC plug over to deans and charged up a 2s lipo. Took it for a spin around the yard and the 2 speed to set up great. But it kept rolling over and I gave it a closer inspection. It seems the front diff is toast. Neither wheel spins when throttled and the driveshaft is spinning. Looks like my killer deal may be on par after the repair. Oh well. It is clean though.
Old 10-02-2017, 04:31 PM   #34
The TH diffs are pretty rugid, so unless someone ran them with the bearings extremely worn for a while they are likely fine.
Check the grub screws on the front driveshaft, they like to loosen up after initial assembly as everything "takes a set".
meatmonkey is offline   Reply With Quote
Old 10-02-2017, 05:35 PM   #35
Forgot to update that. Found both screws loose. I was doing body panels and was gonna do some sort of thread.
Old 10-16-2017, 05:26 PM   #36
smog's Avatar
The set screws on the front drive shaft break loose regularly for me since dropping the 10.5T sensored motor into my rig. It is a huge PITA when out on a run. Wish there was an upgrade.
Old 10-16-2017, 06:06 PM   #37
I was thinking that it was a poor setup. I didn't document and am thinking 'out loud', but will an Axial shaft fit? That way a pin can be ran all the way through it.
Old 10-16-2017, 08:27 PM   #38
smog's Avatar
I have no idea. Can't say I have tried to fit one. If it does it would be the first I have heard of it. When MIP made drive shafts for the TH, they only made the rear piece because apparently the front lacked the space required to fit one.
Old 10-17-2017, 12:51 AM   #39
I took the diff to work. Center punched where the set screw hits and used a drill press to slightly notch the shaft. That way the set screw notches in. No problems since
Old 10-29-2017, 09:25 PM   #40
Originally Posted by CR4NK View Post
I have the Sr Irie bell-crank kit (stock susp.) on my TH. I wonder of I can somehow use the blue monkey shock kit in conjunction with my bell-crank kit? Maybe layer or sandwich the BM shock tower kit and the Irie kit at a certain point to make it work. I’m sure some modification to the BM kit would have to be done to achieve it but I’m willing to try. Hmmmmmm
You can use the derwood designs front shock tower with the St. IRIE bell crank setup.
Sent from my SM-G955U using Tapatalk
onecool54@yahoo is offline   Reply With Quote
Options for vertical front shocks? Options for rear setup? - Similar Threads
Front axle options? BDR Axial XR10 12 03-16-2015 01:46 PM
Vertical front shock angle photon_trap Vaterra Twin Hammers 13 06-05-2013 09:08 PM
Front shock options? Baja Bandido Vaterra Twin Hammers 2 05-13-2013 04:33 PM
spring options for t-maxx shocks or what shocks to use? SmokeScream Axial AX-10 Scorpion 2 08-13-2010 01:02 PM
AX 10 front axle shafts options, please! Jeep-Power Axial AX-10 Scorpion 8 06-10-2009 02:58 PM
