12-20-2019, 06:42 PM | #181 |
Quarry Creeper Join Date: May 2019 Location: North Highlands
| Re: What’d you do with your goat today? |
12-23-2019, 09:31 AM | #182 |
RCC Addict Join Date: Dec 2014 Location: So Cal
Pictures are worth 1000 words..... 20191223_080458 by MAC FAB, on Flickr 20191223_080350 by MAC FAB, on Flickr |
12-24-2019, 10:15 AM | #183 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
That came out great Mac Fab! I dig it.
12-24-2019, 02:29 PM | #184 |
I wanna be Dave Join Date: Sep 2019 Location: US
Today I finally finished my Imperial Capra (well, with the exception of the flat skid from InTheWoks (which is on the way). Find steps involved installing the Desert Lizard shocks, and putting the wheels (with JConcepts Landmines) back on. Full details on today's work at: https://r.tapatalk.com/shareLink/top...ink_source=app ~ More peace, love, laughter & kindness would make the world a MUCH better place |
12-24-2019, 09:33 PM | #185 | |
Rock Stacker Join Date: Feb 2017 Location: Tehachapi
| Re: What’d you do with your goat today? Quote:
12-26-2019, 01:55 PM | #186 |
Today, I officially gave up on the 3-position dig, removed the skid, removed the dig servo horn, recentered the servo, and set the dig up as 2-position (you happy now, Horizon Hobby?). I can see why they chose to market it as a 2-position, instead of a 3-position...the "middle" position is very inconsistent. But, truth-be-told, I'm not worried. When I built the second Capra, using an AX10 trans w/ VP Hurtz V2 dig, that will be set up as a 3-position, and I'm extremely confident it will operate workout problems. The second thing I did today was weigh my goat. Weights convert as such: Total - 3112g, or 6.86lbs Front half - 1771g, or 3.9lbs Rear half - 1341g, or 2.956lbs Left side - 1556g, or 2.43lbs Right side - 1556g, or 2.43lbs Front Right - 892.6g, or 1.968lbs Front Left - 878.7g, or 1.937lbs Rear Right - 677.3g, or 1.493lbs Rear Left - 663.7g, or 2.463lbs I'd guess that the 57% front, 43% rear is pretty decent. ~ More peace, love, laughter & kindness would make the world a MUCH better place Last edited by Panther6834; 12-26-2019 at 06:19 PM. |
12-26-2019, 06:17 PM | #187 | |
12-26-2019, 07:33 PM | #188 | |
Pebble Pounder Join Date: Mar 2019 Location: Ecuador
What would be a good servo setup to make the 3 position dig work? I’d love to have that option. | |
12-26-2019, 11:41 PM | #189 | |
As for good servos, that's a can of worms. I used a Hitec HS-65MG and it performed flawlessly. But then I wanted waterproof and to be able to pump more voltage to my steering servo so I put in a Power HD TR4. Been out 3 times with that one and it's been working well too. | |
12-27-2019, 03:50 PM | #190 |
RCC Addict Join Date: Jun 2012 Location: Meridian,Id
A Tekin 35 turn and 1 tenth hobby rear bed piece. Sent from my iPhone using Tapatalk |
12-27-2019, 03:57 PM | #191 |
| Re: What’d you do with your goat today? I've been considering this for the second Capra. Curious...did you mount the rear shocks to the stock mounts? Or to the mounts built into the rear bed/support? ~ More peace, love, laughter & kindness would make the world a MUCH better place Last edited by Panther6834; 12-27-2019 at 04:21 PM. |
12-27-2019, 03:58 PM | #192 |
I mounted them to the shock mount that’s built into the lower bed brace Sent from my iPhone using Tapatalk |
12-27-2019, 04:23 PM | #193 | |
~ More peace, love, laughter & kindness would make the world a MUCH better place | |
12-27-2019, 07:16 PM | #194 | |
Quarry Creeper Join Date: May 2019 Location: Knoxville
I'm sorry you couldn't get it working. Mine has worked fine since day 1 with a Spektrum DX5c using the SX107 servo. I'll admit that I spent a fair amount of time on the front end making it work in a 3 position (and I rarely use the freewheel so I don't feel you are "sacrificing" anything) but at least you can make the 2 position work fine. | |
01-04-2020, 03:42 PM | #195 |
Today was a very short day of working on the Imperial Capra. Installed the OD portal gears, and finally came up with a "fix" for the piece of plastic 'garbage' used on the slipper. For the slipper spring part number, turn to my Imperial thread. ~ More peace, love, laughter & kindness would make the world a MUCH better place Last edited by Panther6834; 01-04-2020 at 03:48 PM. |
01-04-2020, 04:44 PM | #196 |
If you’re having problems with your slipper it may because your slipper pad isn’t seated properly. If it’s not seated on both sides you’re going to get slippage. If it is seated properly it shouldn’t slip at all when tightened.
01-04-2020, 09:30 PM | #197 | |
~ More peace, love, laughter & kindness would make the world a MUCH better place Last edited by Panther6834; 01-04-2020 at 10:47 PM. | |
01-04-2020, 10:25 PM | #198 | |
Everything is awsome with the Capra, everything but taking it apart... it’s a pain in the a** | |
01-04-2020, 10:46 PM | #199 |
01-13-2020, 04:17 AM | #200 |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
Figured I'd post everything that I've done so far over the past couple weeks since I don't have a thread created for my Capra. Still some more things to do... incl SS brass portal covers, scale hubs, SSD dig servo mounts, etc. But here's what I've done so far: > 3BrosRC G13 steering servo/ 19 mm alum arm. > Super Shafty aluminum steering servo mounting plate. > XT60 battery connector. > SSD 1.9 Trail bead-locks > Proline Flat Iron tires w/ CI 2-stage med/ soft foams. > YR Fire Extinguisher. > Body panels- White/ silver/ gun metal fade. > Stock grill- painted silver ( will prob also fab up black grill mesh soon). > Side vent- Hated the vent decals so used metal plate for more scale appearance. > OEM fuel cell- Painted plus added filler standoff, cap, braided fuel line, and breather valve. > Rear reflective faux lights- One spot/ two brake lights. > Light bar wires shrink-wrapped for more scale appearance. Did some other less significant mods and details but those are the main things. Pics: All finished for now... |
What’d you do with your goat today? - Similar Threads | ||||
Goat 2s to 3s possible? | Hoyta | Electronics | 1 | 06-10-2015 09:40 PM |
Goat 2s help.... | msd44 | Electronics | 10 | 03-12-2012 08:02 AM |
Novak Goat Vs Novak Goat Ballistic?? | k_r_a_c_k_e_r | Electronics | 3 | 02-19-2010 07:53 PM |
new goat 3s | redking | Electronics | 2 | 09-02-2009 11:13 AM |
