02-19-2009, 09:46 PM | #841 | |
Newbie Join Date: Feb 2008 Location: Wheaton
THANK you BENDER that set up work grate but i change it a little bit i use red springs in the back with 45 w on the left rear and 35 and the right rear wheel an the front 20w and yellow springs works grate thank's! | |
03-03-2009, 02:44 PM | #842 |
Rock Crawler Join Date: Aug 2007 Location: Casper, WY
Bender, You installed the Axial CVD's back around post 400, how have they held up? Any failures with them? Thanks for being a straight-up guy and sharing your wealth of information with us. |
03-06-2009, 12:53 AM | #843 |
Newbie Join Date: Jan 2009 Location: Port Coquitlam
When you added the Chisels did you lower your belly hieght back down to what it was with the claws or leave it high? I am running Rovers and finding the side hilling not as good as it used to be with claws on. I lowered the COG back down and find it a bit better.
03-06-2009, 09:32 AM | #844 | ||
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
03-22-2009, 07:19 AM | #845 |
RCC Addict Join Date: Oct 2008 Location: Finland
Bender, why do you prefer to run the optional taller gearing in the front axle and stock in the back? One would think that running stock up front and lower in the back would be more helpful to prevent torque twist. Thanks! |
03-22-2009, 07:27 AM | #846 | |
Quarry Creeper Join Date: Dec 2008 Location: Clermont
You're essentially doing the same thing either way, faster in the front, lower in the back.. | |
03-22-2009, 09:16 AM | #847 |
Newbie Join Date: Feb 2009 Location: pensacola
Hi Bender, after reading all of this build post a couple times im sold on an SWX i alrdy have a TCS Edge rig an a mostly stock AX10 so the bug has bit again im gona build an SWX an follow your build hope its not patient pending......lol......great build thread an thx for all the info an pics..... |
03-22-2009, 11:46 AM | #848 | |||
I personally run the high speed gear set out front to gain a little more wheel speed while digging. Either aftermarket gear set from Axial will help fight torque twist. Running the under drive gears out back will give you the same effect but with a little less wheel speed. Quote:
03-22-2009, 12:51 PM | #849 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
wouldn't running different ratio's in the two axles cause problems like a 1:1 rig, or is it too small of a difference to matter...............bob .... |
03-22-2009, 02:05 PM | #850 |
Rock Crawler Join Date: Nov 2008 Location: Roseville,Ca
03-22-2009, 07:39 PM | #851 |
Rock Crawler Join Date: Jul 2008 Location: Chula Vista
Higher gearset ratio = 2.57 Stock gearset ratio = 2.92 Lower gearset ratio = 3.30 Here is the thread for the optional gear ratios. Optional Ratio Gear Sets The ratio between the Higher and the stock would be so minute that you would only see it when climbing vertical or digging. Correct me if I am wrong. I ordered mine and can't wait. Thanks Axial for thinking of ways to help us shafties out. Bender do you know if they are going to make the helical gears for the stock ratio? Last edited by treday619; 03-22-2009 at 11:58 PM. |
03-23-2009, 09:05 AM | #852 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
Brad, will axial be offering a dig servo mount for the SWX |
03-23-2009, 10:17 AM | #853 |
"HOLLYWOOD" Join Date: Dec 2008 Location: Miami
Hey Bender wanted to ask you how your rig ran at the Midwest Comp.?
03-23-2009, 02:53 PM | #854 | |||
My rig worked awesome. I just made a couple mistakes on my 2nd course, which ended up costing me big time. | |||
03-24-2009, 12:25 PM | #855 |
Quarry Creeper Join Date: Nov 2008 Location: Boise
Hey Bender, Can you see if you can help this guy out? I don't want to give him wrong advice. Quick swx Question Was I correct in saying the SWX was designed to run a dig? That is the only thing that makes any sense to me but I am not an expert. Thanks |
03-27-2009, 05:40 PM | #856 |
Rock Crawler Join Date: Jun 2007 Location: Great Britain
Bender what's the eye to eye length on you lower links? Sorry if I missed it earlier in the thread.
04-01-2009, 11:27 AM | #857 | |
My lowers measure just a shade under 4" to the center of the rod ends. | |
04-01-2009, 05:34 PM | #858 |
[quote=BENDER;1713263]The SWX is designed for the DNA dig, it'll all bolt right up to the skid plate. The only issue that may come up is with the stock DNA dig servo mount, it leaves the servo horn really close to the chassis. I just flipped the servo mount 180* then driled new holes to move the bracket away from the chassis plate. But do you necessarilly have to run a DNA Dig on the SWX chassis? |
04-01-2009, 05:36 PM | #859 | ||
04-01-2009, 05:43 PM | #860 |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
156,000 views on a build thread? You are the ICON. |
