05-12-2008, 05:40 PM | #61 | |
Quarry Creeper Join Date: Feb 2008 Location: Quincy
In my dealings with VF so far I cannot tune it or assemble it due to incorrectly machined parts. I also did not receive any instructions to follow. In fact my crawler has been in pieces for two weeks waiting on them to send parts that will fit correctly. Consider yourself lucky that you got a good one. I did not realize that I would need a mill to install this product. | |
05-12-2008, 06:41 PM | #62 |
Newbie Join Date: Apr 2008 Location: Kent
| Dremel, Dremel What?
New, ordered on the seventh and, fresh out of the box today; everything went just fine until I tried to assemble the tranny to the DIG case. Stock outdrive gear in tranny would not fit in DIG. I see in this thread that there are some machining issues in SOME kits, is this case ID one of them? While I could probably take the Dremel to it and make it work I think maybe I'll grind down the OD of my main outgear (AX80010) in the tranny instead and then wait to hear back from VF. Could be that Axial's gear was too big, I dunno. Last edited by Master_Dirt; 05-12-2008 at 06:50 PM. Reason: part error |
05-12-2008, 08:01 PM | #63 | |
05-12-2008, 09:53 PM | #64 | |
Rock Crawler Join Date: May 2007 Location: lacey
doesn't the dig come with new outdrives? | |
05-12-2008, 11:54 PM | #65 |
Pebble Pounder Join Date: Jan 2008 Location: nowhere near the HAMMERS!!
I think this is his problem, just like me. e-mailed VF with still no reply to repair problem. hole to small ? or shaft to big? what to do? might have to mod it my self. argh!!
05-12-2008, 11:59 PM | #66 |
Quarry Creeper Join Date: Jan 2008 Location: In the corn
I have one of the first ones shipped to the public and I have had zero issues from the start. I love it! |
05-13-2008, 08:21 AM | #67 |
Quarry Creeper Join Date: Nov 2007 Location: Bozeman, MT
I've had mine for over a month & it's been used hard - never had an issue with any part of it - did you people even bother to read the INSTRUCTIONS posted on the VF site?
05-13-2008, 08:32 AM | #68 |
Rock Crawler Join Date: Apr 2007 Location: Denverish
I had the same problem as Big Bird. I just drilled out the circular part that slides over the tranny outdrive. Annoying, but not too big a deal. I did email sales@visionaryfabrication and they sent out new parts at no cost.
05-13-2008, 08:34 AM | #69 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Yup luckily I was an original early adopter. Love it from day one even with a tad bit of working I had to do, very minimal and my trans was used before so that could be part of the issue. Just 2 nights ago ran into my first problem. 4wd wouldn't lock, so I had front wheel drive in 2 spots and front wheel and rear lock. Tore it down, user error! The set screw holding the new VF dog with brass pin onto the VF output was loose. Apparently in my rush to get it on I forgot to tighten it and use loc-tite! LOL |
05-13-2008, 09:35 AM | #70 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
Everybody emailing them with no reply back, you need to send them PM's too. I haven't had any problems with there products yet and I bought a DIG unit and there motor plate.....I thought the motor plate was engraved though and mine wasn't. Who cares though cause engraving dosen't affect anything. |
05-13-2008, 10:16 AM | #71 | |
Moderator Join Date: Jul 2007 Location: Texas baby!
I just installed my second Dig. This time it was on a stock AX-10 chassis. Make sure that the dig case does NOT touch the skidplate. I had to trim a little off of the skid to make it work. The dig action should be buttery smooth for the unit to work correctly. If it does not, take it off the truck and find the problem. Here is a pic of where the dig case was rubbing the stock skid. And here you can see the corner of the skid that needs to be removed. | |
05-13-2008, 10:18 AM | #72 |
Quarry Creeper Join Date: Aug 2006 Location: CO burbs
The HD output yolk is supposed to come with it from them. If that one you have that is reading 6.9 is from them, I would say they have a problem with quality control. I personally would rather have the output larger and have to machine a bit out of the ID on the hole. I don't like busted outputs..... I PMd him and got a response to my first one in about a day. Never got anything back on my 2nd PM. My tracking number tells me that it's hung up in customs with Canada. So either I got the wrong tracking number or he is having someone in Canada make and drop ship them...... I don't know because he hasn't responded. But, it's not like I can't play with the stock setup, so I'm not too worried. Toys are toys and we need to remember that. When someone facilitates us being able to play with cool toys, you gotta give them some slack. It's not like VF has the cash to throw into R&D on a product like FMF/MOOSE... does on their ATV/Cycle parts. I have tried to get machine shops to make stuff for me in the past and they either don't want to mess with it or do something and bail on me because they didn't make enough on little piddly jobs. Then I had to go looking for another shop. In the long run, I had to buy my mill and lathe...... |
05-13-2008, 01:56 PM | #73 |
I joined the Band! Join Date: Aug 2007 Location: mission b.c canada
| vf dig issues..
cutting slack to a company making a product that is suposed to work correctly is ridiculous in my opinion.the company said it was a working unit ,they also said it was a bolt on product ..not many bolt on with no mods required..im sure many people would pay more if it was assembled prior to shipping so the consumer had a bolt on unit..remember alot of people purchased these because they cant make their own dig ..these same people may not have the mental capacity or manual dexterity to do the job of modding the dig unit.. mine showed up the baggy open and the parts all over the inside of the box ..i had to get a set screw and the collar from my lhs..the same hole bigbird is showing as to small mine is oval..that cant be good..the holes the bolts for the outdrives seat against are broken through on the sides.. this is far from a unit that needs any slack cut to the company producing it..if it was an awesome product we wouldnt care about poor service and conflicking statements from the owners..i have a sherline mill/lathe so i can fix or replace any peices i need ,but not everyone can. hey bigbird next time in mission you can turn it on my mill ..if vf doesnt help you..whats with the gap around the brass pin. Last edited by colonelangus; 05-13-2008 at 04:37 PM. |
05-13-2008, 05:35 PM | #74 |
05-13-2008, 05:47 PM | #75 |
| My problem is resolved, where I went wrong was in the transition between the first and second pages of the instructions where the transmission was reassembled. I didn't notice it and of course was trying to assemble it that way. I had rebuilt the original and put it all back together, 100% done (without the DIG) then looked at this thread again. So I tore it down again and this time, looked at the instructions a little more carefully. I did have to drill out one hole on the DIG case, but now I'm assembled and will see if I can get it to work. It binds up too easily but I'll work on it more. |
05-13-2008, 05:57 PM | #76 |
Newbie Join Date: Apr 2008 Location: Fort Worth
Guys I have been very sick since Sunday so if you have been trying to get through to me I will be catching up on my e-mails/shipments all day tomorrow so don't PANIC! I will take care of you as you can see from the other posts if you have a bad part or you just need advise.
05-13-2008, 06:21 PM | #77 | |
Quarry Creeper Join Date: Aug 2007 Location: United States
05-13-2008, 07:14 PM | #78 | |
05-13-2008, 07:43 PM | #79 |
05-14-2008, 08:20 AM | #80 | |
Ok, after doing some more research on them, I have to agree with this. I thought this was mostly a home shop type thing and it's not. There are three guys listed on their web page and I assume all are still there. More than one guy should be able to get this stuff resolved a bit quicker. Now, if his partners bailed on him, I can see issues with being sick. But, the others need to pick it up if one goes down. I am personally involved in 4 small businesses in the mid west, if we ran things the way this is going, we would never have any business. I know what it takes to do it and these guys are getting pretty borderline here. I'm not trying to diss the VF guys for trying to have a go at it, I'm trying to point out that it takes more than one to run a business and this isn't working. Quote:
