04-08-2016, 06:25 AM | #61 | |
Rock Crawler Join Date: Jul 2008 Location: Pearland, TX
| Re: Szczerba's F350 Welder Rig Quote:
McMaster-Carr Cant wait to see where you take this one. Wes | |
04-09-2016, 09:28 AM | #62 |
Quarry Creeper Join Date: Oct 2014 Location: Baltimore
A lightweight bicycle tube (19-25mm) would probably fit over your springs and be more flexible than HS. Is that a Tamiya body? |
04-09-2016, 11:46 AM | #63 |
Pebble Pounder Join Date: Jul 2015 Location: Fort Collins
could always cut the fingers off of black nitrile gloves. they are durable, don't dry out as fast as a latex glove would and the best part is you wouldn't have any glued seams to come apart.
04-09-2016, 08:58 PM | #64 | ||
Good idea on the tube. Yup on the tamiya. Quote:
Another good idea. I used some 1.25" heat shrink but it doesnt look good. Thinking about it, The springs will be out of sight anyways, so I will probably just use cut down springs and call it good. Quickly made the chassis link mounts. Going with dual links and coil springs front and back. Wont be visible anyways. Got in some sweet adjustable builder links from a friend to try out. Pretty slick. Last edited by Szczerba; 04-10-2016 at 10:00 AM. | ||
04-09-2016, 09:29 PM | #65 |
Uhm... That idea for the builder links is genius! Going to have to make some for myself!
04-10-2016, 10:01 AM | #66 |
| Re: Szczerba's F350 Welder Rig |
04-11-2016, 09:16 PM | #67 |
Hacking Another cool building tool from a friend. Revo rod end holder I conjured up months ago. |
04-12-2016, 10:37 AM | #68 |
Rock Crawler Join Date: May 2007 Location: floriduh
04-12-2016, 10:53 AM | #69 |
| Re: Szczerba's F350 Welder Rig Thanks. I am just making this chassis up as I go. Some folks on other sites have mentioned to do this or do that but I just do what I do. Just kinda going with half looks and half laziness to get the chassis built. Up next, front coil spring mounts, then transmission/transfer case setup. |
04-12-2016, 12:08 PM | #70 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
Builder links and rod end tool... Awesome ideas! |
04-12-2016, 12:37 PM | #71 |
04-12-2016, 12:39 PM | #72 |
| Re: Szczerba's F350 Welder Rig Howler Customs and RC Scaleworx, respectively. See above. Thanks |
04-12-2016, 07:12 PM | #73 |
Interesting suspension, looking forward to a running video, just curious.
04-12-2016, 07:18 PM | #74 |
04-12-2016, 08:44 PM | #75 |
Quarry Creeper Join Date: Dec 2014 Location: Goat farm
um its builder links right? so you know how long to make the real links right???? Poprivit and me think the idea is a stroke of geanus!!!
04-12-2016, 09:11 PM | #76 |
04-12-2016, 11:03 PM | #77 | |
Just 2 parallel sets of links then a panhard for side to side control. Wes | |
04-13-2016, 06:52 AM | #78 | |
I kinda mimicked 5 link aftermarket dually suspension setups and whatever was easiest to build. Also note, these fat links are for mock up and are slightly limiting full bump. Also also, the rig is sitting at full bump so the links jammed up against the chassis makes it look funky too. | |
04-13-2016, 06:43 PM | #79 |
| Re: Szczerba's F350 Welder Rig Really? I had a 2003 Dodge Ram quad cab 4x4, and the front suspension looked nothing like that.
04-13-2016, 07:01 PM | #80 |
Szczerba's F350 Welder Rig - Similar Threads | ||||
Szczerba's Micro 8x8 Tow Rig | Szczerba | Micro Scale Rigs | 37 | 12-13-2015 11:57 PM |
1999 F350 Tow Rig | JonFoster | Micro Scale Rigs | 14 | 10-23-2015 10:57 PM |
Szczerba's Tow Rig | Szczerba | Multi Axle Rigs | 514 | 06-08-2015 05:15 PM |
F350 Scale rig | ttown180 | Axial SCX-10 | 43 | 01-28-2010 01:10 PM |
