Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Capra
Thread: What’d you do with your goat today?
Old 10-11-2020, 11:36 PM   #281
Default Re: What’d you do with your goat today?
i replaced the transmission case that i ground too far trying to fir a smaller pinion with a crawlmaster sport. got a crawl master pro 16t and installed it with a 9t pinion (no trans case adjustment necessary). great lo speed control. i also vented my deep woods. i won’t have the opportunity to get out for a couple days but im loving the low speed resolution in my house. i can’t wait to get it on some rocks.
splyn is offline   Reply With Quote
Old 11-11-2020, 02:55 PM   #282
Installed a Vanquish underdrive ring/pinion in the rear. Haven't tried it out side yet (raining here all day) but indoors I can really notice a better turning radius. Can't wait to try it on the rocks in the backyard course.
OnTheTrail is offline   Reply With Quote
Old 11-12-2020, 04:00 AM   #283
swapped out the deepwoods for showdowns. in side-by-side testing, showdowns seem to have the edge in the damp, clay and sandy conditions ive been crawling in. (wider lug spacing and less tendency to fold the lugs). I also added some home made weight using motorcycle wheel weights to each portal box. front got 42grams each (84g total) and rear got 28g each (56g total). its been raining for a couple days so probably wont be able to test the weights for a few days.
Old 11-12-2020, 07:34 AM   #284
What foam did you use for the Showdowns? Stock?
Kingmeow is offline   Reply With Quote
Old 11-12-2020, 10:35 AM   #285
Not trying to answer for anyone else. I run Showdowns on 2 of my crawlers. I thought the stock foams were way to soft and the tires folded over a lot side hilling. Put Proline dual stage foams in them and I think they’re great.
King Dork is offline   Reply With Quote
Old 11-12-2020, 01:35 PM   #286
Im using Pro-Line dual stage. i didnt like stock foams as they seemed too big and "folded" inside the tire. I didnt even install them completely. Although, im not sure the PL dual stages fit all that well because i can feel empty space between the foams and the sides of the tires. When these wear out i want to try some CI foams.
Oh, and the tires are vented. two holes 180 apart made with a soldering iron.
Old 11-12-2020, 04:25 PM   #287
Thanks to both for your replies.
What’d you do with your goat today? - Similar Threads
Goat 2s to 3s possible? Hoyta Electronics 1 06-10-2015 09:40 PM
Goat 2s help.... msd44 Electronics 10 03-12-2012 08:02 AM
Novak Goat Vs Novak Goat Ballistic?? k_r_a_c_k_e_r Electronics 3 02-19-2010 07:53 PM
new goat 3s redking Electronics 2 09-02-2009 11:13 AM
