04-04-2019, 11:58 AM | #241 |
Pebble Pounder Join Date: Jul 2008 Location: Orem
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) The steering Ackermann is correct. The arm kick up is 5* and the caster is 8*. I roughly guessed this, from my experience racing 4wd offroad buggies, also researched full-size mid travel kits and those were the numbers I found common.
04-04-2019, 01:40 PM | #242 |
RCC Addict Join Date: Dec 2014 Location: So Cal
Haven't visited this in a while, all I can say is WOW! I hear ya on the locked diff situation. My Bomber has lockable diffs, (haven't put the servos in it to do so) unlocked it steers like a charm, no climbing anything remotely gnarly, sucks steering when locked, it just likes to plow/push. I had to learn how to drive it differently. Carpet was a bad first surface, whereas the tile floor is too forgiving. Concrete floor? Putty the front for a limited slip? What is the final intent for your build? Crawler or multi-purpose? Looking at the driveshaft clearance, could you put a sheet of teflon as a buffer for flex rubbing, even something like a straw over the shaft? This probably isn't how you want to go, however, in the days of the first VW powered long travel buggies (1:1), they would offset (angle) the motor/trans so they could run the same length axles on both sides running an 091 bus box. That concept gives you some space that way.... offset and/or angled. Wouldn't take much.
04-04-2019, 02:05 PM | #243 | |
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) Quote:
04-08-2019, 09:19 AM | #244 |
I got the body mounts all done this weekend. You can see in the front I had to make them really wide out to the front fenders because eventually ill have the hood opening. This body is just for testing purposes to, so its not that detailed, I have a second body that im going to put alot more detail into including light buckets and all. I also have a new set of spindles on their way because the current ones keep breaking. I ordered some mini slash gears and I think they will actually work for making the open diff design. The parts are going to be really tight though. I also rebuilt my King shocks with some different parts and made a few mods to them to make them easier to build and they don't leak anymore they also feel a lot smoother, if anyone wants me to do a tutorial on this I can take pictures and explain my process more... |
04-08-2019, 11:10 AM | #245 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
Definitely do the tutorial on the king shocks. I dont think anybody has figured out thos e shocks yet. Starting to look like a slick pre-runner! Even though that wasnt your intentions. The mini slash gears should hold up well for what you are doing with it. Sent from my LGMP260 using Tapatalk |
04-08-2019, 11:19 AM | #246 | |
04-08-2019, 08:13 PM | #247 |
Just flexin.. |
04-12-2019, 06:44 PM | #248 |
Made a few more stickers to detail up this body more, door handles and badges and grille. |
04-12-2019, 09:25 PM | #249 |
Got out for the first test drive and I couldn't be happier with how it preformed! The 3 months leading up to this point have been all worth it now. Took a few tumbles and surprisingly nothing broke considering a lot of the parts are still the very brittle weak original prototypes. Hope you guys enjoy. ] If anyone could give me a tip on how to get youtube videos to show up, Ill post them here! |
04-12-2019, 09:27 PM | #250 |
If you load the videos on youtube, right click the video window, copy and paste the embed code here. Sent from my LGMP260 using Tapatalk |
04-12-2019, 09:34 PM | #251 |
Thanks! here you go! |
04-12-2019, 10:25 PM | #252 |
Thats a post I would like. I have not wathed the footage yet, I'll get to it in a minute. Sent from my LGMP260 using Tapatalk |
04-13-2019, 03:28 AM | #253 |
Rock Crawler Join Date: Dec 2018 Location: Ontario, Canada
It’s great to finally see this truck in action! That’s some serious rock crawling you’re doing there! Are you sure you don’t want to keep the front diff locked, and put on some M/T tires? LoL The suspension tuning looks good in the video. Sent from my iPhone using Tapatalk |
04-13-2019, 09:02 AM | #254 |
Rock Crawler Join Date: Oct 2009 Location: Upstate NY
That's freakin awesome! Looks like it runs the rocks fairly good, although it's dressed up for a Baja kinda run... Suspension is working as you designed it. Sweet ride over all! |
04-13-2019, 09:39 AM | #255 |
Awesome to see it working!
04-15-2019, 09:09 AM | #256 | |
I'd say the only part of it that "Baja" is the tires, but I've seen a lot of full size rigs that crawl with the same baja t/a... | |
04-15-2019, 09:48 AM | #257 |
Had a little break yesterday. Kinda bummed because these axles were really compact. Truth is though after the first drive they were already bent up. I'm not sure how these last in the original application but there wasn't much torque put on them with a 35 turn motor and tires that have little grip. Oh well back to the CVD's I had on there in the beginning, genuine Tamiya hardened steel should hold up just fine. Last edited by jonnywachter; 04-15-2019 at 09:53 AM. |
04-15-2019, 10:51 AM | #258 | |
Have you considered a SAS (straight axle swap) on the front of your rig, for a little more durability? LOL! Build it, break it, rebuild it, break it, repeat. | |
04-15-2019, 11:08 AM | #259 |
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) |
04-15-2019, 01:07 PM | #260 |
Were those axle shafts from the Tamiya CC01? If so they dont hold up too well in the original application either.
1st gen Durango IFS TRUE SCALE (you're going to want to see this) - Similar Threads | ||||
IFS Durango from 1.9 section | Joshs4x4toyz | Chit Chat | 97 | 03-11-2019 06:45 AM |
