04-15-2019, 01:15 PM | #261 |
Pebble Pounder Join Date: Jul 2008 Location: Orem
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this)
They were off an HPI rs4
04-15-2019, 08:17 PM | #262 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
Bummer the shaft broke. kinda skinny though.. It would probably take some re-work of the hubs to do this, but id try and cut a Baja rey front shaft, sleeve it, and weld it back together. Maybe chuck it in the lathe and bring down the size for looks. |
04-15-2019, 09:00 PM | #263 |
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) If the shaft was any larger id have to move the shocks back, which would in turn make me have to redesign the top arms so that the suspension could compress. I don't think the shafts are too thin, I think these were just extremely weak steel. We'll see after the next round of parts I get. If the hardened Tamiya ones give me any grief ill have to go back and redesign in the direction you are saying.
04-15-2019, 09:34 PM | #264 |
Thats a lot more work than I thought. I sure hope you dont have to go that route. Sent from my LGMP260 using Tapatalk |
04-25-2019, 09:38 AM | #265 |
Got all the new part in, everything went together very well with the exception of the bottom arms, they where a little too tight on the subframe mounts and needed some filing to move freely, this was just because of the tolerance of the SLS printing, I need to open up the mounts a little more. Other than that the only thing that needs to be done is some drilling and tapping which is pretty common with SLS printed parts in order to get a nice round hole. It's hard to tell now that all the parts are black, but the shock towers and mounts are a lot thicker, which should hold up to even more abuse. I never actually broke any of these parts or had problems, but aesthetically they looked like they could be thicker without sacrificing any looks, so I figured id do so. Also, I made every critical screw that is either mounting an arm, spindle, or the steering components captured, with a locknut that way I don't have to worry about stripping the hole or the screw coming loose from movement. Overall very happy with how this came out, now I need to focus on the interior. |
04-25-2019, 10:18 AM | #266 |
Looks awesome with the SLS printed parts. What is the plan for a skidplate? I see there is a bunch of mounting points incorporated in the parts. |
04-25-2019, 10:26 AM | #267 |
Thanks! I'm planning on cutting the skid plate today out of some thin stainless steel.
04-29-2019, 11:09 AM | #268 |
An update for anyone who is still following... Got the skid plate mounted up over the weekend, also put some mirrors on the body. |
04-29-2019, 11:13 AM | #269 |
Rock Crawler Join Date: Jun 2017 Location: Land of burning couches
man this thing is not disappointing. its begging for a raptor hardbody sir |
04-29-2019, 11:36 AM | #270 |
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) |
04-29-2019, 12:08 PM | #271 | |
Pebble Pounder Join Date: Sep 2018
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) Quote:
Sent from my ONEPLUS A6003 using Tapatalk | |
04-29-2019, 12:17 PM | #272 | |
Rock Crawler Join Date: Dec 2018 Location: Ontario, Canada
I'm definitely still following along. I'd love it even more if you could do away with the button heads on the bottom skid plate. Those will get hung up a bit on some terrain. Would it be possible to make the skid plate once piece, with a bend? I'd think the 4 fasteners on what is now the front skid plate would be enough to hold the formed plate in place. What do you think? Maybe the button heads are no big deal? | |
04-29-2019, 12:33 PM | #273 | ||
04-29-2019, 05:59 PM | #274 |
Very nice and great to see your successful updates!!! |
04-30-2019, 06:37 PM | #275 |
Made some new gears for the transmission so this thing will actually get out of its own way, definitely a big improvement, I think I can still go higher in the pinion. Right now its got a 24t "spur" gear and a 22t pinion, I'm going to get a 24t pinion and maybe a 26t. |
05-03-2019, 03:06 PM | #276 |
RCC Addict Join Date: Oct 2014 Location: UK
You can use some of rc4wd R4 transmission spare gears to speed up the SSD transmission. I designed both.
05-06-2019, 12:51 PM | #277 |
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) I could tell the cases were the same but didn't realize the final drives were different. I'll have to calculate what gear ratio I ended up with after my little mod and see how that compares to the r4 set. Thanks for the info Katan.
05-07-2019, 09:19 AM | #278 |
Got an Axial sway bar mounted on the rear. I'm hoping this helps the front end flex more by not letting the rear axle flex as much. I was also playing with springs last night trying to get the rear end as stiff as possible and still maintaining the ride height I want. Things are looking promising! I'll be going to my first comp this weekend with the 801 RC group. I'm looking forward to it and getting some more testing on this setup. |
05-07-2019, 11:30 AM | #279 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
this is looking flat out AMAZING. i agree about making the skid one piece (less hardware required and less snag points) but seems you already have a handle on that. swaybar setup looks nice but once you get on the rocks i doubt it will be needed? that said, i am REALLY looking forward to hearing how it does! maybe even some vid??? this is really great man, you should be very proud. and i agree no more raptors lol (and that's coming from an owner of a new F150!) |
05-07-2019, 11:34 AM | #280 |
Quarry Creeper Join Date: Apr 2016 Location: Canada, Ottawa/Gatineau
I've been running a rear sway bar setup on all my crawlers, 1/18 an up, from 4 to 15 lbs in weight, with no issues or loss of performance. On the contrary, all of them benefited from the RSB with better side hilling, little to no torque twist during climbs and "high speed" (for a crawler) handling. D |
1st gen Durango IFS TRUE SCALE (you're going to want to see this) - Similar Threads | ||||
IFS Durango from 1.9 section | Joshs4x4toyz | Chit Chat | 97 | 03-11-2019 06:45 AM |
