04-10-2012, 09:11 PM | #261 |
| Re: wanting a winner... build thread
All good 27... It may seem that way from looking at it, its way more front bias then my stock chassis tho. As where I was a little weight forward at the front of my skid plate I had to pick it up by the front yoke to get it to semi balance on my finger. The only thing that changed was the chassis... I'm sure someone better off will chime in an give a better answer to this.. Off to my build... I worked on the front links an I worked on the front shaft, tricky it was, the front shaft is now two male shafts with a female an two custom springs holding it all together. As I moved my upper links around I got my btl just a few degrees back from zero.. yet in a diff hole then Thomas. I believe I did a little too much bending on them. For now it will do... What I have left to do ... I still have my rear lower links to shorten to get with in comp rules of a 12 1/2 inch wheel base. As I have my first comp coming up on may 5th! I also have a scx-10 cherokee build, that I just pulled all the stock electronics, motor, an lights off of tonight... Still have the all the links,(steering as well) an the shocks off yet. The only thing staying is the chassis an axles... On top of my rigs, I have my wifes 1:1 cherokee to put my lift on an get the tires on. Busy busy.. luckily the 1:1 doesn't come out from inspection till Fri at the earliest, hopefully Mon. So I have time to finish my girl! (Paradox creeper) ... Is that wrong? Then I don't want to be right! Lol |
04-10-2012, 09:49 PM | #262 |
Rock Crawler Join Date: Nov 2011 Location: Paradise, ca
You have a pm winner
04-10-2012, 09:52 PM | #263 |
Also your creepers looking really good man keep up good work
04-10-2012, 11:04 PM | #264 |
Quarry Creeper Join Date: Jan 2011 Location: murrieta
Rigs looking great bro.. For getting to the 12.5" comp wheelbase it looks like your rear is fine but your front is too long. I think I'd try bending those front lowers a bit more before chopping more off of the rear. |
04-11-2012, 08:00 AM | #265 |
Newbie Join Date: Dec 2011 Location: port orchard
do you have the front axle turned back a little?
04-11-2012, 08:20 AM | #266 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
| Re: wanting a winner... build thread Another way to shorten the WB is to spread the links at the axle or put them closer together at the chassis...I hav eto get the MOA prepped for a comp tonight but Ill have some updated pics from my Creeper in my thread either tonight or tomorrow...Ive been rolling some ideas around in my head for a couple of weeks and will try them out and post my findings.
04-11-2012, 10:24 AM | #267 |
Yep, front axle is rolled back some. My links are as wide as I can at the axle an already skinny off my chassis.. well the back more then the front. I ran out of longer screws.. so only a ball end width on the front links an two widths at the rear links. (At the chassis).. The front does seem long but till I test it ill leave it where it is. It doesn't need much just bout 1/4 to 1/2 inch.. I'm also thinking bout running blue dot rovers in the rear after I test. I know they would of help take some bite out of her before The new chassis... |
04-11-2012, 02:08 PM | #268 |
Ok xrv2 chassis owners... Anyone willing to send link lengths from eye to eye? I'm gapme an ready to cut or bend or whatever I have to to run her. My sickness is acting up.. its been two days! .. scx-10 cherokee build started so she's apart as well.. wraith in a box.. Ahhhh! I guess its my sons mini Sct if it gets too bad... LOL.. not really laughing tho... Lower links measurements are more important..
04-11-2012, 02:11 PM | #269 |
Rock Crawler Join Date: Jan 2012 Location: st.louis
Is it too long?
04-11-2012, 02:29 PM | #270 |
Over legal comp length
04-12-2012, 04:40 AM | #271 |
ANy help on the above questions would be great, havt to crawl tonight an nothing figured out.. I did switch the stock ball ends out for shorter ones. That got me to 12 1/2 before compresson... I think if I take a 1/8th off The rear lowers it will put me inside the wheel base when compressed. Also my axle roll really rolls my axle back pretty far when I hit the throttle..? Do I have it rolled back too far? I'll send pics of my electronics after work today
04-12-2012, 08:41 AM | #272 | |
| Re: wanting a winner... build thread Quote:
rear lowers are 108mm hole to hole Since you need to lose 1/2"...Id make it fast and simple...1/4" cut from each rear lower rod end...all four rear lower rod ends....each link is then 1/2" shorter...no new links...or drill/tap required. Or you can also remove 1/8" from all of the rod ends from the front and rear lower links.. You never stated in other places how much link length you needed to lose...or gain...I went back through your thread to find the 13" squat WB length you stated above...Id also seriously suggest some larger Out Side Diameter spacer for the lowers at the chassis ends..using the rod end balls will probably allow the chassis to get bent if you push it too hard. I am working on a solution for those of us who try to turn the XRv2 into a pretzel at every comp like I do. Last edited by rmdesignworks; 04-12-2012 at 08:56 AM. | |
04-12-2012, 09:06 AM | #273 | |
The biggest design difference between my chassis and any other is that the XR has the cab inset...the cab which has the shock mounting holes is narrower than the main lower chassis...this is for several reasons but the main one being to get better shock angles to the axle. Pretty much every other chassis is designed in reverse to mine...narrower bottom..fat top...thats fine but it forces you to have all of your electronics mounted higher...I wanted to take advantage of the trans mounted ESC location and the pocket on the other side of the trans for Rx or BEC/wires etc. | |
04-12-2012, 10:20 AM | #274 |
Thanks for all the Great info Thomas, ill have it straightened out after work.. I also got all my electronics mounted.. Bec an Tekin fxr mounted on the side of The tranny an the rx mounted on the back of The trans were th rubber plug is.. pics after work..
04-12-2012, 07:21 PM | #275 |
To start with... I wish you all, none paradox'd creeper owners good see an understand the smile on my face! It has been none stop from the first rock I crawled over today! With that said.. I got smart an cut down my link ends instead of my links.. wheel base at full length is just shy of 12 1/2... Awesome! She settles out flawlessly an the TT is almost nil.. forward bias an climbing up an over was a breeze! Some roll overs but I was pushing her pretty good! Here is a couple of The crawl spot an rigs.. The guys an now the rigs... The blue scx-10 is actually a ax-10 with a scx-10 chassis.. The orange is an ax-10 with a gate keeper chassis an blue dots.. The black is a Lnc with a lcc chassis AND my Creeper wheels an panther cougars..(sold them) The sweet a$$ one!...... Paradox'd creeper! Oh hockey sticks YEAH! We had a great crawl session.. Pics of electronics... I had a slight issue with my front drive shaft coming apart under a hard bind,( to the axle roll with my link setup) a few times.. I just believe I need a little more spring on the tranny side an a little less spring at the axle.. or flop the shaft end for end an test again.. I get to see all three major brands crawl, an do to all of The creeper owners with the sickness an members of team paradox for all ur help to this point, I say, thank you! Thomas ur designs an countless hours of testing has made it possible for all of us to crawl to the too with our creepers! Last edited by winnerone23; 04-12-2012 at 07:40 PM. |
04-12-2012, 09:00 PM | #276 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
Awesome pics! They turned out good. I'll start on that lead for you tomorrow. I'm too wore out tonight. Good crawl today for sure.
04-13-2012, 09:46 AM | #277 |
Awesome pics! and sweet crawl spot winner! im glad you got all the bugs worked out. that thing looks like awesome compaired to all the others! not that they are not nice rigs but that paradox chassis is sick!
04-13-2012, 11:56 AM | #278 |
Thanks prozac, what's ur name? Yeah the crawl spot is sweet! It has a nice long wall of big stone on the other side of the creek too. Yeah the XRV2 IS AWESOME LOOKING AN PERFORMS AS WELL IF NOT BETTER THEN IT LOOKS! I can't wait to finish it... I just got a set of safari links, black in color, To go with my carbon fiber plates I'm making to fit the chassis..
04-14-2012, 01:35 AM | #279 | |
04-14-2012, 09:34 PM | #280 |
So its,the first day of fishing.. and I coulda cared less when I got there, all I could think was crawl! Yeah its goin to be a new crawl spot! I also noticed this.. not sure when or how, there aren't any marks on it from hitting a rock or anything.. So I'm goin to pull it off an straighten it an put it back on. Maybe a crawl tomm at the new spot, lol, its. Rock run... |
wanting a winner... build thread - Similar Threads | ||||
Wanting to build a quadcopter | iamsuperbleeder | Non Crawler RC's | 21 | 03-25-2012 11:42 PM |
Wanting to build my own lcc | xThexFearedx | Team Losi Comp Crawler | 0 | 04-18-2010 11:26 PM |
T-shirt winner(s) thread | Cloak | General Crawlers | 23 | 08-14-2009 08:56 PM |
wanting to try another tuber build | iceman320 | General Crawlers | 8 | 03-29-2009 06:22 PM |
wanting to build a clod | PONYBOY87LX | Tamiya Clod Buster | 5 | 01-25-2008 11:52 AM |
