Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: Tacoma Jero (Jims Rebuild)
Old 06-10-2007, 11:14 PM   #601
MWRCA'er
Mnster's Avatar
Wasn't really a comp but a after comp scaler meet.
Tiny video of Rick conquering a hill.
Mnster is offline   Reply With Quote
Old 06-11-2007, 12:36 AM   #602
is it tough driving two trucks at a time and then taking pictures too
smokinubyrc is offline   Reply With Quote
Old 06-13-2007, 09:33 PM   #603
Default front suspension
what did u do to the front suspension just swap shocks?
it looks like the angle on your a arms is steeper then mine and i also just swapped shocks so i was wondering what else you did to get the little bit of extra height.
iwantoffroad is offline   Reply With Quote
Old 06-14-2007, 12:10 AM   #604
MWRCA'er
Mnster's Avatar
I used these shocks, they are longer then stock and push the arms as far as they can go.
http://www2.towerhobbies.com/cgi-bin...?&I=LXVU97&P=7
You can also use stock TLT shocks if you cut a hole for the shock and flip the shock mount to the top of the chassis.
Getting rid of that enormous front bumper section really helped the clearance and overall performance of the truck.
Old 06-14-2007, 01:20 AM   #605
I wish i would have wait around for abit.I would have been cool to see if rig run.o wll maybe another time my leg hurt to bad.so will you be making to another comp soon?
brushlessnut is offline   Reply With Quote
Old 06-14-2007, 01:27 AM   #606
MWRCA'er
Mnster's Avatar
I would have liked to have seen you go for a second run. Your stuff was killer capable, don't blame you for leaving though, that super class course seemed to drag on forever. Jim and Rick will be back up for another trip around august.
Old 06-15-2007, 08:00 PM   #607
what do u mean for the bumper
what did u do?
dremel away at parts of it?
Old 06-16-2007, 03:37 AM   #608
MWRCA'er
Mnster's Avatar
The bumpers stinger grill guard section broke off. So I had to reweld it, not sure if I posted that it broke or not.
Now if your talking about the Rick Jeep, yeah dremel work.
Old 06-16-2007, 12:20 PM   #609
no i was talking about
what you did to the front end to get it taller
u gave me the link on the shocks that you got
but what else did u do to make it taller for the front?
did u remove any material from anywere
Old 06-16-2007, 02:28 PM   #610
MWRCA'er
Mnster's Avatar
I didn't remove any material from the suspension. The shocks are constantly pushing down as their travel is to long. The shocks are partially compressed when at rest mounted in the truck.
But, as I said removing that large bumper section really improves your approach angle, possibly making the truck look higher.
As you can see when Jim's ride first started out that large plastic section was cut off the front and replaced with a skid plate.
I don't have any pictures with that large stock bumper section but look at your truck and compare.
Old 06-16-2007, 03:31 PM   #611
allright thanks
ya
the shocks that i put on it
are always pushing down like u said
i just locked the front and rear diffs
put in a johnoson 540 motor
i think im gunna remove the front bumper like you mentioned
maybe a 55turn lathe motor
Old 06-16-2007, 04:46 PM   #612
MWRCA'er
Mnster's Avatar
I'm running a 55t lathe in this truck, but will soon upgrade to brushless. The gearing isn't low enough to really crawl like I want to. Yours might be fine though, this thing weighs a ton with all the extras Jim has installed.
In the process of ordering few new parts for this rig now.
1. Tower pro servo's 945's Jim is still running a standard servo for steering and the winch is getting to weak and needs to be remade.
2. Micro servo so the steering wheel turns, Jim needs power steering.
3. Looking into getting some headlights.
4. Cheap brushless esc, Looking into getting the Tazer, may just end up with a mamba.
5. Lexan window glue, still haven't found the right comprimise of flexiblity and holding power.
Old 06-16-2007, 08:08 PM   #613
Without a doubt the most amusing build up ever. Awesome grand, looks great.
500swmag is offline   Reply With Quote
Old 06-16-2007, 11:16 PM   #614
Have you tried Shoe Goo for the windows? I cannot remember if that leaves the white film on lexan or not.
Trikster is offline   Reply With Quote
Old 06-17-2007, 04:40 PM   #615
MWRCA'er
Mnster's Avatar
The set time is a little long but I'm thinking I will try that next.
I've got a cheap $32 BL Esc coming from hong kong along with 3 servos. Once the stuff comes I'll put Jim to work.
Old 06-17-2007, 05:54 PM   #616
Shoe Goo is very similar to contact cement. stick the two parts together, pull them apart and let them sit for a few minutes. stick them back together and you should have just enough time to get things positined before everything starts to set up. Usually is only a 10-15 minute process, smaller amounts take less time usually...
Old 06-17-2007, 06:33 PM   #617
MWRCA'er
Mnster's Avatar
I'm mostly concerned with finding a way to hold the windsheild in as it likes to spring back and slide all over leaving glue all over. Thats why I liked Ca I simply tacked it down. But, as soon as the truck would roll and something would impact it would just snap off. There is a very minimal bond area 1/8 to a 1/16th edge around the window so it has to be lined up perfect.
Old 06-17-2007, 06:45 PM   #618
What ESC is it? Does it have reverse?
Crawlerguy851 is offline   Reply With Quote
Old 06-17-2007, 07:01 PM   #619
hey mnster what about epoxy putty. you could roll it into a strip and form it around the back side of the window. Just a thought.
Old 06-17-2007, 07:32 PM   #620
MWRCA'er
Mnster's Avatar
Yes, looks like it has a lot of features to. No drag brake, but it should be ok in this truck.
http://cgi.ebay.com/ws/eBayISAPI.dll...2936&rd=1&rd=1
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/1-9-scale-rigs/30646-tacoma-jero-jims-rebuild.html
Posted By For Type Date
ClodTalk.com - View topic - Funny thread on RCCrawler-Jim's Tacoma XC build This thread Refback 03-02-2013 08:03 AM
