09-02-2008, 08:38 AM | #141 |
RCC Addict Join Date: Feb 2007 Location: Simpsonville, SC
Those links are SWEET |
09-02-2008, 02:43 PM | #142 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
| Here some pics with the new links installed They clear everything by about 1/8" just like I thought they where going to. Last edited by yotachump; 02-22-2009 at 11:38 AM. |
09-02-2008, 04:39 PM | #143 |
09-02-2008, 04:49 PM | #144 |
Rock Stacker Join Date: Feb 2007 Location: Roseville, Ca
Are you not afraid of the square corners next to the ball ends snagging? Or are they closer to the same size than they look in the pics.
09-02-2008, 04:55 PM | #145 |
I wanna be Dave Join Date: Mar 2008 Location: Pacific Ocean
Those really tuck up in there nice snd flush. What do you think about a delrin version? |
09-02-2008, 06:31 PM | #146 |
09-02-2008, 07:14 PM | #147 |
09-02-2008, 07:25 PM | #148 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
09-02-2008, 09:01 PM | #149 |
09-03-2008, 01:26 PM | #150 |
| Nope, im not worried about it at all, The corners are not sticking out that much. If anyway it ends up being a problem ill file the corners.
09-03-2008, 10:00 PM | #151 |
09-03-2008, 11:00 PM | #152 |
| Nice lookin chassis and those Traxxas ends are THE way to go with the Losi shocks....Losi ends fit very loose and pop out easy. Traxxas plastic is more durable too. |
09-04-2008, 08:32 PM | #153 |
| My Axial CVD repair.since I cant seem to keep the stock pins in one piece. Drill this out with a 1/16" drill Drill the CVD Stub out with a 1/16" drill The new 1/16" pin on the left. The 1/16" pin has a shear strength of 800lbs. I picked them up from Mcmaster.com part #98381A418 And assemble Last edited by yotachump; 02-22-2009 at 11:38 AM. |
09-04-2008, 08:41 PM | #154 |
RCC Addict Join Date: Jun 2006 Location: Sin City
I think I need a set for my new comp rig. I don't care which set... both are the bomb
09-05-2008, 05:57 AM | #155 |
you didnt have to open the slot up any? im wondering if thats what put the pressure on the pin causing it to break. i may just do this pre-breakage since i noticed some play in that area on mine. my pins were still good shape and they've had about 30 hours of runtime on them. |
09-11-2008, 11:37 AM | #156 |
09-11-2008, 12:46 PM | #157 |
| yea, there biggest spacer goes between the o-rings ,but it also come with limiting spacers. There are 2 spacers connected to each other. use the bigger of those 2.
09-11-2008, 03:17 PM | #158 |
Rock Crawler Join Date: Jul 2007 Location: central PA
How are your CVDs holding up now? I blew a pin apart last night and swapped both pins around to 1/16" drill bit shafts. I hope this holds up because Im only running 7 cells and plan to upgrade to 10 cells. |
09-11-2008, 07:41 PM | #159 |
| Well it's gonna have to do without, cause I forgot to instal them and there built already. I'll just tip the shocks back a couple holes if I have to. |
09-12-2008, 02:48 PM | #160 |
| Lasted long enough to make me need to order a new set. Things really got sloppy after awhile(axle shaft wearing) and then the pin snapped.
