Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: bmuzz1's 2012 NWSC C1 "H2 Grocery Getter" and C2 "Cheropile Cherokee"
Old 08-23-2012, 04:26 PM   #1
Default bmuzz1's 2012 NWSC C1 "H2 Grocery Getter" and C2 "Cheropile Cherokee"
So my Wife gave me the green light to attend the 2012 NWSC since I had to miss last years MSD's due to starting a new job.
I have sold off a couple rigs in the past couple months for various reasons and am down to only 1 now but want to make my trip worth my while so I signed up for C1, C2 and the 1.9 KOL...yes 1 rig, 3 events.
I figured the easiest way to do this would be to make sure that the wheelbase was the same which is why I decided to run the H2 and Cherokee bodies, that and since they both have a fairly flat grill bumpers would be able to be universal.
The only changes other then bodies from C1 to C2 is wheels/tires and a quick install of a pair of wheel wells in the Cherokee and it is ready to go.
Here's the specs of the rigs...
Electronics:
FXR
Savox 1268mg servo
CC bec
3Racing winch w/heyOK controller
Ko Propo EX-5UR tx/rx
brood Apocalypse R/S 35t
2200mah 3s 30c batteries
Axles:
Axial front w/OD gears, 300's, Axial C's, VP knucks, HandBrothers CMS
Axial rear w/Axial rear straights and HD gears, DMG truss
Tranny:
Axial filled with RRP gears, 32p 56t spur, 13t pinion
MIP's
Bumpers/Sliders:
Front and rear bumper made out of 3/16" solid rod by me
sliders are RC4WD I believe and are 3/16" solid rod
On to the pics....
C1 H2
Driver is vertically challenged so he needed a pillow to reach the pedals...
C2 Cheropile
bmuzz1 is offline   Reply With Quote
Old 08-23-2012, 04:49 PM   #2
PapaGriz Yo
Grizzly4x4's Avatar
Default Re: bmuzz1's 2012 NWSC C1 "H2 Grocery Getter" and C2 "Cheropile Cherokee"
Originally Posted by bmuzz1 View Post
C1 H2
C2 Cheropile
Your slip is showing in the rear.
Looks great with both bodies on there. Great solution to your "problem".
What is your flexible snorkel tube made from?
Grizzly4x4 is offline   Reply With Quote
Old 08-23-2012, 05:03 PM   #3
Yeah, I've still got to whip up some wheel wells that can be installed Friday night.
It's a reusable flexible straw from a sports bottle with a cap from a spent tube of Shoe Goo.
Old 08-23-2012, 05:26 PM   #4
Like the chero
We need to do another run when it cools off more. And keep an eye out for G6 in late oct.
Erin is offline   Reply With Quote
Old 08-23-2012, 05:44 PM   #5
R2j
SORRCA Committee Member
R2j's Avatar
That's one way to take care of business Brian! Both look great! Wish I was going this year
R2j is offline   Reply With Quote
Old 08-23-2012, 06:08 PM   #6
PapaGriz Yo
Grizzly4x4's Avatar
Freakin awesome, I'll prolly have to steal that idea for Guido. The filter I have looks too big.
Looking forward to seeing this (these? ) at NWSC.
Old 08-23-2012, 06:13 PM   #7
Go for it! I got the bottle/cup from the local .99 store.
I'm looking forward to seeing Guido and the other epic builds for the first time!...and meeting some great people!
Old 08-23-2012, 10:06 PM   #8
Originally Posted by Erin View Post
Like the chero
Yeah we do only this time I'm going down there and I'll be on the look out for the G6 info.
Sometimes you've gotta do what ya gotta do.
Sorry you wont be making it out this year to Shon, but there is always next year.
Old 08-24-2012, 12:52 PM   #9
Well I got the rear gap filler panels made for the Cheropile so as Grizz put it "my slip won't show"
I also whipped up a set of wheel wells out of some heavy clear plastic painted on the inside that can be zip-tide in place before the C2 event.
Old 08-24-2012, 04:15 PM   #10
Is this the rig that used to have the red LR3 body on it? What happened to Little Ava? I can't keep up with you and your rigs?
Big Daddy is offline   Reply With Quote
Old 08-24-2012, 04:23 PM   #11
Yep this is the rig that had the LR3 body on it.
Ava belongs to MTHead now
Old 08-24-2012, 07:27 PM   #12
Kinda went back home...
Old 08-24-2012, 10:41 PM   #13
Yes it did...
So I pulled the servo and water proofed it and then with the help of my 6yr old daughter I plasti-dipped the ends of my Lipos. I should be good to go now, 5 3s lipos and 1 little 2s for the lights on the H2.
In the above chassis pic you can see I already sealed up the electronics box with E6000.
I also put my LED control units in balloons since they are attached to the bodies and liquid taped the backs of the LED's.
With any luck "knock on wood" everything should stay safe from water damage.
Old 08-25-2012, 08:44 PM   #14
Made a quick muffler and exhaust out of some 3/16 brake line and sheet metal. Not sure If I'll paint it or not, I kinda like the way it looks raw.
Old 08-25-2012, 09:09 PM   #15
That looks awesome man! I kind of like how the exhaust on the LR3 has rusted a little, I would imagine this would do the same?
What do you paint your fender wells with? I need to redo the land rover.
Highmark is offline   Reply With Quote
Old 08-25-2012, 09:45 PM   #16
Thanks bud!
I painted these with black lexan paint to help combat the flaking. I used Krylon outdoor spaces textured paint on the LR3.
Old 08-25-2012, 09:56 PM   #17
DOOH!!!
Looking good Brian!!!!
The Cheropile looks ready to do some serious work
I, I, I...... actually ordered some parts today for a new build.. See what happens when we get one day below 100º
MTHead is offline   Reply With Quote
Old 08-25-2012, 10:10 PM   #18
Thanks John!
Any hints to what it's gonna be?
Old 08-25-2012, 11:07 PM   #19
DOOH!!!
Thanks John!
Well it's a Jeep, sort of.. I have a vision, probably end up nothing like it..
Old 09-02-2012, 04:06 PM   #20
I took the H2 up to Prescott with CRAWLER DAD and a few other friends today for a little shake down run. Found a couple little issues that need addressing before the comp. First I need to up my spur gear to a 54-56 tooth because the new 35t motor was getting too hot with the 52t. Second, I found that my tranny screws were working loose and even lost one so we'll need to fix that.
Otherwise it was a great test run. The rig is well balanced and should do really well. The Gmade tires I'm running which I've never seen on another rig before but took a chance on worked amazingly well for climbing and side hill even under the weight of the H2.
I also got some new lights to use on the H2 and the Cheropile Cherokee from CRAWLER DAD that I'll be installing on the front bumper, Rock sliders and the roof of the H2 probably. The lights will run off 12v like the others, but can be ran off 6v as well they just wont be as bright. the other difference is in the 5" light, it uses 12 LEDs not 6 like some of the others.
More updates to come....
bmuzz1's 2012 NWSC C1 "H2 Grocery Getter" and C2 "Cheropile Cherokee" - Similar Threads
BADDMANS C1 called 50Cal """XR10 up grade""" baddman 1.9 Scale Rigs 21 08-27-2012 11:56 PM
"Victim" or "V2" a "Country Boy Customs" class 3 Mighty1 2.2 Scale Rigs 10 05-06-2011 10:56 PM
