Thread: XR10 Mod for AX10 Axles Parts List
Old 05-24-2012, 03:48 PM   #1
Default XR10 Mod for AX10 Axles Parts List
I’ve been asked several times lately for a list of required and recommended parts for the XR10 modification to the AX10 axles so I decided to write up a list. This thread will include part numbers and some RCC vendors who carry them. It will also have my recommendations on what to use. These recommendations are purely my opinion and can be replaced with your favorite brand of hop-up parts.
RCC Vendors That Carry Some or All of These Parts
Vanquish Products
Crawler Innovations
TCS
RCP Crawlers
RPP Hobby
Required XR10 Parts
1. XR10 Universals – AXI30563
2. XR10 Straight Axles – AXI30758 (You will need two of the 110mm shafts so either order two of this part or cut and grind the longer 117mm shaft.)
3. XR10 Knuckles – AXI80061 ( I prefer Vanquish Incision Knuckles)
4. XR10 C-Hubs – AXI80062 (I prefer Vanquish Incision C-Hubs)
5. XR10 Lockouts – AXI80064 (I prefer Vanquish Incision Lockouts)
Beef Tube Options
1. Biggin69 (Longer Beef Tubes)
2. Chris_The_Battery_Man (Wide Splined – Front)(Wide Un-Splined – Rear)
Hardware Needed (Note: Your hop-up parts may include hardware.)
1. M3x6mm Button Head x 24 (Beef Tube and C-Hub Installation)
2. M3x8mm Button Head x 8 (Knuckle and Lockout Installation)
Other Recommended Parts
1. Your favorite brand of locker/spool.
2. Under Drive Rear Gear Set (43/13) – AXI30402
3. Over Drive Front Gear Set (36/14) – AXI30401
I hope this helps someone. If there is any interest I can also post a list of parts needed for building axles and a transmission from scratch. If you have any questions shoot me a PM
Link to my 2.2S
WooPigSooie is offline   Reply With Quote
Old 05-24-2012, 04:18 PM   #2
Right on! This will be great to have for my new build I am putting together. Thanks!
Propane is offline   Reply With Quote
Old 05-24-2012, 05:38 PM   #3
Default Re: XR10 Mod for AX10 Axles Parts List
Good to know! I actually like the trac width offset.
Old 05-24-2012, 06:17 PM   #4
TSK
Shelf queen
TSK's Avatar
Never mind, I was wrong. I did use XR's and 2 short sides. Lol. My bad
TSK is offline   Reply With Quote
Old 05-24-2012, 06:41 PM   #5
Lol it's all good...
But on the track width subject I usually make up for it in hub sizes anyway.
Old 05-24-2012, 07:23 PM   #6
Thanks for the info brother!
MexicanMarauder is offline   Reply With Quote
Old 05-24-2012, 07:29 PM   #7
I've ordered about 85% of the parts. Thanks for your help.
mmatthews is offline   Reply With Quote
Old 05-24-2012, 08:28 PM   #8
No problem fellas
Old 05-24-2012, 08:54 PM   #9
Also on Knuckle, the VP one is Zero ankerman but not Axial one. I think well worth the extra money. For C-hub, I uses TopCAD one, mate up with Vp knuckle no problem and only 1/3 the price.
Colgout is offline   Reply With Quote
Old 05-24-2012, 09:37 PM   #10
i did this mod WITHOUT the beef tubes. very easy to do. i used strc c-hubs with vp knuckles. the vp knuckles are a little different and allow more steering angle. i did not swap the rear axle shafts since i don't see the point in that. mine was done cheaply with cut down xr universals, c-hubs, knuckles. that was it.
hoghead5150 is offline   Reply With Quote
Old 05-24-2012, 10:08 PM   #11
Great info Chris!
Old 05-25-2012, 06:50 AM   #12
I did mine with chris the batterymans short splined tubes with vanquish chubs an stock xr knuckles with cut down xr universals an overdrive gears, I wanted to be just a 1/2 wider than the stock width,this was the ticket! awsome write up on the info
crawlernut is offline   Reply With Quote
Old 05-25-2012, 07:25 AM   #13
No idea what I'm doing
I did mine the same way, but this is a fantastic post! With the popularity of this mod, this should be stickied.
C*H*U*D is offline   Reply With Quote
Old 05-25-2012, 07:34 AM   #14
Great post Kent.
Another option for rear axle shafts are the Wheely King axle shafts. They are a direct drop in with "longer beef tubes".
No issues with mine in over 6 months of comps.
HPI Wheely King Straight Axle
Szczerba's FF-SZ 2.2s post #50
I have since replaced the spacers with e-clips to hold the axle in.
Szczerba is offline   Reply With Quote
Old 05-25-2012, 07:40 AM   #15
Location: Taylors Falls just hanging with the MNRCRC crew.
Great thread, it should be a sticky.
Stormin2u is offline   Reply With Quote
Old 05-25-2012, 07:44 AM   #16
Tire&Foam Extraordinaire
Nova's Ark's Avatar
Subscribed Kent. It was nice to meet you last weekend and I look forward to seeing this build come together.
Nova's Ark is offline   Reply With Quote
Old 05-25-2012, 09:01 AM   #17
Thanks guys!
It was my goal when I posted this to get as much info on this mod in one place as possible.
Once I start my build thread I will post a link to it in the original post.
Old 05-25-2012, 11:30 AM   #18
Chris_The_Battery_Man's Avatar
Heres instructions and purchase info on my delrin tubes:
http://www.rccrawler.com/forum/axles...ml#post3648912
Chris_The_Battery_Man is offline   Reply With Quote
Old 05-25-2012, 03:01 PM   #19
AXIAL Sells zero ackerman steering plates ax30778 that should fit the stock knuckle.
RCOG is offline   Reply With Quote
Old 05-27-2012, 05:12 PM   #20
yeah those work well I have them on mine
XR10 Mod for AX10 Axles Parts List - Similar Threads
newbie need help parts list for overdrive mod on mrc pro hammer29 Losi Mini-Rock Crawler 22 06-21-2015 02:20 PM
Axial parts list for scratch XR10 build? jubilee Axial XR10 7 04-11-2012 08:42 PM
X-Factor axles - PARTS LIST!!! cman_1500w XTM Crawler 15 10-24-2004 11:44 PM
