03-27-2016, 07:52 PM | #61 |
Quarry Creeper Join Date: Dec 2012 Location: Remember, wherever you go. There you are.
| Re: Poprivet's first full tuber named U.N.C.L.E.
Got some work done this weekend. I finally decided on how I want to mount the servo, but could see some clearance issues. This should take care of those. Then the servo mount. I cut, notched, drilled, and tapped a piece of 1/8" angle iron. I left the 4 link installed to get the steering link length right. That way I could make the panhard bar the same length. To help eliminate bump steer. Some temporary all thread links for now. A simple tab drilled and tapped 3mm locates the panhard to the chassis. SSD's panhard/3 link mount that comes with the housings works perfect. It puts the axle side panhard mount in just the right spot to keep the panhard as parallel to the steering link as possible. Also helping to prevent bump steer. All that makes for a complete steering roller, and I could not resist zip tying my electronics in and taking it for a spin around the yard. It handles pretty well, but its definitely got some more motor coming it's way. I may just throw some gear at it first and see, but it needs a little more speed. |
03-27-2016, 07:57 PM | #62 |
I still have the rear cage, and some bracing left. Also trying to decide on body panel material, and how to mount them along with battery mount and removal. Here is a peek at some scale touches I have in mind. Last edited by Poprivet; 03-27-2016 at 08:00 PM. |
03-27-2016, 08:30 PM | #63 |
Rock Crawler Join Date: Mar 2015 Location: "Crawling Heaven"
I wanna get one of those KOH light bars. Just haven't stepped up. How is the body roll In the corners on that? Mine if I'm not carful will roll in the corner... Sway bars are on the list... __________________________ 1.9 Ibex tuber - The Merica ibex. R.I.P Dave Mirra |
03-27-2016, 09:36 PM | #64 | |
| Re: Poprivet's first full tuber named U.N.C.L.E. Quote:
To those of you that don't already know. The light bar and radiator are from the recently discontinued axial EXO. They shouldn't have done that. I frickin love my EXO. To anyone out there that hates there exo, send it to me I will give it a good home. | |
03-27-2016, 09:56 PM | #65 |
Ha ha ha yeah. I'm looking into the Hot racing Universal set up (I know Hot racing) it has good reviews so I might pick it up __________________________ 1.9 Ibex tuber - The Merica ibex. R.I.P Dave Mirra |
03-28-2016, 12:45 AM | #66 |
Quarry Creeper Join Date: Dec 2014 Location: Goat farm
OK OK already everyone know already you make some sweet ass cars! And to make matters worse they perform as good as they look! After getting a chance to drool all over that rig today I think you should wipe off my saliva! Look into dinky rc cheep seats.
03-28-2016, 06:25 AM | #67 | |
Might just be my luck though. | |
03-28-2016, 06:35 AM | #68 | |
I think the dinky seats are still to tall. I'm going to have to do a 2d interior for sure. There is just not enough room for a full interior. | |
03-28-2016, 08:09 AM | #69 |
Oh that's a bummer. What else would you go with? __________________________ 1.9 Ibex tuber - The Merica ibex. R.I.P Dave Mirra |
03-28-2016, 08:46 AM | #70 |
Very clean build! I wish I could braze!
03-28-2016, 09:08 AM | #71 |
| Re: Poprivet's first full tuber named U.N.C.L.E. Thank you sir. Give it a shot. It's not as hard as you'd think. And with your skill level you'll have it down in no time. It literally took me about 6-8 practice joints from never doing it in my life to being decent at it. Last edited by Poprivet; 03-28-2016 at 08:20 PM. |
03-28-2016, 09:18 AM | #72 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
WOW, Looking good buddy!!! If your going to go with 2-D the twin Hammer driver/interior might work for you. And I was complaining about so many joints to solder. That servo set up you came up with is very clean. Is your scale sand rail going to be next?? I have my old B4.2 buggy and a dune buggy body with the same wheel base, the wheels have been turning. |
03-28-2016, 09:23 AM | #73 | |
Also lower gear ratios help a bit. And of course good throttle control. | |
03-28-2016, 09:39 AM | #74 | |
And the more I look at this rig the more I think I may have over done it with all the tube work. I keep trying to tell myself that there are no real lives on the line here. I have a couple rc10gt that I've converted to brushless. Ive been thinking of making one of them into a rail for a while now. But I'm thinking a full scale project might be next on the list. Last edited by Poprivet; 03-28-2016 at 09:52 AM. | |
03-28-2016, 10:17 AM | #75 | |
03-28-2016, 10:19 AM | #76 |
Thanks Ernie, I'll take some measurements when I get home.
03-28-2016, 10:30 AM | #77 |
Rock Stacker Join Date: Sep 2015 Location: Brunswick Hills
Great thread ! I have been wanting to try my hand at brazing for awhile and you have answered alot of questions that I did not even know I had. Rig looks great. I think my first try will probably be a honcho cage. Something much less complicated to get my confidence built up. Thanks for the schooling.
03-28-2016, 11:09 AM | #78 | |
I'm just running the stock ratio that comes in the scx10. The ride height at the bottom of the belly is 1 3/4 and the top of the roof is 8 7/8. __________________________ 1.9 Ibex tuber - The Merica ibex. R.I.P Dave Mirra | |
03-28-2016, 11:50 AM | #79 | |
03-28-2016, 12:12 PM | #80 | |
While a lower ride height will lower your center of gravity. It doesn't stop there. Where the weight is located on the rig has alot to do with it to. If your going for higher speed u4 style, I would say you want your weight low and center bias. If you want good lower speed crawling, I would say you want it low and forward bias. That's just my opinion of course. I am far from an expert. I am still learning as I go. | |
Poprivet's first full tuber named U.N.C.L.E. - Similar Threads | ||||
SUPER TUBER NAMED TSR-"tequila sun rise" | AxialJeepster | 1.9 Scale Rigs | 15 | 07-22-2012 08:12 PM |
Full Skin Tuber? | Double J | Chit Chat | 9 | 11-22-2006 02:45 PM |
4 link turned into FULL TUBER | dhoffroad | General Crawlers | 5 | 03-04-2006 04:59 PM |
