03-04-2016, 08:54 PM | #21 |
Quarry Creeper Join Date: Dec 2012 Location: Remember, wherever you go. There you are.
| Re: Poprivet's first full tuber named U.N.C.L.E.
Not sure of the exact temps, but the map gas got plenty hot. A little to hot for me. I found myself burning off my flux before the joint was good. And it seemed like the acual size of the flame spread the heat to far when I was joining a new tube to a preexisting joint. It was worth the extra cash for the little torch to be able to pinpoint the heat. I can somewhat push the solder around with it. That being said, I already had the torch kit. A set of bottles and torch set ain't cheap. With more patience than I have, the map gas set up would definitely get the job done for around $80 bucks vs. The 2-300 initial cost of an oxy/acetylene set up. |
03-04-2016, 09:18 PM | #22 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Poprivet's first full tuber named U.N.C.L.E. Quote: I know you have done some nice tube work on some of your cages, but for your first tuber you are doing a really nice job. Are you still using your rod bender to bend the tube, or did you put something else together? Anyway, looking forward to following along on this one. |
03-04-2016, 09:59 PM | #23 |
Thank you CODYBOY. I did add this to the rod benders bracket. Using the opposite side of the backstop. I got the idea from abother member, but can't Remer who. It's a 1/2" bolt, 2 washers, 2 nuts, and whatever you can find for a spacer. The spacer needs to be the same thickness as the tubing your bending. I just loosen the top nut to slide in the tube, and barely finger tight it down. I put marks on the bracket for duplicating bends. Last edited by Poprivet; 03-04-2016 at 10:02 PM. |
03-04-2016, 10:05 PM | #24 |
Completely unrelated, but Rccrawler just sent me an email wishing me a happy birthday. How cool is that?! This is a great forum. |
03-04-2016, 10:12 PM | #25 |
I knew you would figure out how to make your bender work with the tubing. It is amazing how good the washers a spacer keep the tubing from kinking. I just set mine finger tight too. Good job!!!! And thanks for taking the photo.
03-05-2016, 08:58 AM | #26 |
Quarry Creeper Join Date: Jun 2015 Location: Petaluma, Ca
This is some good info for a first timer maybe thinking about doing some brazing work. The photos of the products that you use help to know what to buy. The file for notching the tubing is a good idea. Will be following the rest of your build.
03-05-2016, 08:28 PM | #27 |
I'm real glad to hear it. What is the point of a build thread, if not to let someone see how you built that. Or in this case "rebuilt that". I can't leave well enough alone. I know it's out of proportion to the 1:1in a few ways (Loosely based). I'm still learning how to scale down. So in an attempt to get it looking more like the real one I'm changing some things. 2 steps forward / 3 steps back. Lol Last edited by Poprivet; 03-05-2016 at 08:33 PM. |
03-05-2016, 08:36 PM | #28 |
I would really like more pictures of the 1:1. If someone can find a good side shot, I'd love to see it.
03-06-2016, 12:05 AM | #29 |
| Re: Poprivet's first full tuber named U.N.C.L.E. 2 steps forward / 3 steps back. Some of my builds resembles that remark! Sometimes you just have to make it your own. |
03-07-2016, 09:44 AM | #30 |
Made a little progress over the weekend. The rear has been reworked, and is still not finished. I shortened everything out back a little. The front got a new stinger, and moved the lower mounting points back to put more of a rake forward. Also got a big portion of the bracing finished. Last edited by Poprivet; 03-08-2016 at 10:12 AM. |
03-07-2016, 09:49 AM | #31 |
| Re: Poprivet's first full tuber named U.N.C.L.E. |
03-08-2016, 07:52 AM | #32 |
03-08-2016, 08:03 AM | #33 |
And just to satisfy my curiosity. I just sat all the electronics in to see where it was at for weight. I still have more bracing and body panels. There are no u4rc tracks anywhere near me,(until I build one) but I had intended on this rig to be 1.9 trophy class legal. The rules say "minimum of 7 lb." I'm not sure I'm gonna make it. Anyone know why there is a 7 lb. minimum? |
03-08-2016, 08:08 AM | #34 |
Rock Crawler Join Date: Mar 2015 Location: "Crawling Heaven"
| Re: Poprivet's first full tuber named U.N.C.L.E. Quote: Wow 5.15lbs. Mine ways 7.04lbs with those same axles. __________________________ 1.9 Ibex tuber - The Merica ibex. R.I.P Dave Mirra Cheers Jacob |
03-08-2016, 08:18 AM | #35 |
Looks good, you made some great progress this weekend. What are you using for your tubing? I use all SS, so magnets won't work for me. How do you like your new torch? |
03-08-2016, 08:30 AM | #36 |
I suppose I might have another pound with the rest of the braces, panels, and a couple scale accessories. We'll see.
03-08-2016, 08:35 AM | #37 | |
It's all 3/16" brake line, and I love love love this torch! How do you like working with the stainless? Stronger I'm sure. I considered ss, and dom, but decided I'd better do my learning on the cheap stuff. | |
03-08-2016, 08:56 AM | #38 |
CODYBOY, I just flipped through a couple of your threads, and I have to say my thumb would be exhausted if I clicked "like" that many times. You do amazing work sir! |
03-08-2016, 12:29 PM | #39 |
Well, thanks Bud it is kind of like therapy for me. If you haven't checked it out, I just started a new build in the Twin Hammer section. "Herbie The Thug Bug" Baja Style. This one is going to be fun, and I'm kind of stepping out of the box a little. |
03-09-2016, 10:09 AM | #40 |
Newbie Join Date: Mar 2016 Location: New Brunswick, Can
| Re: Poprivet's first full tuber named U.N.C.L.E. Hey, I just signed up for this forum to say your build looks awesome and ask a couple questions. I'm still new to crawlers, could you humour me and list the parts you used in this picture? I'd love to do a build like this, I'm wondering what the motor trays from? Or is it something you made up? Thanks Mark |
Poprivet's first full tuber named U.N.C.L.E. - Similar Threads | ||||
SUPER TUBER NAMED TSR-"tequila sun rise" | AxialJeepster | 1.9 Scale Rigs | 15 | 07-22-2012 08:12 PM |
Full Skin Tuber? | Double J | Chit Chat | 9 | 11-22-2006 02:45 PM |
4 link turned into FULL TUBER | dhoffroad | General Crawlers | 5 | 03-04-2006 04:59 PM |
