11-23-2007, 05:53 AM | #121 |
Pebble Pounder Join Date: Nov 2006 Location: scarborough CANADA
just got my ax10/ SW3 done. man what a difference. it seems to me that your chassis is a better fit and works better(a lot) than the stocker. Thanks Bender for all the help and setup tips. |
11-23-2007, 06:41 AM | #122 |
Pebble Pounder Join Date: Nov 2007 Location: canada
11-23-2007, 09:18 AM | #123 |
RCC Addict Join Date: Sep 2007 Location: WHEAT RIDGE, CO
Drilling the plate is simple........use your stock pan as a template, scribe-it, punch it (keep drill from wandering) and drill it. Bender used a dremel, i believe a drill-press is easier (for dorks like me) plus i'm using just two holes, countersunk, works well.Enjoy!!!!!!!!
11-23-2007, 09:54 AM | #124 | ||||
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
That can be arranged. Quote:
Thanks again guys. | ||||
11-23-2007, 11:31 AM | #125 |
I wanna be Dave Join Date: Oct 2007 Location: 801
Oh I am getting excited I cant wait for mine. I just ordered it early this week. Does anybody know if bender emails you when the chassis has been shipped?
11-26-2007, 10:58 PM | #126 | |
Your order did go out this morning. | |
11-30-2007, 11:16 AM | #127 |
| SW3 shoppers READ THIS Bender SW3 Rocks! If you’re considering this Chassis READ THIS. So I received my SW3 chassis last night. I put it together and my buddy who had the exact same set up as my Axial brought his Ax to come over for a mini comp in my rock garden. I was skeptically dropping $65 for a chassis that I thought looked cool, but may not perform that much better over stock. My buddy thought I was stupid and was wasting my money. I know 1 thing! “This Chassis doesn’t just make a little difference it makes a night and day difference.” Cato on this build said he was “impressed” I agree completely, but also think “impressed" is an understatement. I could not believe the lines I could drive over that my axial struggled with on several times. I set it up with 2” of ground clearance because that is what our axials had with the big bores and I wanted last night to be a good comparison between what I had vs. the SW3. Needless to say I schooled my buddies Axial. He couldn’t believe it and honestly neither could I. My friend who once made fun of me for buying a new chassis was now asking to drive my rig half the night. Keep in mind this is the same setup as my axial other than shorter lower links. Although the skid plate is longer than stock I now understand that the skid being thinner makes more of a difference than being shorter, Don’t let the longer skid turn you away from the SW3. I know Bender knows what he is doing and this is why he set it up this way. My first comp I took 34th out of 55 I have my second comp next Saturday so I will give you more updates as to how much better I did. I will promote this chassis until I die, or at least until a SW4 comes out! Sorry this is so long! Last edited by Chaotic Crawlers; 12-03-2007 at 06:41 PM. |
12-02-2007, 04:10 PM | #128 |
12-02-2007, 11:44 PM | #129 | |
| Quote: Thanks again for the compliments on the chassis too. | |
12-04-2007, 08:53 AM | #130 |
Thanks brad that means a lot coming from the man who makes these. Any suggestions on what i could have done better? |
12-04-2007, 12:23 PM | #131 | |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
Why are the Side plates different ? one is cut down low the other side is full with cut outs | |
12-05-2007, 03:17 PM | #132 |
| I did that to allow the tranny to be pulled out as quickly as possible, in case of breakage during comps. The SW3 is originally designed around the Stampede tranny, the tranny mounts to the engraved chassis plate. The open motor side plate makes it easier to work on the rig without completely tearing it down. It also allows AX10 owners to move the tranny around before they drill the holes and mount it.
12-05-2007, 03:22 PM | #133 | |
12-05-2007, 03:27 PM | #134 | |
12-07-2007, 05:16 PM | #135 |
RCC Addict Join Date: Apr 2006 Location: Brighton
I'm in, thanks for the chance ...excited to see how this SW3 and the AX-10 axles/trans works. Very cool!!!
12-07-2007, 11:43 PM | #136 |
Pebble Pounder Join Date: Jul 2007 Location: Okinawa, JP
you will not be disappointed!! super easy to switch over from stock and the balance and performance is unreal ! IMO
12-08-2007, 01:11 AM | #137 | |
12-08-2007, 01:21 AM | #138 |
Shouldn't the skid be as smooth and solid to slid over rocks why the heck would you create open pockets like this |
12-08-2007, 01:25 AM | #139 |
The reason the skid is short, is to accomodate a stampede tranny(which is what the SW chassis' were originally designed for)which lets the ears of the tranny slide down past the skid(that's the 2 holes you see in the chassis bottom section), for the lowest center of gravity. With a different tranny, it opens up those voids, but that is curable with a custom longer skid. |
12-08-2007, 10:04 PM | #140 | |
Tanis answered this already, it is because of the Stampede tranny. I ran a short skid for a while with no real issues getting caught up on it. | |
