10-10-2012, 01:15 PM | #241 |
| Re: Helhedded's Comp Shafty
In preparation for the 2013 season I have performed the XR10 mod on this rig. The amount of room I have to work with now compared to what I had before the modification is great! My at-the-axle suspension mounting points have been moved out and the front uppers are now ran straight instead of triangulated. The servo has been moved to the center while the RCBro 600mAh 3s has been re-located behind the servo above the drive-line. The rear Mayhems were also swapped out for some HPI 5-Stars to lighten things up. old and gone: SDS Customz Super 300s w/locker VP AX10 Zero Ackerman knuckles No-name C hubs Steel front Beef Tubes Axial AX10 Aluminum Lockouts Axial AX10 rear straight axles new and installed: Creation Fab Premium Delrin Tubes front and rear Axial XR10 Universals and rear straight axles Vanquish Products XR10 Knuckles Vanquish Products XR10 C Hubs Stainless Steel tierod Axial XR10 plastic Lockouts Highland Crawler lockers front and rear HPI 5-Star Wheels #3031 (trimmed to 1" and epoxied hexes) |
10-10-2012, 01:19 PM | #242 |
Nice work Ashton...again...great driving at Nats |
10-10-2012, 01:22 PM | #243 |
After stretching the track width out with the XR10 mod I went into my dungeon filled with Mayhem hubs and hoops and came up with the exact same track width that I had before the axle modification. front track width: 10.5" ~ Mayhem Evo .75 with #1 .180 hubs, shaved Rover, CI 5.5 Soft outer and closed cell inners = 6.5oz rear track width: 10.2" ~ HPI #3031 1" with epoxied axial hexes, shaved Rover, CI 5.5 Medium outer and closed cell inners = 4oz Last edited by helhedded; 10-10-2012 at 01:24 PM. |
10-10-2012, 01:52 PM | #244 |
I wanna be Dave Join Date: Feb 2011 Location: Atlanta, GA
Looks great Ashton! Have you driven it at the new weight? I'm in the process of shedding weight off my 2.2s as well. |
10-10-2012, 02:12 PM | #245 |
| Re: Helhedded's Comp Shafty |
10-10-2012, 02:14 PM | #246 |
| Re: Helhedded's Comp Shafty Thanks, Ryan Yes I have. It was like driving a new rig. The wider shock mounting and less scrub make things much smoother on the rocks and the loss of weight just makes the rig easier to drive. Having more steering helps too. |
10-10-2012, 02:17 PM | #247 |
| Re: Helhedded's Comp Shafty Yes sir, had it before ECC. No build thread Yeah the steering is the key to these rigs without dig. Reverse, reverse, reverse sucks . |
10-10-2012, 02:28 PM | #248 |
I wanna be Dave Join Date: Jan 2008 Location: Arat Alabama
10-11-2012, 10:59 AM | #249 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
Man, thanks for not doing these mods before Nats Ashton! Really nice mods! You confident that those HPI wheels will hold up or are you just experimenting? Yep...and thinking outside the box...sometimes waaaaaaay outside the box. |
10-11-2012, 01:23 PM | #250 |
| Re: Helhedded's Comp Shafty I am confident in the HPIs as I have been beating on them with my berg for quite a while. The only thing that I have to tend to is the epoxy. It will crack up after a bad bind but I have never had a hex slip. I usually just chip the old stuff off and apply new goo after a good beating.
10-11-2012, 01:34 PM | #251 | |
| Re: Helhedded's Comp Shafty Quote:
10-12-2012, 07:59 AM | #252 |
I'm glad that I found this now but my rear HC locker is shot to hell. I guess I'll have to add some of the new VP lockers to the wishlist. In the meantime I'm running a bit of nostalgia in the rear axle. Can anyone identify this locker? |
10-12-2012, 08:07 AM | #253 |
Hauntfreaks locker?
10-12-2012, 08:11 AM | #254 |
10-12-2012, 08:14 AM | #255 | |
Haunts is/was a club member here in jerz and a good buddy. It's cool to still see some of his parts doing work! What do I win? | |
10-12-2012, 08:15 AM | #256 | |
You win a *crawling hug* | |
10-12-2012, 08:16 AM | #257 |
10-12-2012, 08:43 AM | #258 |
10-12-2012, 08:45 AM | #259 |
10-12-2012, 11:59 AM | #260 |
Rock Crawler Join Date: Mar 2007 Location: perkasie, pa
those lockers were the best ever.......I traded mine away 2 years ago in my old pre-moa ax10........DOH!
