11-19-2013, 10:19 AM | #341 |
| Re: Helhedded's Comp Shafty
This new Ultralite D-Mount in aluminum is a sweet piece. The delrin D-Mount has never failed me but added strength at a .3g increase... well I can handle that. Thanks, Duuuuuuude! Last edited by helhedded; 11-19-2013 at 10:37 AM. |
11-19-2013, 10:32 AM | #342 |
Time to test it...let's see some more jumps |
07-24-2016, 10:37 AM | #343 |
bump? |
07-24-2016, 06:57 PM | #344 |
Pebble Pounder Join Date: Sep 2013 Location: matane
Sweet to see this little best is staying alive a have check so many time what you have done it is another great build this build thread, so i am supposed you will drive a new châssis or still keep this one? ??i will follow this build too.
07-24-2016, 06:58 PM | #345 |
I have would says "beast" at the place of "best", sorry.
07-25-2016, 07:49 AM | #346 |
| Re: Helhedded's Comp Shafty I plan on running the same chassis. Even though I drove this car for years I'm still learning how to drive it. |
07-25-2016, 08:36 AM | #347 |
ok ok it seem to work very capable because whit all the new chassis you still run and comp your one ,so you have find a good based rigs.i love it that way ,drawing a chassis an modded them and comp with this is why make crawling more fun.
07-25-2016, 06:59 PM | #348 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
Its about bloody time |
07-25-2016, 07:57 PM | #349 |
Rock Crawler Join Date: Apr 2009 Location: Saint Charles
You crawling again?...... Next your going to grow that sweet beard back. Sent from my iPhone using Tapatalk |
07-26-2016, 03:28 PM | #350 |
| Re: Helhedded's Comp Shafty Cheers mate Looks like body and panel dims aka lack thereof have changed, and some careful wording of what is a cleared gate and what is not. Basically, I can run any body as long as it isn't smaller that 8x3x3, panels are no longer measured and you can no longer straddle for progress. Anything else? Or do you Aussie fckers run different angry 'roo rules? Maybe a little... |
07-26-2016, 03:43 PM | #351 |
I wanna be Dave Join Date: Feb 2011 Location: Atlanta, GA
Who is this helhedded guy? |
07-26-2016, 10:21 PM | #352 | |
| Re: Helhedded's Comp Shafty Quote:
I was not aware that the straddle had been removed. Which IMO is silly as it gives the new folk even less drive time on a comp day. | |
07-27-2016, 05:18 AM | #353 | ||
Where/How does it say Straddles were removed? Quote:
Good to see ya coming back Helhedded ..... nice seeing long time veterans dusting things off | ||
07-27-2016, 05:56 AM | #354 |
Motors rebuilt and heading your way Ashton, the one problem motor had overheated and slung the solder off the comm. I just resoldered it with some high temp silver filler. Your pair is an early one, we started brazing the comm shortly after launching the Crawlmaster brand line. Still a solid motor set though!
07-27-2016, 07:51 AM | #355 | |||
| Re: Helhedded's Comp Shafty Who? Quote:
I was a bit confused. I found an old post by Fishy about how the straddle wording was removed. But HEY that was post was back from 2012. I figured I would start back when I dropped off to catch up. Nothing has changed, you still get progress with two tars through ...it just isn't called a straddle in the rule book. It's referred to as a gate penalty because not all 4 tars made it through cleanly. Quote:
Thanks John and yeah those 16t Crawlmaster motors are great. They comped all across the U.S. back in the olden days | |||
07-27-2016, 02:30 PM | #356 |
| Re: Helhedded's Comp Shafty |
07-30-2016, 06:51 PM | #357 |
| Re: Helhedded's Comp Shafty Tested and ready for Disney, Oklahoma. I'm trying something new up front for foams. It's a prototype closed cell inner built for a 6" tall tire, and 5.25 medium tuning ring surrounding that. So far I like it. It's pretty funky and leaves a bit of air space in the tire. The RCBROS splined tubes are cool. Good stuff. |
10-10-2016, 08:19 PM | #358 |
| Re: Helhedded's Comp Shafty A -47 out of a possible -48 landed me in second place after a tiebreaker with Chadw30 at the 2016 Crawlapalooza. The rig drove great and I had a blast competing again. Last edited by helhedded; 10-10-2016 at 08:28 PM. |
10-10-2016, 09:02 PM | #359 |
Nice job HH! One dang reverse? Too many. I like the weightlifting sticker on the Lex. |
10-10-2016, 10:46 PM | #360 |
Great effort man, So cool to see two old stall warts topping the podium. I bet you found yourself moving much freer on the rocks too. |
