05-31-2009, 10:47 PM | #21 |
Quarry Creeper Join Date: Sep 2007 Location: Central Coast, NSW, Australia
Hard to tell from the photo if the shafts are supported by bearings or bushes. Definitely looks like something in there though, so even a bush could be swapped out for a bearing if there was a problem. Berg offset wheels may not agree with the added bulk at the hub however. |
06-01-2009, 12:52 AM | #22 |
Newbie Join Date: May 2009 Location: Australia, Townsville
Well I ordered a set last night. I need a little clearance anyways as I have droop setup with my shocks. My axial drags its guts over some rocks. The steering set up wont bother me as I dont have my rods on the outer side of the diff. My tie rod runs on the back side. A full custom set up on the front and rear diffs with 4ws. Works very well. Do I have to take a heap of pics and post em up??? |
06-01-2009, 12:53 AM | #23 |
Hateraide Join Date: Dec 2008 Location: Mission BC
they have bushings in them just found out earlier |
06-01-2009, 01:46 AM | #24 |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
I saw those down at the hobby shop. Interesting idea for sure. Wierd that they come as a set of four steering knuckles instead of lockouts for the rear. I was toying with the idea of powder coating them black and using them in a unimog scaler. |
06-01-2009, 08:37 AM | #25 |
Quarry Creeper Join Date: May 2006 Location: Taylorsville
be cooler if you could get a 1:1 for the front and the 1.6:1 for the rear. might could just swap out the big gear in the front, and run 2 little gears for 1:1 if they release spare parts.
06-01-2009, 08:40 AM | #26 |
| Since they have reduction of 1.6:1 you have to run them all the way around. Also since they are a 2 gear they will reverse your rotation so again you have to run them all the way around. Have to go back to old school link type lockouts or fashion some FUBAR style lockouts that we use on the berg.
06-01-2009, 12:31 PM | #27 |
Newbie Join Date: Jan 2007 Location: Oregon City
Stupid question, but I have to assume it's $50 pair, right? It's not clear on the site - and 3Racing occasionally has insanely low pricing on some items. If it's $50 for a set of 4 ea, I'm all over 'em.
06-01-2009, 12:51 PM | #28 |
Rock Stacker Join Date: Jan 2009 Location: Eugene
Unless those are radial bearings on both sides of those gears, I don't think those knuckles will last very long. Kevin |
06-01-2009, 12:57 PM | #29 | |
they come in a pack of all four!! and i will find out how well they hold up if the person gets them on his truck soon | |
06-01-2009, 03:01 PM | #30 |
06-01-2009, 03:30 PM | #31 | |
Question.... where does Axial have thrust bearings, I am only familiar with the AX-10 Kevin | |
06-01-2009, 03:47 PM | #32 |
Quarry Creeper Join Date: Jul 2008 Location: Over a rock and under a bridge
06-01-2009, 04:13 PM | #33 |
06-01-2009, 08:12 PM | #34 |
Newbie Join Date: Nov 2007 Location: Your guess is as good as mine
QUOTE=Harley0706;1823354]Since they have reduction of 1.6:1 you have to run them all the way around. Also since they are a 2 gear they will reverse your rotation so again you have to run them all the way around. Have to go back to old school link type lockouts or fashion some FUBAR style lockouts that we use on the berg.[/QUOTE] On a Axial flip the rear axle over, shave the old mounting towers and make some type of new mount for the upper links. With the three different R&P that can be had mix and match to get the gearing right. |
06-01-2009, 08:17 PM | #35 | |
On a Axial flip the rear axle over, shave the old mounting towers and make some type of new mount for the upper links. With the three different R&P that can be had mix and match to get the gearing right.[/QUOTE] I wonder how close you could get....gotta go look some stuff up | |
06-01-2009, 08:38 PM | #36 |
So how come run it on the back only? I would have thought that extra clearance under both axles would be more advantageous? |
06-01-2009, 09:11 PM | #37 |
06-01-2009, 09:14 PM | #38 |
Gotcha. Guess I didn't see the advantage 'cause here we can steer the back axle around too.
06-02-2009, 01:36 AM | #39 |
Well i just got an email saying my parts have been sent. Shouldnt take to long to find out how well these work. I will post up here with more info once they turn up.
06-02-2009, 09:45 AM | #40 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
Those gears sure look small. like to know how they will hold up. Not worried about the bushings other than losing alittle friction loss. Just kinda think the clearance gain isn't worth the cog loss. The extra gears may help torque twist though. Interesting???????????????????
